[GeoNode-users] Multi-Tenancy on apt-get installation
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jan 26 04:37:47 PST 2017
Hi Davide,
in order to customise geonode in production you should use the geonode
project, see here https://github.com/GeoNode/geonode-project. It is always
suggested to first try in dev mode and then switch to production.
Just a note, the documentation on geosites is not 100% correct (for example
the addsite command is not available and you have to manually copy and
modify the template folder) and you will have to know some django basics in
order to set it up correctly.
hope this helps
2017-01-26 13:31 GMT+01:00 Davide Sandona' <sandona.davide at gmail.com>:
> Hello,
> I've setup a Virtual Machine running Ubuntu 14.04, and I've installed
> GeoNode using atp-get. I was looking to test a Multi-Tenancy setup.
> I'm not able to locate the settings.py file, in order to add
> "geonode.contrib.geosites" to INSTALLED_APPS.
> Reading the docs, it should be located into /etc/geonode folder, instead
> in that folder there is the local_settings.py file (there is no
> INSTALLED_APPS variable in this file).
> How these two files (settings.py and local_settings.py) are related? What
> should I do?
> Davide.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170126/5f5a07be/attachment.html>
More information about the geonode-users mailing list
