[GeoNode-users] Error when trying to view maps in windows 2.6
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 7 00:15:34 PDT 2017
Seems connection issues, this could be the reason of all the errors you get.
2017-07-07 2:55 GMT+02:00 Franklin, Chris <CFranklin at anglogoldashanti.com>:
> error at /maps/20
> [Errno 10053] An established connection was aborted by the software in
> your host machine
> Request Method:             GET
> Request URL:     http://*********/maps/20
> Django Version: 1.8.17
> Exception Type: error
> Exception Value:
> your host machine
> Exception Location:         C:\GeoNode-2.6.x\Python27\Lib\socket.py in
> readline, line 480
> Python Executable:          C:\GeoNode-2.6.x\Apache2\bin\Apache.exe
> Python Version: 2.7.10
> Python Path:
> ['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\Lib\\site-packages',
> 'C:\\GeoNode-2.6.x\\Python27\\python27.zip',
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\DLLs',
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib',
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\plat-win',
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\lib-tk',
> 'C:\\GeoNode-2.6.x\\Apache2\\bin',
> 'C:\\GeoNode-2.6.x\\Python27\\Lib',
> 'C:\\GeoNode-2.6.x\\Python27\\DLLs',
> 'C:\\GeoNode-2.6.x\\Python27\\Lib\\lib-tk',
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x',
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages',
> 'C:\\GeoNode-2.6.x\\Apache2']
> Server time:        Fri, 7 Jul 2017 08:53:39 -0500
> Error during template rendering
> In template C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\templates\maps\map_detail.html,
> error at line 215
> 10053
> 205
> 206                <li class="list-group-item">
> 207                  <h4>{% trans "Copy this map" %}</h4>
> 208                  <p>{% trans "Duplicate this map and modify it for
> your own purposes" %}</p>
> 209                  <a href="{% url "new_map" %}?copy={{ resource.id }}"
> class="btn btn-default btn-md btn-block">{% trans "Create a New Map" %}</a>
> 210                </li>
> 211
> 212                {% if resource.is_public and "change_resourcebase" in
> perms_list or resource.layer_group %}
> 213                <li class="list-group-item">
> 214                  <h4>{% trans "Map WMS" %}</h4>
> 215
>                 <dl>
>       {% if resource.layer_group %}
> 216                    <dt>{% trans "WMS layer group for local map layers"
> %}:</dt>
> 217                    <dd><em>{{ resource.layer_group.catalog.name
> }}</em> ({% trans "on" %} <a href="{{ resource.layer_group.ows
> }}?service=WMS&request=GetCapabilities">{% trans "local OWS" %}</a>)</dd>
> 218                    {% endif %}</dl>
> 219                  {% if "change_resourcebase" in perms_list %}
> 220                  <p>{% trans "Publish local map layers as WMS layer
> group" %}</p>
> 221                  <a id="layer-group" href="{%url "map_wms" resource.id
> %}" class="btn btn-default btn-md btn-block">{% trans "Publish Map WMS"
> %}</a>
> 222                  {% endif %}
> 223                  <dl id="layer-group-dl"></dl>
> 224                </li>
> 225                {% endif %}
> Traceback Switch to copy-and-paste view
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\core\handlers\base.py
> in get_response
>                                 response = wrapped_callback(request,
> *callback_args, **callback_kwargs) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\views.py in map_detail
>                 return render_to_response(template,
> RequestContext(request, context_dict)) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\shortcuts.py in
> render_to_response
>                     content = loader.render_to_string(template_name,
> context, using=using) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\loader.py
> in render_to_string
>                     return template.render(context, request) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\backends\django.py
> in render
>                     return self.template.render(context) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py
> in render
>                                 return self._render(context) ...
> ▶ Local vars
> in _render
>                     return self.nodelist.render(context) ...
> ▶ Local vars
> in render
>                             bit = self.render_node(node, context) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\debug.py
> in render_node
>                         return node.render(context) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\loader_tags.py
> in render
>                     return compiled_parent._render(context) ...
> ▶ Local vars
> in _render
> ▶ Local vars
> in render
> ▶ Local vars
> in render_node
> ▶ Local vars
> in render
> ▶ Local vars
> in _render
> ▶ Local vars
> in render
> ▶ Local vars
> in render_node
> ▶ Local vars
> in render
> ▶ Local vars
> in _render
> ▶ Local vars
> in render
> ▶ Local vars
> in render_node
> ▶ Local vars
> in render
>                             result = block.nodelist.render(context) ...
> ▶ Local vars
> in render
> ▶ Local vars
> in render_node
> ▶ Local vars
> in render
> ▶ Local vars
> in render
> ▶ Local vars
> in render_node
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\defaulttags.py
> in render
>                             return nodelist.render(context) ...
> ▶ Local vars
> in render
> ▶ Local vars
> in render_node
> ▶ Local vars
> in render
>                                 match = condition.eval(context) ...
> ▶ Local vars
> in eval
>                     return self.value.resolve(context,
> ignore_failures=True) ...
> ▶ Local vars
> in resolve
>                             obj = self.var.resolve(context) ...
> ▶ Local vars
> in resolve
>                         value = self._resolve_lookup(context) ...
> ▶ Local vars
> in _resolve_lookup
>                                     current = getattr(current, bit) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\models.py in layer_group
>                             'catalog': gs_catalog.get_layergroup(lg_name),
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\geoserver\catalog.py in
> get_layergroup
>                         group = self.get_xml(group_url) ...
> ▶ Local vars
> get_xml
>                         response, content = self.http.request(rest_url) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\httplib2\__init__.py in
> request
>                                 (response, content) = self._request(conn,
> authority, uri, request_uri, method, body, headers, redirections, cachekey)
> ▶ Local vars
> _request
>                     (response, content) = self._conn_request(conn,
> request_uri, method, body, headers) ...
> ▶ Local vars
> _conn_request
>                             response = conn.getresponse() ...
> ▶ Local vars
> C:\GeoNode-2.6.x\Python27\Lib\httplib.py in getresponse
>                         response.begin() ...
> ▶ Local vars
> C:\GeoNode-2.6.x\Python27\Lib\httplib.py in begin
>                         version, status, reason = self._read_status() ...
> ▶ Local vars
> C:\GeoNode-2.6.x\Python27\Lib\httplib.py in _read_status
>                     line = self.fp.readline(_MAXLINE + 1) ...
> ▶ Local vars
> C:\GeoNode-2.6.x\Python27\Lib\socket.py in readline
>                                 data = self._sock.recv(self._rbufsize) ...
> ▶ Local vars
> Request information
> GET
> No GET data
> POST
> No POST data
> FILES
> No FILES data
> COOKIES
> Variable               Value
> csrftoken
> 'dzHRAPIfiD2PDIst1cJDKlLYYQaJgXwW'
> sessionid
> '08oyegge9s9iphmpdiz55b7t441qp28u'
> META
> Variable               Value
> wsgi.multiprocess
> False
> HTTP_COOKIE
> 'sessionid=08oyegge9s9iphmpdiz55b7t441qp28u; csrftoken=
> SERVER_PROTOCOL
> 'HTTP/1.1'
> SERVER_SOFTWARE
> 'Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10'
> SCRIPT_NAME
> u''
> mod_wsgi.enable_sendfile
> '0'
> mod_wsgi.handler_script
> SERVER_SIGNATURE
> REQUEST_METHOD
> 'GET'
> PATH_INFO
> u'/maps/20'
> SystemRoot
> 'C:\\Windows'
> QUERY_STRING
