[GeoNode-users] Issue on updateip in migration to 2.6
Simone Dalmasso simone.dalmasso at gmail.com
Mon Jul 3 02:31:08 PDT 2017
Annalisa, layer preview from geoserver seems to have a bug in the url of
the preview itself
if you right click and copy the url you'll notice it has two "?". if you
replace the second one with "&" then should work. This will probably be
fixed in next gs releases
2017-07-03 11:21 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Hi Toni,
> 2017-07-03 10:07 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de>
>> Hi Annalisa,
>> I setted the ip address in geonode-oauth2 in a couple of lines they still
>> point to "localhost“.
>> You could grep your files to see if somewhere localhost is still
>> mentioned:
>> grep -rn --include="*.py“ „192.68.31.80" 2>/dev/null
> Ok, but now it seems that localhost should remain in some settings, maybe?
>> Here it is an example of a wrong preview link:
>> http://192.168.31.80/geoserver/geonode/wms?access_token=SFtO
>> 1m1uwzKVWzOmJmsQi72nMQyEfi?service=WMS&version=1.1.0&requ
>> est=GetMap&layers=geonode:v_staz_aria_attive&styles=&bbox=
>> 1647277.811,4991070.397,1798213.0,5117620.0&width=768&height
>> =643&srs=EPSG:3003&format=application/openlayers
>> You want the local IP to be a public, right?
>> Stupid question. Have you restarted your web servers?
> After checking all, I'll have to change it to a domain ... Yes, I've
> restarted apache and tomcat
>> Then, I've some old layers in geonode that doesn't more exists in
>> geoserver. If I try to remove from geonode ui It fails. Also the "geonode
>> updatelayers --remove-deleted" fails on those layers
>> updatelayers has a verbose option.
>> http://docs.geonode.org/en/master/tutorials/admin/admin_mgmt
>> _commands/#updatelayers
>> can you provide a detailed error output?
>> There are geonode commands for clean or syncronize databases? Some docs?
>> syncdb is now deprecated, right?
>> I think to remember that from Django 1.9 synchdb is depreceated. Instead
>> migrate
>> should work. F.e.:
>> python manage.py migrate auth# performs migrations for auth and contenttypes contrib apps
>> python manage.py migrate --run-syncdb# creates the rest of the database
>> I couldn´t find any updated documentation either.
>> When searching for things like that I often have a look in pavement.py  ;)
>> https://github.com/GeoNode/geonode/blob/master/pavement.py#L213
>> Thanks
> Annalisa
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Mobil +49/ (0) 176 6680 3198 <+49%20176%2066803198>
>> Tel  +49/ (0) 341 24 04 738 <+49%20341%202404738>
>> Fax  +49/ (0) 341 24 04 73 <+49%20341%20240473>
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170703/15c68707/attachment-0001.html>
More information about the geonode-users mailing list
