[GeoNode-users] Data Issue When assessing GeoNode IP address
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jul 11 01:11:57 PDT 2017
>From the geoserver web page you can access the geoserver logs and see if
there are errors related to authentication. If yes then you need to follow
that guide to fix.
2017-07-11 9:00 GMT+02:00 Nizam ud Din <nizam_space at hotmail.com>:
> Dear Simone
> Thanks for the quick reply.
> Sir I checked and Geoserver is active and showing all data (Layers &
> documents) on the computer where GeoNode is installed.
> I am in trouble when I access GeoNode to another computer via IP address
> of that computer where GeoNode is installed.
> Sir Layers can not be viewed, downloaded and no thumbnail.
> Sir some maps and documents (which are not compressed) can be downloaded,
> while not showing thumbnails but .rar document give Internal server error.
> Sir I am not a developer and I want to know in step wise.
> Best Regards
> * Nizam-ud-Din*
> *Sr. Manager GIS **The Urban Unit*
> (Urban Sector Planning & Management Services Unit (Private) Limited)
> * Government of The Punjab,*
> * 503-**Shaheen Complex
> <https://maps.google.com/maps?q=31.562863%2c+74.332847&num=1&t=h&vpsrc=6&ie=UTF8&ll=31.562749%2c74.33297&spn=0.001296%2c0.002642&z=19&iwloc=A>
> , **5th Floor, ** Egerton Road, Lahore. Pakista*n
> *------------------------------------ *Mob: +92-321-4243824
> <+92%20321%204243824>
> Office: +92-042-99205316 <+92%2042%2099205316>-22,042-36376365
> fax: 042-99205323
> Email: nizam at urbanunit.gov.pk, nizam_space at hotmail.com
> *http://www.urbanunit.gov.pk <http://www.urbanunit.gov.pk/>*
> http://www.irispunjab.gov.pk
> *From:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Sent:* Tuesday, July 11, 2017 10:45 AM
> *To:* Nizam ud Din
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] Data Issue When assessing GeoNode IP
> address
> Hi, this looks like a misconfiguration, in particular I see two issues:
> - the web server is not correctly configured to serve the thumbnails or
> the thumbnails are not generated correctly
> - the permissions issue is probably due to the fact that geoserver cannot
> reach GeoNode to ask for authorization (and this could also be the reason
> of the issue 1)
> Check the geoserver's logs to see if there are auth issues and in case fix
> the geoserver configuration http://docs.geonode.org/en/master/
> tutorials/install_and_admin/geonode_install/install_
> geoserver_application.html#setup-geoserver
> 2017-07-10 9:17 GMT+02:00 Nizam ud Din <nizam_space at hotmail.com>:
>> Dear All
>> I am new one in using GeoNode.
>> I installed GeoNode 2.4 on Window and working well.
>> I am accessing on other systems (computer) via IP address,I have the
>> following issues;
>> 1-layers/documents not showing in the data content window as below;
>> 2- when I want to download data i received "Error! permission to
>> download the resource could not be requested to resource owner because of
>> an error".
>> Best Regards
>> * Nizam-ud-Din*
>> fax: 042-99205323
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/3e203b93/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/3e203b93/attachment-0001.png>
More information about the geonode-users mailing list