> wsgi.errors
> <mod_wsgi.Log object at 0x0CF93E58>
> HTTP_USER_AGENT
> 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like
> Gecko) Chrome/59.0.3071.115 Safari/537.36'
> HTTP_CONNECTION
> 'keep-alive'
> HTTP_REFERER
> 'http://*********/maps/?limit=100&offset=0'
> SERVER_NAME
> REMOTE_ADDR
> '172.16.1.179'
> mod_wsgi.request_handler
> 'wsgi-script'
> apache.version
> (2, 4, 10)
> wsgi.url_scheme
> 'http'
> PATH_TRANSLATED
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\wsgi.py\\maps\\20'
> SERVER_PORT
> '80'
> mod_wsgi.version
> (4, 4, 21)
> SERVER_ADDR
> '172.16.0.229'
> DOCUMENT_ROOT
> 'C:/GeoNode-2.6.x/geonode-2.6.x/geonode'
> mod_wsgi.process_group
> CONTEXT_DOCUMENT_ROOT
> COMSPEC
> 'C:\\Windows\\system32\\cmd.exe'
> mod_wsgi.path_info
> '/maps/20'
> SCRIPT_FILENAME
> 'C:/GeoNode-2.6.x/geonode-2.6.x/geonode/wsgi.py'
> SERVER_ADMIN
> 'webmaster at example.org'
> wsgi.input
> <mod_wsgi.Input object at 0x0EECEEC0>
> HTTP_HOST
> CONTEXT_PREFIX
> mod_wsgi.callable_object
> 'application'
> wsgi.multithread
> True
> PATHEXT
> '.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC'
> REQUEST_URI
> '/maps/20'
> HTTP_ACCEPT
> 'text/html,application/xhtml+xml,application/xml;q=0.9,
> image/webp,image/apng,*/*;q=0.8'
> WINDIR
> 'C:\\Windows'
> wsgi.file_wrapper
> wsgi.version
> (1, 0)
> GATEWAY_INTERFACE
> 'CGI/1.1'
> wsgi.run_once
> False
> mod_wsgi.script_name
> REMOTE_PORT
> '53847'
> HTTP_ACCEPT_LANGUAGE
> 'en-US,en;q=0.8'
> REQUEST_SCHEME
> 'http'
> CSRF_COOKIE_USED
> True
> mod_wsgi.script_start
> '1499388818784964'
> HTTP_UPGRADE_INSECURE_REQUESTS
> '1'
> mod_wsgi.application_group
> 'localhost|'
> mod_wsgi.script_reloading
> '1'
> mod_wsgi.request_start
> '1499388818784964'
> CSRF_COOKIE
> u'dzHRAPIfiD2PDIst1cJDKlLYYQaJgXwW'
> HTTP_ACCEPT_ENCODING
> 'gzip, deflate'
> Settings
> Using settings module geonode.settings
> Setting  Value
> _DEFAULT_LOCALE_PATHS
> ('C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\locale',)
> CASCADE_WORKSPACE
> 'geonode'
> DEFAULT_WORKSPACE
> 'geonode'
> ACCOUNT_USER_DISPLAY
> <function <lambda> at 0x0AB76770>
> DATABASES
> {'datastore': {'ATOMIC_REQUESTS': False,
>                'AUTOCOMMIT': True,
>                'CONN_MAX_AGE': 0,
>                'ENGINE': 'django.contrib.gis.db.backends.postgis',
>                'HOST': 'localhost',
>                'NAME': 'geonode_imports',
>                'OPTIONS': {},
>                'PASSWORD': u'********************',
>                'PORT': '5454',
>                'TEST': {'CHARSET': None,
>                         'COLLATION': None,
>                         'MIRROR': None,
>                         'NAME': None},
>                'TIME_ZONE': 'America/Chicago',
>                'USER': 'geonode'},
> 'default': {'ATOMIC_REQUESTS': False,
>              'AUTOCOMMIT': True,
>              'CONN_MAX_AGE': 0,
>              'ENGINE': 'django.db.backends.postgresql_psycopg2',
>              'NAME': 'geonode',
>              'OPTIONS': {},
>              'PORT': '5454',
>                       'COLLATION': None,
>                       'MIRROR': None,
>                       'NAME': None},
>              'USER': 'geonode'}}
> AWS_QUERYSTRING_AUTH
> False
> CELERY_CREATE_MISSING_QUEUES
> True
> GEONODE_CONTRIB_APPS
> ('geonode.contrib.dynamic',
> 'geonode.contrib.exif',
> 'geonode.contrib.favorite',
> 'geonode.contrib.geogig',
> 'geonode.contrib.geosites',
> 'geonode.contrib.nlp',
> 'geonode.contrib.slack',
> 'geonode.contrib.metadataxsl')
> CSRF_COOKIE_SECURE
> False
> CELERY_DEFAULT_QUEUE
> 'default'
> UPLOADER
> {'BACKEND': 'geonode.rest',
> 'OPTIONS': {'GEOGIG_ENABLED': False,
>              'MOSAIC_ENABLED': False,
>              'TIME_ENABLED': False}}
> LANGUAGE_CODE
> 'en'
> LICENSES
> {'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
> MANAGERS
> DOWNLOAD_FORMATS_METADATA
> ['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
> BROKER_URL
> 'django://'
> SILENCED_SYSTEM_CHECKS
> DEFAULT_CHARSET
> 'utf-8'
> IGNORABLE_404_URLS
> CELERY_DEFAULT_EXCHANGE_TYPE
> 'direct'
> GDAL_LIBRARY_PATH
> 'C:\\GeoNode-2.6.x\\GDAL\\gdal111.dll'
> DEFAULT_MAP_CENTER
> (0, 0)
> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
> 3
> TIME_INPUT_FORMATS
> ('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
> None
> ACCOUNT_INVITE_USER_URL
> u'account_invite_user'
> REGISTRATION_OPEN
> 1
> ALLOWED_HOSTS
> ['localhost', '127.0.0.1', '*********']
> EMAIL_HOST
> 'localhost'
> DOWNLOAD_FORMATS_RASTER
> ['JPEG',
> 'PDF',
> 'PNG',
> 'ArcGrid',
> 'GeoTIFF',
> 'Gtopo30',
> 'ImageMosaic',
> 'KML',
> 'View in Google Earth',
> 'Tiles',
> 'GML',
> 'GZIP']
> AUTH_EXEMPT_URLS
> WSGI_APPLICATION
> None
> EMAIL_SUBJECT_PREFIX
> '[Django] '
> SERVER_EMAIL
> 'root at localhost'
> SECURE_HSTS_SECONDS
> 0
> STATICFILES_FINDERS
> ('django.contrib.staticfiles.finders.FileSystemFinder',
> 'django.contrib.staticfiles.finders.AppDirectoriesFinder')
> NOTIFICATION_QUEUE_ALL
> False
> S3_MEDIA_ENABLED
> False
> CELERY_IMPORTS
> ('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
> SESSION_COOKIE_DOMAIN
> None
> SESSION_COOKIE_NAME
> 'sessionid'
> GEOSERVER_PUBLIC_LOCATION
> 'http://localhost:8080/geoserver/'
> AWS_STORAGE_BUCKET_NAME
> AWS_BUCKET_NAME
> SECURE_REDIRECT_EXEMPT
> ACCOUNT_USE_AUTH_AUTHENTICATE
> False
> EMAIL_SSL_KEYFILE
> FILE_UPLOAD_DIRECTORY_PERMISSIONS
> None
> X_FRAME_OPTIONS
> 'SAMEORIGIN'
> FILE_UPLOAD_PERMISSIONS
> None
> ACCOUNT_TIMEZONES
> [('Africa/Abidjan', 'Africa/Abidjan'),
> ('Africa/Accra', 'Africa/Accra'),
> ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
> ('Africa/Algiers', 'Africa/Algiers'),
> ('Africa/Asmara', 'Africa/Asmara'),
> ('Africa/Asmera', 'Africa/Asmera'),
> ('Africa/Bamako', 'Africa/Bamako'),
> ('Africa/Bangui', 'Africa/Bangui'),
> ('Africa/Banjul', 'Africa/Banjul'),
> ('Africa/Bissau', 'Africa/Bissau'),
> ('Africa/Blantyre', 'Africa/Blantyre'),
> ('Africa/Brazzaville', 'Africa/Brazzaville'),
> ('Africa/Bujumbura', 'Africa/Bujumbura'),
> ('Africa/Cairo', 'Africa/Cairo'),
> ('Africa/Casablanca', 'Africa/Casablanca'),
> ('Africa/Ceuta', 'Africa/Ceuta'),
> ('Africa/Conakry', 'Africa/Conakry'),
> ('Africa/Dakar', 'Africa/Dakar'),
> ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
> ('Africa/Djibouti', 'Africa/Djibouti'),
> ('Africa/Douala', 'Africa/Douala'),
> ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
> ('Africa/Freetown', 'Africa/Freetown'),
> ('Africa/Gaborone', 'Africa/Gaborone'),
> ('Africa/Harare', 'Africa/Harare'),
> ('Africa/Johannesburg', 'Africa/Johannesburg'),
> ('Africa/Juba', 'Africa/Juba'),
> ('Africa/Kampala', 'Africa/Kampala'),
> ('Africa/Khartoum', 'Africa/Khartoum'),
> ('Africa/Kigali', 'Africa/Kigali'),
> ('Africa/Kinshasa', 'Africa/Kinshasa'),
> ('Africa/Lagos', 'Africa/Lagos'),
> ('Africa/Libreville', 'Africa/Libreville'),
> ('Africa/Lome', 'Africa/Lome'),
> ('Africa/Luanda', 'Africa/Luanda'),
> ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
> ('Africa/Lusaka', 'Africa/Lusaka'),
> ('Africa/Malabo', 'Africa/Malabo'),
> ('Africa/Maputo', 'Africa/Maputo'),
> ('Africa/Maseru', 'Africa/Maseru'),
> ('Africa/Mbabane', 'Africa/Mbabane'),
> ('Africa/Mogadishu', 'Africa/Mogadishu'),
> ('Africa/Monrovia', 'Africa/Monrovia'),
> ('Africa/Nairobi', 'Africa/Nairobi'),
> ('Africa/Ndjamena', 'Africa/Ndjamena'),
> ('Africa/Niamey', 'Africa/Niamey'),
> ('Africa/Nouakchott', 'Africa/Nouakchott'),
> ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
> ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
> ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
> ('Africa/Timbuktu', 'Africa/Timbuktu'),
> ('Africa/Tripoli', 'Africa/Tripoli'),
> ('Africa/Tunis', 'Africa/Tunis'),
> ('Africa/Windhoek', 'Africa/Windhoek'),
> ('America/Adak', 'America/Adak'),
> ('America/Anchorage', 'America/Anchorage'),
> ('America/Anguilla', 'America/Anguilla'),
> ('America/Antigua', 'America/Antigua'),
> ('America/Araguaina', 'America/Araguaina'),
> ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
> ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
> ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
> ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
> ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
> ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
> ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
> ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
> ('America/Argentina/Salta', 'America/Argentina/Salta'),
> ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
> ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
> ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
> ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
> ('America/Aruba', 'America/Aruba'),
> ('America/Asuncion', 'America/Asuncion'),
> ('America/Atikokan', 'America/Atikokan'),
> ('America/Atka', 'America/Atka'),
> ('America/Bahia', 'America/Bahia'),
> ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
> ('America/Barbados', 'America/Barbados'),
> ('America/Belem', 'America/Belem'),
> ('America/Belize', 'America/Belize'),
> ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
> ('America/Boa_Vista', 'America/Boa_Vista'),
> ('America/Bogota', 'America/Bogota'),
> ('America/Boise', 'America/Boise'),
> ('America/Buenos_Aires', 'America/Buenos_Aires'),
> ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
> ('America/Campo_Grande', 'America/Campo_Grande'),
> ('America/Cancun', 'America/Cancun'),
> ('America/Caracas', 'America/Caracas'),
> ('America/Catamarca', 'America/Catamarca'),
> ('America/Cayenne', 'America/Cayenne'),
> ('America/Cayman', 'America/Cayman'),
> ('America/Chicago', 'America/Chicago'),
> ('America/Chihuahua', 'America/Chihuahua'),
> ('America/Coral_Harbour', 'America/Coral_Harbour'),
> ('America/Cordoba', 'America/Cordoba'),
> ('America/Costa_Rica', 'America/Costa_Rica'),
> ('America/Creston', 'America/Creston'),
> ('America/Cuiaba', 'America/Cuiaba'),
> ('America/Curacao', 'America/Curacao'),
> ('America/Danmarkshavn', 'America/Danmarkshavn'),
> ('America/Dawson', 'America/Dawson'),
> ('America/Dawson_Creek', 'America/Dawson_Creek'),
> ('America/Denver', 'America/Denver'),
> ('America/Detroit', 'America/Detroit'),
> ('America/Dominica', 'America/Dominica'),
> ('America/Edmonton', 'America/Edmonton'),
> ('America/Eirunepe', 'America/Eirunepe'),
> ('America/El_Salvador', 'America/El_Salvador'),
> ('America/Ensenada', 'America/Ensenada'),
> ('America/Fort_Nelson', 'America/Fort_Nelson'),
> ('America/Fort_Wayne', 'America/Fort_Wayne'),
> ('America/Fortaleza', 'America/Fortaleza'),
> ('America/Glace_Bay', 'America/Glace_Bay'),
> ('America/Godthab', 'America/Godthab'),
> ('America/Goose_Bay', 'America/Goose_Bay'),
> ('America/Grand_Turk', 'America/Grand_Turk'),
> ('America/Grenada', 'America/Grenada'),
> ('America/Guadeloupe', 'America/Guadeloupe'),
> ('America/Guatemala', 'America/Guatemala'),
> ('America/Guayaquil', 'America/Guayaquil'),
> ('America/Guyana', 'America/Guyana'),
> ('America/Halifax', 'America/Halifax'),
> ('America/Havana', 'America/Havana'),
> ('America/Hermosillo', 'America/Hermosillo'),
> ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
> ('America/Indiana/Knox', 'America/Indiana/Knox'),
> ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
> ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
> ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
> ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
> ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
> ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
> ('America/Indianapolis', 'America/Indianapolis'),
> ('America/Inuvik', 'America/Inuvik'),
> ('America/Iqaluit', 'America/Iqaluit'),
> ('America/Jamaica', 'America/Jamaica'),
> ('America/Jujuy', 'America/Jujuy'),
> ('America/Juneau', 'America/Juneau'),
> ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
> ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
> ('America/Knox_IN', 'America/Knox_IN'),
> ('America/Kralendijk', 'America/Kralendijk'),
> ('America/La_Paz', 'America/La_Paz'),
> ('America/Lima', 'America/Lima'),
> ('America/Los_Angeles', 'America/Los_Angeles'),
> ('America/Louisville', 'America/Louisville'),
> ('America/Lower_Princes', 'America/Lower_Princes'),
> ('America/Maceio', 'America/Maceio'),
> ('America/Managua', 'America/Managua'),
> ('America/Manaus', 'America/Manaus'),
> ('America/Marigot', 'America/Marigot'),
> ('America/Martinique', 'America/Martinique'),
> ('America/Matamoros', 'America/Matamoros'),
> ('America/Mazatlan', 'America/Mazatlan'),
> ('America/Mendoza', 'America/Mendoza'),
> ('America/Menominee', 'America/Menominee'),
> ('America/Merida', 'America/Merida'),
> ('America/Metlakatla', 'America/Metlakatla'),
> ('America/Mexico_City', 'America/Mexico_City'),
> ('America/Miquelon', 'America/Miquelon'),
> ('America/Moncton', 'America/Moncton'),
> ('America/Monterrey', 'America/Monterrey'),
> ('America/Montevideo', 'America/Montevideo'),
> ('America/Montreal', 'America/Montreal'),
> ('America/Montserrat', 'America/Montserrat'),
> ('America/Nassau', 'America/Nassau'),
> ('America/New_York', 'America/New_York'),
> ('America/Nipigon', 'America/Nipigon'),
> ('America/Nome', 'America/Nome'),
> ('America/Noronha', 'America/Noronha'),
> ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
> ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
> ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
> ('America/Ojinaga', 'America/Ojinaga'),
> ('America/Panama', 'America/Panama'),
> ('America/Pangnirtung', 'America/Pangnirtung'),
> ('America/Paramaribo', 'America/Paramaribo'),
> ('America/Phoenix', 'America/Phoenix'),
> ('America/Port-au-Prince', 'America/Port-au-Prince'),
> ('America/Port_of_Spain', 'America/Port_of_Spain'),
> ('America/Porto_Acre', 'America/Porto_Acre'),
> ('America/Porto_Velho', 'America/Porto_Velho'),
> ('America/Puerto_Rico', 'America/Puerto_Rico'),
> ('America/Rainy_River', 'America/Rainy_River'),
> ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
> ('America/Recife', 'America/Recife'),
> ('America/Regina', 'America/Regina'),
> ('America/Resolute', 'America/Resolute'),
> ('America/Rio_Branco', 'America/Rio_Branco'),
> ('America/Rosario', 'America/Rosario'),
> ('America/Santa_Isabel', 'America/Santa_Isabel'),
> ('America/Santarem', 'America/Santarem'),
> ('America/Santiago', 'America/Santiago'),
> ('America/Santo_Domingo', 'America/Santo_Domingo'),
> ('America/Sao_Paulo', 'America/Sao_Paulo'),
> ('America/Scoresbysund', 'America/Scoresbysund'),
> ('America/Shiprock', 'America/Shiprock'),
> ('America/Sitka', 'America/Sitka'),
> ('America/St_Barthelemy', 'America/St_Barthelemy'),
> ('America/St_Johns', 'America/St_Johns'),
> ('America/St_Kitts', 'America/St_Kitts'),
> ('America/St_Lucia', 'America/St_Lucia'),
> ('America/St_Thomas', 'America/St_Thomas'),
> ('America/St_Vincent', 'America/St_Vincent'),
> ('America/Swift_Current', 'America/Swift_Current'),
> ('America/Tegucigalpa', 'America/Tegucigalpa'),
> ('America/Thule', 'America/Thule'),
> ('America/Thunder_Bay', 'America/Thunder_Bay'),
> ('America/Tijuana', 'America/Tijuana'),
> ('America/Toronto', 'America/Toronto'),
> ('America/Tortola', 'America/Tortola'),
> ('America/Vancouver', 'America/Vancouver'),
> ('America/Virgin', 'America/Virgin'),
> ('America/Whitehorse', 'America/Whitehorse'),
> ('America/Winnipeg', 'America/Winnipeg'),
> ('America/Yakutat', 'America/Yakutat'),
> ('America/Yellowknife', 'America/Yellowknife'),
> ('Antarctica/Casey', 'Antarctica/Casey'),
> ('Antarctica/Davis', 'Antarctica/Davis'),
> ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
> ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
> ('Antarctica/Mawson', 'Antarctica/Mawson'),
> ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
> ('Antarctica/Palmer', 'Antarctica/Palmer'),
> ('Antarctica/Rothera', 'Antarctica/Rothera'),
> ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
> ('Antarctica/Syowa', 'Antarctica/Syowa'),
> ('Antarctica/Troll', 'Antarctica/Troll'),
> ('Antarctica/Vostok', 'Antarctica/Vostok'),
> ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
