[GeoNode-users] geonode-project for templates
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 7 02:04:32 PDT 2017
Annalisa,
no need for a local settings actually, just use the settings of your
template project. It is already the 2.6 branch and is correct for geonode
2.6.
For templates you need to have the same folders structure as geonode does
in order for the template to be used, and your template project needs to be
in installed apps. For you the geo_header should be in
my_geonode/templates/geonode. This is a django normal configuration and is
also django that will find and render the templates inside the folders.
2017-07-07 10:48 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Hi all!
> I've create a new template after having upgraded geonode (to 2.6.1) with
> this instructions:
> $ django-admin startproject geoportale26 --template=https://github.com/GeoNode/geonode-project/archive/2.6.zip -epy,rst
> $ sudo pip install -e geoportale26
> according these instructions: https://github.com/GeoNode/geonode-project
> But I've chosed 2.6 branch, is it correct?
> I've these problems:
> 1. I don'y have local_settings.py.sample in my dir, so I don't renamed it
> and I've got only a settings.py in my dir geoportale26/geoportale26.
> 2. I changed/added some files in static dir (site_base.css, img, js and
> geoexplorer-debug.js) and in template dir, but the file "geo_header.html"
> under templates/geonode seems have no effect on the new site! In geo_header.html
> I call geoexplorer-debug.js instead of geoexplorer.js, how can I do?
> To apply changes, I run python collectstatic, and it replaces original
> static files in /var/www/geonode/static with mine, but how does it work
> with templates?
> Thanks to all
> Annalisa
> 2017-06-29 13:51 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Annalisa, it works in the same way.
>> Best
>> 2017-06-29 12:43 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com
>>> Hi all!
>>> In our geonode 2.4 site I used geonode-project to customize logo, images
>>> and little else.
>>> For geonode 2.6, can I use it in the same way? Do you suggest to follow
>>>  (connect to geonode/stable) ? It works in the same way?
>>> Is there any up-to-date documentation?
>>> Thanks
>>> Annalisa
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170707/9bbc02d8/attachment-0001.html>
More information about the geonode-users mailing list
