[GeoNode-users] Geonode deploying on a working virtual machine with Ubuntu 12.04
Simone Dalmasso simone.dalmasso at gmail.com
Mon Jan 30 00:23:36 PST 2017
your procedure is correct, you have to go with the manual installation.
Geoexplorer hasn't changed from 2.0 to 2.4, you should investigate more the
issue of pink tiles by looking at the http response that comes from
geoserver. For the limited zoom it may just be a configuration in the
map_geoexplorer template
https://github.com/GeoNode/geonode/blob/master/geonode/maps/templates/maps/map_geoexplorer.js
hope this helps
2017-01-27 17:14 GMT+01:00 gkpetrak <gkpetrak at gmail.com>:
> Hello,
> I installed and customized a Geonode project (2.0 edition) on my fresh
> local machine (Ubuntu 12.04) with apt-get installation.
> Now I have to deploy the project on a virtual machine which already hosts
> a WebGIS application (with technologies such as Geoserver / Jetty,
> Postgresql / PostGIS, Apache2) on Ubuntu 12.04.
> I think that Geonode installation via apt-get is not recommended when the
> machine already runs individual software components of Geonode. So I have
> to install Geonode with custom installation following this link:
> https://geonode.readthedocs.io/en/2.0/tutorials/admin/instal
> l/complete_install.html
> Am I wrong ?
> Also because I have some problems with GeoExplorer of Geonode 2.0 (pink
> tiles and limited zoom in) is there a way to upgrade to GeoExplorer of
> Geonode 2.4 ?
> Thank you in advance !
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170130/6501230f/attachment.html>
More information about the geonode-users mailing list