> ('Asia/Aden', 'Asia/Aden'),
> ('Asia/Almaty', 'Asia/Almaty'),
> ('Asia/Amman', 'Asia/Amman'),
> ('Asia/Anadyr', 'Asia/Anadyr'),
> ('Asia/Aqtau', 'Asia/Aqtau'),
> ('Asia/Aqtobe', 'Asia/Aqtobe'),
> ('Asia/Ashgabat', 'Asia/Ashgabat'),
> ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
> ('Asia/Atyrau', 'Asia/Atyrau'),
> ('Asia/Baghdad', 'Asia/Baghdad'),
> ('Asia/Bahrain', 'Asia/Bahrain'),
> ('Asia/Baku', 'Asia/Baku'),
> ('Asia/Bangkok', 'Asia/Bangkok'),
> ('Asia/Barnaul', 'Asia/Barnaul'),
> ('Asia/Beirut', 'Asia/Beirut'),
> ('Asia/Bishkek', 'Asia/Bishkek'),
> ('Asia/Brunei', 'Asia/Brunei'),
> ('Asia/Calcutta', 'Asia/Calcutta'),
> ('Asia/Chita', 'Asia/Chita'),
> ('Asia/Choibalsan', 'Asia/Choibalsan'),
> ('Asia/Chongqing', 'Asia/Chongqing'),
> ('Asia/Chungking', 'Asia/Chungking'),
> ('Asia/Colombo', 'Asia/Colombo'),
> ('Asia/Dacca', 'Asia/Dacca'),
> ('Asia/Damascus', 'Asia/Damascus'),
> ('Asia/Dhaka', 'Asia/Dhaka'),
> ('Asia/Dili', 'Asia/Dili'),
> ('Asia/Dubai', 'Asia/Dubai'),
> ('Asia/Dushanbe', 'Asia/Dushanbe'),
> ('Asia/Famagusta', 'Asia/Famagusta'),
> ('Asia/Gaza', 'Asia/Gaza'),
> ('Asia/Harbin', 'Asia/Harbin'),
> ('Asia/Hebron', 'Asia/Hebron'),
> ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
> ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
> ('Asia/Hovd', 'Asia/Hovd'),
> ('Asia/Irkutsk', 'Asia/Irkutsk'),
> ('Asia/Istanbul', 'Asia/Istanbul'),
> ('Asia/Jakarta', 'Asia/Jakarta'),
> ('Asia/Jayapura', 'Asia/Jayapura'),
> ('Asia/Jerusalem', 'Asia/Jerusalem'),
> ('Asia/Kabul', 'Asia/Kabul'),
> ('Asia/Kamchatka', 'Asia/Kamchatka'),
> ('Asia/Karachi', 'Asia/Karachi'),
> ('Asia/Kashgar', 'Asia/Kashgar'),
> ('Asia/Kathmandu', 'Asia/Kathmandu'),
> ('Asia/Katmandu', 'Asia/Katmandu'),
> ('Asia/Khandyga', 'Asia/Khandyga'),
> ('Asia/Kolkata', 'Asia/Kolkata'),
> ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
> ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
> ('Asia/Kuching', 'Asia/Kuching'),
> ('Asia/Kuwait', 'Asia/Kuwait'),
> ('Asia/Macao', 'Asia/Macao'),
> ('Asia/Macau', 'Asia/Macau'),
> ('Asia/Magadan', 'Asia/Magadan'),
> ('Asia/Makassar', 'Asia/Makassar'),
> ('Asia/Manila', 'Asia/Manila'),
> ('Asia/Muscat', 'Asia/Muscat'),
> ('Asia/Nicosia', 'Asia/Nicosia'),
> ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
> ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
> ('Asia/Omsk', 'Asia/Omsk'),
> ('Asia/Oral', 'Asia/Oral'),
> ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
> ('Asia/Pontianak', 'Asia/Pontianak'),
> ('Asia/Pyongyang', 'Asia/Pyongyang'),
> ('Asia/Qatar', 'Asia/Qatar'),
> ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
> ('Asia/Rangoon', 'Asia/Rangoon'),
> ('Asia/Riyadh', 'Asia/Riyadh'),
> ('Asia/Saigon', 'Asia/Saigon'),
> ('Asia/Sakhalin', 'Asia/Sakhalin'),
> ('Asia/Samarkand', 'Asia/Samarkand'),
> ('Asia/Seoul', 'Asia/Seoul'),
> ('Asia/Shanghai', 'Asia/Shanghai'),
> ('Asia/Singapore', 'Asia/Singapore'),
> ('Asia/Srednekolymsk', 'Asia/Srednekolymsk'),
> ('Asia/Taipei', 'Asia/Taipei'),
> ('Asia/Tashkent', 'Asia/Tashkent'),
> ('Asia/Tbilisi', 'Asia/Tbilisi'),
> ('Asia/Tehran', 'Asia/Tehran'),
> ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
> ('Asia/Thimbu', 'Asia/Thimbu'),
> ('Asia/Thimphu', 'Asia/Thimphu'),
> ('Asia/Tokyo', 'Asia/Tokyo'),
> ('Asia/Tomsk', 'Asia/Tomsk'),
> ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
> ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
> ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
> ('Asia/Urumqi', 'Asia/Urumqi'),
> ('Asia/Ust-Nera', 'Asia/Ust-Nera'),
> ('Asia/Vientiane', 'Asia/Vientiane'),
> ('Asia/Vladivostok', 'Asia/Vladivostok'),
> ('Asia/Yakutsk', 'Asia/Yakutsk'),
> ('Asia/Yangon', 'Asia/Yangon'),
> ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
> ('Asia/Yerevan', 'Asia/Yerevan'),
> ('Atlantic/Azores', 'Atlantic/Azores'),
> ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
> ('Atlantic/Canary', 'Atlantic/Canary'),
> ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
> ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
> ('Atlantic/Faroe', 'Atlantic/Faroe'),
> ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
> ('Atlantic/Madeira', 'Atlantic/Madeira'),
> ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
> ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
> ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
> ('Atlantic/Stanley', 'Atlantic/Stanley'),
> ('Australia/ACT', 'Australia/ACT'),
> ('Australia/Adelaide', 'Australia/Adelaide'),
> ('Australia/Brisbane', 'Australia/Brisbane'),
> ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
> ('Australia/Canberra', 'Australia/Canberra'),
> ('Australia/Currie', 'Australia/Currie'),
> ('Australia/Darwin', 'Australia/Darwin'),
> ('Australia/Eucla', 'Australia/Eucla'),
> ('Australia/Hobart', 'Australia/Hobart'),
> ('Australia/LHI', 'Australia/LHI'),
> ('Australia/Lindeman', 'Australia/Lindeman'),
> ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
> ('Australia/Melbourne', 'Australia/Melbourne'),
> ('Australia/NSW', 'Australia/NSW'),
> ('Australia/North', 'Australia/North'),
> ('Australia/Perth', 'Australia/Perth'),
> ('Australia/Queensland', 'Australia/Queensland'),
> ('Australia/South', 'Australia/South'),
> ('Australia/Sydney', 'Australia/Sydney'),
> ('Australia/Tasmania', 'Australia/Tasmania'),
> ('Australia/Victoria', 'Australia/Victoria'),
> ('Australia/West', 'Australia/West'),
> ('Australia/Yancowinna', 'Australia/Yancowinna'),
> ('Brazil/Acre', 'Brazil/Acre'),
> ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
> ('Brazil/East', 'Brazil/East'),
> ('Brazil/West', 'Brazil/West'),
> ('CET', 'CET'),
> ('CST6CDT', 'CST6CDT'),
> ('Canada/Atlantic', 'Canada/Atlantic'),
> ('Canada/Central', 'Canada/Central'),
> ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
> ('Canada/Eastern', 'Canada/Eastern'),
> ('Canada/Mountain', 'Canada/Mountain'),
> ('Canada/Newfoundland', 'Canada/Newfoundland'),
> ('Canada/Pacific', 'Canada/Pacific'),
> ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
> ('Canada/Yukon', 'Canada/Yukon'),
> ('Chile/Continental', 'Chile/Continental'),
> ('Chile/EasterIsland', 'Chile/EasterIsland'),
> ('Cuba', 'Cuba'),
> ('EET', 'EET'),
> ('EST', 'EST'),
> ('EST5EDT', 'EST5EDT'),
> ('Egypt', 'Egypt'),
> ('Eire', 'Eire'),
> ('Etc/GMT', 'Etc/GMT'),
> ('Etc/GMT+0', 'Etc/GMT+0'),
> ('Etc/GMT+1', 'Etc/GMT+1'),
> ('Etc/GMT+10', 'Etc/GMT+10'),
> ('Etc/GMT+11', 'Etc/GMT+11'),
> ('Etc/GMT+12', 'Etc/GMT+12'),
> ('Etc/GMT+2', 'Etc/GMT+2'),
> ('Etc/GMT+3', 'Etc/GMT+3'),
> ('Etc/GMT+4', 'Etc/GMT+4'),
> ('Etc/GMT+5', 'Etc/GMT+5'),
> ('Etc/GMT+6', 'Etc/GMT+6'),
> ('Etc/GMT+7', 'Etc/GMT+7'),
> ('Etc/GMT+8', 'Etc/GMT+8'),
> ('Etc/GMT+9', 'Etc/GMT+9'),
> ('Etc/GMT-0', 'Etc/GMT-0'),
> ('Etc/GMT-1', 'Etc/GMT-1'),
> ('Etc/GMT-10', 'Etc/GMT-10'),
> ('Etc/GMT-11', 'Etc/GMT-11'),
> ('Etc/GMT-12', 'Etc/GMT-12'),
> ('Etc/GMT-13', 'Etc/GMT-13'),
> ('Etc/GMT-14', 'Etc/GMT-14'),
> ('Etc/GMT-2', 'Etc/GMT-2'),
> ('Etc/GMT-3', 'Etc/GMT-3'),
> ('Etc/GMT-4', 'Etc/GMT-4'),
> ('Etc/GMT-5', 'Etc/GMT-5'),
> ('Etc/GMT-6', 'Etc/GMT-6'),
> ('Etc/GMT-7', 'Etc/GMT-7'),
> ('Etc/GMT-8', 'Etc/GMT-8'),
> ('Etc/GMT-9', 'Etc/GMT-9'),
> ('Etc/GMT0', 'Etc/GMT0'),
> ('Etc/Greenwich', 'Etc/Greenwich'),
> ('Etc/UCT', 'Etc/UCT'),
> ('Etc/UTC', 'Etc/UTC'),
> ('Etc/Universal', 'Etc/Universal'),
> ('Etc/Zulu', 'Etc/Zulu'),
> ('Europe/Amsterdam', 'Europe/Amsterdam'),
> ('Europe/Andorra', 'Europe/Andorra'),
> ('Europe/Astrakhan', 'Europe/Astrakhan'),
> ('Europe/Athens', 'Europe/Athens'),
> ('Europe/Belfast', 'Europe/Belfast'),
> ('Europe/Belgrade', 'Europe/Belgrade'),
> ('Europe/Berlin', 'Europe/Berlin'),
> ('Europe/Bratislava', 'Europe/Bratislava'),
> ('Europe/Brussels', 'Europe/Brussels'),
> ('Europe/Bucharest', 'Europe/Bucharest'),
> ('Europe/Budapest', 'Europe/Budapest'),
> ('Europe/Busingen', 'Europe/Busingen'),
> ('Europe/Chisinau', 'Europe/Chisinau'),
> ('Europe/Copenhagen', 'Europe/Copenhagen'),
> ('Europe/Dublin', 'Europe/Dublin'),
> ('Europe/Gibraltar', 'Europe/Gibraltar'),
> ('Europe/Guernsey', 'Europe/Guernsey'),
> ('Europe/Helsinki', 'Europe/Helsinki'),
> ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
> ('Europe/Istanbul', 'Europe/Istanbul'),
> ('Europe/Jersey', 'Europe/Jersey'),
> ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
> ('Europe/Kiev', 'Europe/Kiev'),
> ('Europe/Kirov', 'Europe/Kirov'),
> ('Europe/Lisbon', 'Europe/Lisbon'),
> ('Europe/Ljubljana', 'Europe/Ljubljana'),
> ('Europe/London', 'Europe/London'),
> ('Europe/Luxembourg', 'Europe/Luxembourg'),
> ('Europe/Madrid', 'Europe/Madrid'),
> ('Europe/Malta', 'Europe/Malta'),
> ('Europe/Mariehamn', 'Europe/Mariehamn'),
> ('Europe/Minsk', 'Europe/Minsk'),
> ('Europe/Monaco', 'Europe/Monaco'),
> ('Europe/Moscow', 'Europe/Moscow'),
> ('Europe/Nicosia', 'Europe/Nicosia'),
> ('Europe/Oslo', 'Europe/Oslo'),
> ('Europe/Paris', 'Europe/Paris'),
> ('Europe/Podgorica', 'Europe/Podgorica'),
> ('Europe/Prague', 'Europe/Prague'),
> ('Europe/Riga', 'Europe/Riga'),
> ('Europe/Rome', 'Europe/Rome'),
> ('Europe/Samara', 'Europe/Samara'),
> ('Europe/San_Marino', 'Europe/San_Marino'),
> ('Europe/Sarajevo', 'Europe/Sarajevo'),
> ('Europe/Saratov', 'Europe/Saratov'),
> ('Europe/Simferopol', 'Europe/Simferopol'),
> ('Europe/Skopje', 'Europe/Skopje'),
> ('Europe/Sofia', 'Europe/Sofia'),
> ('Europe/Stockholm', 'Europe/Stockholm'),
> ('Europe/Tallinn', 'Europe/Tallinn'),
> ('Europe/Tirane', 'Europe/Tirane'),
> ('Europe/Tiraspol', 'Europe/Tiraspol'),
> ('Europe/Ulyanovsk', 'Europe/Ulyanovsk'),
> ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
> ('Europe/Vaduz', 'Europe/Vaduz'),
> ('Europe/Vatican', 'Europe/Vatican'),
> ('Europe/Vienna', 'Europe/Vienna'),
> ('Europe/Vilnius', 'Europe/Vilnius'),
> ('Europe/Volgograd', 'Europe/Volgograd'),
> ('Europe/Warsaw', 'Europe/Warsaw'),
> ('Europe/Zagreb', 'Europe/Zagreb'),
> ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
> ('Europe/Zurich', 'Europe/Zurich'),
> ('GB', 'GB'),
> ('GB-Eire', 'GB-Eire'),
> ('GMT', 'GMT'),
> ('GMT+0', 'GMT+0'),
> ('GMT-0', 'GMT-0'),
> ('GMT0', 'GMT0'),
> ('Greenwich', 'Greenwich'),
> ('HST', 'HST'),
> ('Hongkong', 'Hongkong'),
> ('Iceland', 'Iceland'),
> ('Indian/Antananarivo', 'Indian/Antananarivo'),
> ('Indian/Chagos', 'Indian/Chagos'),
> ('Indian/Christmas', 'Indian/Christmas'),
> ('Indian/Cocos', 'Indian/Cocos'),
> ('Indian/Comoro', 'Indian/Comoro'),
> ('Indian/Kerguelen', 'Indian/Kerguelen'),
> ('Indian/Mahe', 'Indian/Mahe'),
> ('Indian/Maldives', 'Indian/Maldives'),
> ('Indian/Mauritius', 'Indian/Mauritius'),
> ('Indian/Mayotte', 'Indian/Mayotte'),
> ('Indian/Reunion', 'Indian/Reunion'),
> ('Iran', 'Iran'),
> ('Israel', 'Israel'),
> ('Jamaica', 'Jamaica'),
> ('Japan', 'Japan'),
> ('Kwajalein', 'Kwajalein'),
> ('Libya', 'Libya'),
> ('MET', 'MET'),
> ('MST', 'MST'),
> ('MST7MDT', 'MST7MDT'),
> ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
> ('Mexico/BajaSur', 'Mexico/BajaSur'),
> ('Mexico/General', 'Mexico/General'),
> ('NZ', 'NZ'),
> ('NZ-CHAT', 'NZ-CHAT'),
> ('Navajo', 'Navajo'),
> ('PRC', 'PRC'),
> ('PST8PDT', 'PST8PDT'),
> ('Pacific/Apia', 'Pacific/Apia'),
> ('Pacific/Auckland', 'Pacific/Auckland'),
> ('Pacific/Bougainville', 'Pacific/Bougainville'),
> ('Pacific/Chatham', 'Pacific/Chatham'),
> ('Pacific/Chuuk', 'Pacific/Chuuk'),
> ('Pacific/Easter', 'Pacific/Easter'),
> ('Pacific/Efate', 'Pacific/Efate'),
> ('Pacific/Enderbury', 'Pacific/Enderbury'),
> ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
> ('Pacific/Fiji', 'Pacific/Fiji'),
> ('Pacific/Funafuti', 'Pacific/Funafuti'),
> ('Pacific/Galapagos', 'Pacific/Galapagos'),
> ('Pacific/Gambier', 'Pacific/Gambier'),
> ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
> ('Pacific/Guam', 'Pacific/Guam'),
> ('Pacific/Honolulu', 'Pacific/Honolulu'),
> ('Pacific/Johnston', 'Pacific/Johnston'),
> ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
> ('Pacific/Kosrae', 'Pacific/Kosrae'),
> ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
> ('Pacific/Majuro', 'Pacific/Majuro'),
> ('Pacific/Marquesas', 'Pacific/Marquesas'),
> ('Pacific/Midway', 'Pacific/Midway'),
> ('Pacific/Nauru', 'Pacific/Nauru'),
> ('Pacific/Niue', 'Pacific/Niue'),
> ('Pacific/Norfolk', 'Pacific/Norfolk'),
> ('Pacific/Noumea', 'Pacific/Noumea'),
> ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
> ('Pacific/Palau', 'Pacific/Palau'),
> ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
> ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
> ('Pacific/Ponape', 'Pacific/Ponape'),
> ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
> ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
> ('Pacific/Saipan', 'Pacific/Saipan'),
> ('Pacific/Samoa', 'Pacific/Samoa'),
> ('Pacific/Tahiti', 'Pacific/Tahiti'),
> ('Pacific/Tarawa', 'Pacific/Tarawa'),
> ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
> ('Pacific/Truk', 'Pacific/Truk'),
> ('Pacific/Wake', 'Pacific/Wake'),
> ('Pacific/Wallis', 'Pacific/Wallis'),
> ('Pacific/Yap', 'Pacific/Yap'),
> ('Poland', 'Poland'),
> ('Portugal', 'Portugal'),
> ('ROC', 'ROC'),
> ('ROK', 'ROK'),
> ('Singapore', 'Singapore'),
> ('Turkey', 'Turkey'),
> ('UCT', 'UCT'),
> ('US/Alaska', 'US/Alaska'),
> ('US/Aleutian', 'US/Aleutian'),
> ('US/Arizona', 'US/Arizona'),
> ('US/Central', 'US/Central'),
> ('US/East-Indiana', 'US/East-Indiana'),
> ('US/Eastern', 'US/Eastern'),
> ('US/Hawaii', 'US/Hawaii'),
> ('US/Indiana-Starke', 'US/Indiana-Starke'),
> ('US/Michigan', 'US/Michigan'),
> ('US/Mountain', 'US/Mountain'),
> ('US/Pacific', 'US/Pacific'),
> ('US/Pacific-New', 'US/Pacific-New'),
> ('US/Samoa', 'US/Samoa'),
> ('UTC', 'UTC'),
> ('Universal', 'Universal'),
> ('W-SU', 'W-SU'),
> ('WET', 'WET'),
> ('Zulu', 'Zulu')]
> FILE_UPLOAD_HANDLERS
> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
> 'django.core.files.uploadhandler.TemporaryFileUploadHandler')
> DEFAULT_CONTENT_TYPE
> 'text/html'
> DEBUG_STATIC
> 0
> ACCOUNT_APPROVAL_REQUIRED
> 0
> BING_API_KEY
> DATABASE_URL
> 'sqlite:///C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\development.db'
> APPEND_SLASH
> True
> FIRST_DAY_OF_WEEK
> 0
> DATABASE_ROUTERS
> DEFAULT_TABLESPACE
> STAMEN_BASEMAPS
> False
> GEOSERVER_LOCATION
> YEAR_MONTH_FORMAT
> 'F Y'
> STATICFILES_STORAGE
> 'django.contrib.staticfiles.storage.StaticFilesStorage'
> CACHES
> {'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
> 1
> CKAN_ORIGINS
> [{'css_class': 'hdx',
>   'label': 'Humanitarian Data Exchange (HDX)',
>   'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&
> dataset_date={date}&notes={abstract}&caveats={caveats}'}]
> SLACK_WEBHOOK_URLS
> ['https://hooks.slack.com/services/T000/B000/XX']
> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
> 0
> SESSION_COOKIE_PATH
> ALT_OSM_BASEMAPS
> False
> USE_X_FORWARDED_HOST
> False
> ACCOUNT_OPEN_SIGNUP
> True
> ROOT_URLCONF
> 'geonode.urls'
> CATALOGUE
> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
>              'URL': 'http://localhost:8000/catalogue/csw'}}
> MAPBOX_ACCESS_TOKEN
> MISSING_THUMBNAIL
> 'geonode/img/missing_thumb.png'
> FILE_UPLOAD_TEMP_DIR
> None
> MIDDLEWARE_CLASSES
> ('django.middleware.common.CommonMiddleware',
> 'django.contrib.sessions.middleware.SessionMiddleware',
> 'django.contrib.messages.middleware.MessageMiddleware',
> 'django.middleware.locale.LocaleMiddleware',
> 'pagination.middleware.PaginationMiddleware',
> 'django.middleware.csrf.CsrfViewMiddleware',
> 'django.contrib.auth.middleware.AuthenticationMiddleware',
> 'django.middleware.clickjacking.XFrameOptionsMiddleware',
> 'django.contrib.auth.middleware.SessionAuthenticationMiddleware',
> 'oauth2_provider.middleware.OAuth2TokenMiddleware')
> USE_I18N
> 1
> THOUSAND_SEPARATOR
> SECRET_KEY
> MODELTRANSLATION_FALLBACK_LANGUAGES
> ('en',)
> LANGUAGE_COOKIE_NAME
> 'django_language'
> OGC_SERVER
> {'default': {'BACKEND': 'geonode.geoserver',
>              'BACKEND_WRITE_ENABLED': True,
>              'DATASTORE': 'datastore',
>              'GEOGIG_DATASTORE_DIR': '',
>              'GEONODE_SECURITY_ENABLED': True,
>              'LOCATION': 'http://localhost:8080/geoserver/',
>              'LOG_FILE': 'C:\\GeoNode-2.6.x\\geonode-2.
> 6.x/geoserver/data/logs/geoserver.log',
>              'MAPFISH_PRINT_ENABLED': True,
>              'PRINT_NG_ENABLED': True,
>              'PUBLIC_LOCATION': 'http://*********/geoserver/',
>              'TIMEOUT': 10,
>              'USER': 'admin',
>              'WMST_ENABLED': False,
>              'WPS_ENABLED': False}}
> ACCOUNT_REMEMBER_ME_EXPIRY
> 315360000
> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
> DEFAULT_MAP_CRS
> 'EPSG:900913'
> EMAIL_USE_SSL
> False
> ACCOUNT_EMAIL_UNIQUE
> True
> THESAURI
> LOGGING_CONFIG
> 'logging.config.dictConfig'
> _DEFAULT_LANGUAGES
> (('en', 'English'),
> ('es', 'Espa\xc3\xb1ol'),
> ('it', 'Italiano'),
> ('fr', 'Fran\xc3\xa7ais'),
> ('de', 'Deutsch'),
> ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\
> xce\xac'),
> ('id', 'Bahasa Indonesia'),
> ('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
> ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
> ('fa', 'Persian'),
> ('ar', 'Arabic'),
> ('bn', 'Bengali'),
> ('ne', 'Nepali'),
> ('sq', 'Albanian'),
> ('af', 'Afrikaans'),
> ('sw', 'Swahili'),
> ('pt', 'Portuguese'),
> ('pt-br', 'Portuguese (Brazil)'),
> ('ru', 'Russian'),
> ('vi', 'Vietnamese'),
> ('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
> ('am', 'Amharic'),
> ('km', 'Khmer'),
> ('pl', 'Polish'),
> ('sv', 'Swedish'),
> ('th', '\xe0\xb9\x84\xe0\xb8\x97\xe0\xb8\xa2'),
> ('uk', 'Ukranian'),
> ('si', 'Sinhala'),
> ('ta', 'Tamil'),
> ('tl', 'Tagalog'))
> TEMPLATE_LOADERS
> ('django.template.loaders.filesystem.Loader',
> 'django.template.loaders.app_directories.Loader')
> GEOS_LIBRARY_PATH
> 'C:\\GeoNode-2.6.x\\GDAL\\geos_c.dll'
> TASTYPIE_DEFAULT_FORMATS
> ['json']
> TEMPLATE_DEBUG
> False
> AUTO_GENERATE_AVATAR_SIZES
> (20, 30, 32, 40, 50, 65, 70, 80, 100, 140, 200, 240)
> CSRF_COOKIE_NAME
> 'csrftoken'
> THEME_ACCOUNT_CONTACT_EMAIL
> 'admin at example.com'
> 'default'
> OAUTH2_PROVIDER
> {'CLIENT_ID_GENERATOR_CLASS': 'oauth2_provider.generators.
> ClientIdGenerator',
> 'SCOPES': {'groups': 'Access to your groups',
>             'read': 'Read scope',
>             'write': 'Write scope'}}
> CELERY_DEFAULT_ROUTING_KEY
> ACCOUNT_LOGIN_REDIRECT_URL
> u'/'
> TWITTER_HASHTAGS
> ['geonode']
> CELERY_ALWAYS_EAGER
> True
> EMAIL_TIMEOUT
> None
> MODIFY_TOPICCATEGORY
> 0
> SIGNING_BACKEND
> 'django.core.signing.TimestampSigner'
> SESSION_COOKIE_SECURE
> False
> NLP_ENABLED
> False
> ACCOUNT_LOGIN_URL
> u'account_login'
> MESSAGE_STORAGE
> 'django.contrib.messages.storage.fallback.FallbackStorage'
> CACHE_TIME
> 0
> SECURE_BROWSER_XSS_FILTER
> False
> PYCSW
> {'CONFIGURATION': {'metadata:inspire': {'conformity_service':
> 'notEvaluated',
>                                         'contact_email': 'Email Address',
>                                         'contact_name': 'Organization
> Name',
>                                         'date': 'YYYY-MM-DD',
>                                         'default_language': 'eng',
>                                         'enabled': 'true',
>                                         'gemet_keywords': 'Utility and
> governmental services',
>                                         'languages_supported': 'eng,gre',
>                                         'temp_extent':
> 'YYYY-MM-DD/YYYY-MM-DD'},
>                    'metadata:main': {'contact_address': 'Mailing Address',
>                                      'contact_city': 'City',
>                                      'contact_country': 'Country',
>                                      'contact_fax': '+xx-xxx-xxx-xxxx',
>                                      'contact_hours': 'Hours of Service',
>                                      'contact_instructions': 'During
> hours of service. Off on weekends.',
>                                      'contact_name': 'Lastname,
> Firstname',
>                                      'contact_phone': '+xx-xxx-xxx-xxxx',
>                                      'contact_position': 'Position Title',
>                                      'contact_postalcode': 'Zip or Postal
> Code',
>                                      'contact_role': 'pointOfContact',
>                                      'contact_stateorprovince':
> 'Administrative Area',
>                                      'contact_url': 'Contact URL',
>                                      'identification_abstract': 'GeoNode
> is an open source platform that facilitates the creation, sharing, and
> collaborative use of geospatial data',
>                                      'identification_accessconstraints':
> 'None',
>                                      'identification_fees': 'None',
>                                      'identification_keywords': 'sdi,
> catalogue, discovery, metadata, GeoNode',
>                                      'identification_keywords_type':
> 'theme',
>                                      'identification_title': 'GeoNode
> Catalogue',
>                                      'provider_name': 'Organization Name',
>                                      'provider_url': '
> http://localhost:8000/'}}}
> CSRF_COOKIE_DOMAIN
> None
> FILE_CHARSET
> 'utf-8'
> DEBUG
> 1
> SECURE_SSL_REDIRECT
> False
> LANGUAGE_COOKIE_DOMAIN
> None
> AWS_ACCESS_KEY_ID
> DEFAULT_FILE_STORAGE
> 'django.core.files.storage.FileSystemStorage'
> INSTALLED_APPS
> ('modeltranslation',
> 'django.contrib.auth',
> 'django.contrib.contenttypes',
> 'django.contrib.sessions',
> 'django.contrib.sites',
> 'django.contrib.admin',
> 'django.contrib.sitemaps',
> 'django.contrib.staticfiles',
> 'django.contrib.messages',
> 'django.contrib.humanize',
> 'django.contrib.gis',
> 'pagination',
> 'taggit',
> 'treebeard',
> 'friendlytagloader',
> 'geoexplorer',
> 'leaflet',
> 'django_extensions',
> 'autocomplete_light',
> 'mptt',
> 'djcelery',
> 'storages',
> 'pinax_theme_bootstrap_account',
> 'pinax_theme_bootstrap',
> 'django_forms_bootstrap',
> 'account',
> 'avatar',
> 'dialogos',
> 'agon_ratings',
> 'announcements',
> 'actstream',
> 'user_messages',
> 'tastypie',
> 'polymorphic',
> 'guardian',
> 'oauth2_provider',
> 'geonode.people',
> 'geonode.base',
> 'geonode.layers',
> 'geonode.maps',
> 'geonode.proxy',
> 'geonode.security',
> 'geonode.social',
> 'geonode.catalogue',
> 'geonode.documents',
> 'geonode.api',
> 'geonode.groups',
> 'geonode.services',
> 'geonode.upload',
> 'geonode.tasks')
> LANGUAGES_BIDI
> ('he', 'ar', 'fa', 'ur')
> USE_L10N
> 1
> SITEURL
> 'http://*********/'
> STATIC_ROOT
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\static_root'
> SECURE_HSTS_INCLUDE_SUBDOMAINS
> False
> GEONODE_APPS
> ('geonode.people',
> 'geonode.base',
> 'geonode.layers',
> 'geonode.maps',
> 'geonode.proxy',
> 'geonode.security',
> 'geonode.social',
> 'geonode.api',
> 'geonode.groups',
> 'geonode.services',
> 'geonode.upload',
> 'geonode.tasks')
> LEAFLET_CONFIG
> {'PLUGINS': {u'ALL': {u'css': <leaflet.utils.ListWithLazyItems object at
> 0x0A9583F0>,
>                       u'js': <leaflet.utils.ListWithLazyItems object at
> 0x0C2AA6B0>},
>              u'__default__': {u'css': <leaflet.utils.ListWithLazyItems
> object at 0x0C2AA710>,
> object at 0x0C2AA790>},
>              u'__is_normalized__': True,
>              'esri-leaflet': {'auto-include': True,
> object at 0x0C2AA7B0>,
> object at 0x0C2AA7D0>},
>              u'forms': {u'auto-include': False,
> at 0x0C2AA550>,
> 0x0A9584D0>},
>              'leaflet-fullscreen': {'auto-include': True,
> object at 0x0C2AA6D0>,
> object at 0x0C2AA730>}},
> 'RESET_VIEW': False,
> 'SRID': 3857,
> 'TILES': [('Watercolor',
>             'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png
> <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>             'Map tiles by <a href="http://stamen.com">Stamen
> Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC
> BY 3.0</a>          — Map data ©          <a href="
> http://openstreetmap.org">OpenStreetMap</a> contributors,          <a
> href="http://creativecommons.org/licenses/by-sa/2.0/">
> CC-BY-SA</a>'),
>            ('Toner Lite',
>             'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png
> <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
> CC-BY-SA</a>')]}
> DOWNLOAD_FORMATS_VECTOR
> ['JPEG',
> 'PDF',
> 'PNG',
> 'Zipped Shapefile',
> 'GML 2.0',
> 'GML 3.1.1',
> 'CSV',
> 'Excel',
> 'GeoJSON',
> 'KML',
> 'Tiles']
> PREPEND_WWW
> False
> SECURE_PROXY_SSL_HEADER
> None
> AUTH_IP_WHITELIST
> TWITTER_CARD
> True
> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
> LANGUAGE_COOKIE_AGE
> None
> SESSION_COOKIE_HTTPONLY
> True
> AWS_SECRET_ACCESS_KEY
> DEBUG_PROPAGATE_EXCEPTIONS
> False
> INTERNAL_IPS
> DEFAULT_ANONYMOUS_VIEW_PERMISSION
> 1
> _DEFAULT_SECRET_KEY
> MONTH_DAY_FORMAT
> 'F j'
> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
> u'account_login'
> LOGIN_URL
> '/account/login/'
> SESSION_EXPIRE_AT_BROWSER_CLOSE
> False
> SEARCH_FILTERS
> {'CATEGORIES_ENABLED': True,
> 'DATE_ENABLED': True,
> 'EXTENT_ENABLED': True,
> 'H_KEYWORDS_ENABLED': u'********************',
> 'KEYWORDS_ENABLED': u'********************',
> 'OWNERS_ENABLED': True,
> 'REGION_ENABLED': True,
> 'TEXT_ENABLED': True,
> 'TYPE_ENABLED': True,
> 'T_KEYWORDS_ENABLED': u'********************'}
> OPENGRAPH_ENABLED
> True
> OGP_URL
> 'http://geodata.tufts.edu/solr/select'
> CELERY_EAGER_PROPAGATES_EXCEPTIONS
> True
> TIME_FORMAT
> 'P'
> CELERY_IGNORE_RESULT
> True
> SERVICE_UPDATE_INTERVAL
> 0
> AUTH_USER_MODEL
> 'people.Profile'
> DATE_INPUT_FORMATS
> ('%Y-%m-%d',
> '%m/%d/%Y',
> '%m/%d/%y',
> '%b %d %Y',
> '%b %d, %Y',
> '%d %b %Y',
> '%d %b, %Y',
> '%B %d %Y',
> '%B %d, %Y',
> '%d %B %Y',
> '%d %B, %Y')
> ACCOUNT_LOGOUT_REDIRECT_URL
> u'/'
> SESSION_SERIALIZER
> 'django.contrib.sessions.serializers.PickleSerializer'
> HAYSTACK_SEARCH
> False
> AUTHENTICATION_BACKENDS
> ('oauth2_provider.backends.OAuth2Backend',
> 'django.contrib.auth.backends.ModelBackend',
> 'guardian.backends.ObjectPermissionBackend')
> EMAIL_HOST_PASSWORD
> CELERY_DISABLE_RATE_LIMITS
> True
> PASSWORD_RESET_TIMEOUT_DAYS
> SESSION_FILE_PATH
> None
> CACHE_MIDDLEWARE_ALIAS
> 'default'
> SESSION_SAVE_EVERY_REQUEST
> False
> NUMBER_GROUPING
> 0
> SHORT_DATETIME_FORMAT
> 'm/d/Y P'
> SESSION_ENGINE
> 'django.contrib.sessions.backends.db'
> CELERY_RESULT_BACKEND
> None
> ACCOUNT_DELETION_MARK_CALLBACK
> <function account_delete_mark at 0x09C1CD70>
> CSRF_COOKIE_PATH
> LOGIN_REDIRECT_URL
> '/accounts/profile/'
> TEMPLATE_STRING_IF_INVALID
> NLP_LIBRARY_PATH
> '/opt/MITIE/mitielib'
> ACCOUNT_DELETION_EXPUNGE_HOURS
> 48
> PROJECT_ROOT
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode'
> DECIMAL_SEPARATOR
> API_INCLUDE_REGIONS_COUNT
> CELERY_SEND_EVENTS
> False
> EXIF_ENABLED
> True
> NOSE_ARGS
> ['--nocapture', '--detailed-errors']
> LOCALE_PATHS
> NLP_MODEL_PATH
> '/opt/MITIE/MITIE-models/english/ner_model.dat'
> PASSWORD_HASHERS
> PROXY_ALLOWED_HOSTS
> LOCAL_MEDIA_URL
> '/uploaded/'
> CARTODB_BASEMAPS
> False
> SOCIAL_ORIGINS
> [{'css_class': 'email',
>   'label': 'Email',
>   'url': 'mailto:?subject={name}&body={url}'},
> {'css_class': 'fb',
>   'label': 'Facebook',
>   'url': 'http://www.facebook.com/sharer.php?u={url}'},
> {'css_class': 'tw',
>   'label': 'Twitter',
>   'url': 'https://twitter.com/share?url={url}&hashtags={hashtags}'},
> {'css_class': 'gp',
>   'label': 'Google +',
>   'url': 'https://plus.google.com/share?url={url}'}]
> LOGOUT_URL
> '/account/logout/'
> MAP_BASELAYERS
> [{'source': {'ptype': 'gxp_wmscsource',
>              'restUrl': '/gs/rest',
>              'title': 'Local Geoserver',
>              'url': 'http://*********/geoserver/wms'}},
> {'args': ['No background'],
>   'fixed': True,
>   'group': 'background',
>   'name': 'background',
>   'source': {'ptype': 'gxp_olsource'},
>   'type': 'OpenLayers.Layer',
>   'visibility': False},
> {'attribution': "© <a href='http://osm.org/copyright'>OpenStreetMap</a>
> contributors",
>   'fixed': True,
>   'name': 'mapnik',
>   'source': {'ptype': 'gxp_osmsource'},
>   'title': 'OpenStreetMap',
>   'type': 'OpenLayers.Layer.OSM',
>   'visibility': True}]
> EMAIL_USE_TLS
> False
> ACCOUNT_LANGUAGES
> [('en', u'English'),
> ('es', u'espa\xf1ol'),
> ('it', u'italiano'),
> ('fr', u'fran\xe7ais'),
> ('de', u'Deutsch'),
> ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
> ('id', u'Bahasa Indonesia'),
> ('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
> ('ja', u'\u65e5\u672c\u8a9e'),
> ('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
> ('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
> ('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
> ('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
> ('sq', u'shqip'),
> ('af', u'Afrikaans'),
> ('sw', u'Kiswahili'),
> ('pt', u'Portugu\xeas'),
> ('pt-br', u'Portugu\xeas Brasileiro'),
> ('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
> ('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
> ('ko', u'\ud55c\uad6d\uc5b4'),
> ('am', 'Amharic'),
> ('km', u'Khmer'),
> ('pl', u'polski'),
> ('sv', u'svenska'),
> ('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
> ('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
> ('si', 'sinhala'),
> ('ta', u'tamil'),
> ('tl', 'tagalog')]
> FIXTURE_DIRS
> ABSOLUTE_URL_OVERRIDES
> DATE_FORMAT
> 'N j, Y'
> NLP_LOCATION_THRESHOLD
> 1.0
> CSRF_FAILURE_VIEW
> 'django.views.csrf.csrf_failure'
> SKIP_PERMS_FILTER
> False
> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
> MEDIA_ROOT
> 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\uploaded'
> AGON_RATINGS_CATEGORY_CHOICES
> {'documents.Document': {'document': 'How good is this document?'},
> 'layers.Layer': {'layer': 'How good is this layer?'},
> 'maps.Map': {'map': 'How good is this map?'}}
> SECURE_CONTENT_TYPE_NOSNIFF
> False
> DEFAULT_EXCEPTION_REPORTER_FILTER
> 'django.views.debug.SafeExceptionReporterFilter'
> ADMINS
> FORMAT_MODULE_PATH
> None
> DEFAULT_FROM_EMAIL
> 'webmaster at localhost'
> STATICFILES_DIRS
> ['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\static']
> MEDIA_URL
> '/uploaded/'
> DATETIME_FORMAT
> 'N j, Y, P'
> TEMPLATE_DIRS
> ALLOWED_DOCUMENT_TYPES
> ['doc',
> 'docx',
> 'gif',
> 'jpg',
> 'jpeg',
> 'ods',
> 'odt',
> 'odp',
> 'pdf',
> 'png',
> 'ppt',
> 'pptx',
> 'rar',
> 'sld',
> 'tif',
> 'tiff',
> 'txt',
> 'xls',
> 'xlsx',
> 'xml',
> 'zip',
> 'gz',
> 'qml']
> NOTIFICATION_LANGUAGE_MODULE
> 'account.Account'
> ACCOUNT_DELETION_EXPUNGE_CALLBACK
> <function account_delete_expunge at 0x09C1CD30>
> RESOURCE_PUBLISHING
> False
> ACCOUNT_HOOKSET
> <account.hooks.AccountDefaultHookSet object at 0x09C1B750>
> PROXY_URL
> '/proxy/?url='
> SITE_ID
> 1
> DISALLOWED_USER_AGENTS
> ALLOWED_INCLUDE_ROOTS
> API_LIMIT_PER_PAGE
> THUNDERFOREST_BASEMAPS
> False
> ACCOUNT_SETTINGS_REDIRECT_URL
> u'account_settings'
> USE_THOUSAND_SEPARATOR
> False
> EXTRA_LANG_INFO
> {'am': {'bidi': False,
>         'code': 'am',
>         'name': 'Amharic',
>         'name_local': 'Amharic'},
> 'si': {'bidi': False,
>         'code': 'si',
>         'name': 'Sinhala',
>         'name_local': 'sinhala'},
> 'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local':
> u'tamil'},
> 'tl': {'bidi': False,
>         'code': 'tl',
>         'name': 'Tagalog',
>         'name_local': 'tagalog'}}
> SRID
> {'DETAIL': 'never'}
> LOGGING
> {'disable_existing_loggers': True,
> 'filters': {'require_debug_false': {'()': 'django.utils.log.
> RequireDebugFalse'}},
> 'formatters': {'simple': {'format': '%(message)s'},
>                 'verbose': {'format': '%(levelname)s %(asctime)s
> %(module)s %(process)d %(thread)d %(message)s'}},
> 'handlers': {'console': {'class': 'logging.StreamHandler',
>                           'formatter': 'simple',
>                           'level': 'ERROR'},
>               'mail_admins': {'class': 'django.utils.log.
> AdminEmailHandler',
>                               'filters': ['require_debug_false'],
>                               'level': 'ERROR'},
>               'null': {'class': 'django.utils.log.NullHandler',
>                        'level': 'ERROR'}},
> 'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
>              'geonode': {'handlers': ['console'], 'level': 'ERROR'},
>              'gsconfig.catalog': {'handlers': ['console'], 'level':
> 'ERROR'},
>              'owslib': {'handlers': ['console'], 'level': 'ERROR'},
>              'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
> 'version': 1}
> _DEFAULT_STATICFILES_DIRS
> SHORT_DATE_FORMAT
> 'm/d/Y'
> TWITTER_SITE
> '@GeoNode'
> SLACK_ENABLED
> False
> TEMPLATES
> [{'APP_DIRS': True,
>   'BACKEND': 'django.template.backends.django.DjangoTemplates',
>   'DIRS': ['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\templates'],
>   'NAME': 'GeoNode Project Templates',
>   'OPTIONS': {'context_processors': ['django.contrib.auth.context_
> processors.auth',
>                                      'django.core.context_
> processors.debug',
> processors.i18n',
>                                      'django.core.context_processors.tz',
> processors.media',
> processors.static',
> processors.request',
> context_processors.messages',
>                                      'account.context_processors.account',
>                                      'geonode.context_processors.
> resource_urls',
>                                      'geonode.geoserver.context_
> processors.geoserver_urls'],
>               'debug': 1}}]
> TEST_RUNNER
> 'django_nose.NoseTestSuiteRunner'
> ACTSTREAM_SETTINGS
> {'FETCH_RELATIONS': True,
> 'GFK_FETCH_DEPTH': 1,
> 'USE_JSONFIELD': True,
> 'USE_PREFETCH': False}
> MODELTRANSLATION_LANGUAGES
> ['en']
> HAYSTACK_FACET_COUNTS
> False
> CACHE_MIDDLEWARE_KEY_PREFIX
> AWS_S3_BUCKET_DOMAIN
> '.s3.amazonaws.com'
> TIME_ZONE
> 'America/Chicago'
> FILE_UPLOAD_MAX_MEMORY_SIZE
> 2621440
> LOCAL_GEOSERVER
> SESSION_CACHE_ALIAS
> 'default'
> EMAIL_BACKEND
> 'django.core.mail.backends.smtp.EmailBackend'
> ANONYMOUS_USER_ID
> '-1'
> DEFAULT_MAP_ZOOM
> 0
> TEMPLATE_CONTEXT_PROCESSORS
> ('django.contrib.auth.context_processors.auth',
> 'django.template.context_processors.debug',
> 'django.template.context_processors.i18n',
> 'django.template.context_processors.media',
> 'django.template.context_processors.static',
> 'django.template.context_processors.tz',
> 'django.contrib.messages.context_processors.messages')
> LOCKDOWN_GEONODE
> 0
> S3_STATIC_ENABLED
> False
> SESSION_COOKIE_AGE
> 1209600
> SETTINGS_MODULE
> 'geonode.settings'
> GUARDIAN_GET_INIT_ANONYMOUS_USER
> 'geonode.people.models.get_anonymous_user_instance'
> USE_ETAGS
> False
> SOCIAL_BUTTONS
> False
> LANGUAGES
> (('en', 'English'),
> ('it', 'Italiano'),
> ('de', 'Deutsch'),
> xce\xac'),
> ('fa', 'Persian'),
> ('ar', 'Arabic'),
> ('bn', 'Bengali'),
> ('ne', 'Nepali'),
> ('sq', 'Albanian'),
> ('sw', 'Swahili'),
> ('ru', 'Russian'),
> ('am', 'Amharic'),
> ('km', 'Khmer'),
> ('pl', 'Polish'),
> ('sv', 'Swedish'),
> ('uk', 'Ukranian'),
> ('si', 'Sinhala'),
> ('ta', 'Tamil'),
> ('tl', 'Tagalog'))
> CELERY_TASK_RESULT_EXPIRES
> 1
> DEFAULT_INDEX_TABLESPACE
> CSRF_COOKIE_AGE
> 31449600
> STATIC_URL
> '/static/'
> EMAIL_PORT
> 25
> LAYER_PREVIEW_LIBRARY
> 'geoext'
> USE_TZ
> False
> DEFAULT_SEARCH_SIZE
> 10
> CLIENT_RESULTS_LIMIT
> 100
> TEST_NON_SERIALIZED_APPS
> USE_QUEUE
> 0
> MODELTRANSLATION_DEFAULT_LANGUAGE
> 'en'
> ACCOUNT_SIGNUP_REDIRECT_URL
> u'/'
> LANGUAGE_COOKIE_PATH
> MIGRATION_MODULES
> CACHE_MIDDLEWARE_SECONDS
> 600
> EMAIL_SSL_CERTFILE
> None
> ACCOUNT_CREATE_ON_SAVE
> True
> VERSION
> '2.6'
> CSRF_COOKIE_HTTPONLY
> False
> DATETIME_INPUT_FORMATS
> ('%Y-%m-%d %H:%M:%S',
> '%Y-%m-%d %H:%M:%S.%f',
> '%Y-%m-%d %H:%M',
> '%Y-%m-%d',
> '%m/%d/%Y %H:%M:%S',
> '%m/%d/%Y %H:%M:%S.%f',
> '%m/%d/%Y %H:%M',
> '%m/%d/%Y',
> '%m/%d/%y %H:%M:%S',
> '%m/%d/%y %H:%M:%S.%f',
> '%m/%d/%y %H:%M',
> '%m/%d/%y')
> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
> 0
> FORCE_SCRIPT_NAME
> None
> SECURE_SSL_HOST
> None
> EMAIL_HOST_USER
> MAX_DOCUMENT_SIZE
> 5
> You're seeing this error because you have DEBUG = True in your Django
> settings file. Change that to False, and Django will display a standard
> page generated by the handler for this status code.
> Does anyone know the cause of this error?
> This email, and its attachments, is subject to important warnings and
> disclaimers which are legally incorporated into this email in terms of
> Section 11(3) of the South African Electronic Communications and
> Transactions Act, 25 of 2002. The full text of the warnings and
> disclaimers, together with the company details and directors is available
> by clicking on http://www.anglogoldashanti.com/en/Pages/legal.aspx
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170707/c9b71a23/attachment-0001.html>
More information about the geonode-users mailing list
