[GeoNode-users] ACTIVITY Feed - Option
Naresh N naresh919 at gmail.com
Tue Jul 11 05:08:25 PDT 2017
Dear All,
 Please any body can share how to disable activity stream option for all
the users.
With Best Regards,
Naresh
On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com> wrote:
> Dear Fabiani,
>  Thanks for sharing the links, I will go through the links
> Best Regards,
> Naresh
> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> Hi,
>> recently I have rebuilt almost from scratch the source code of
>> GeoExplorer and aligned with live code in order to make it updatable.
>> You can find the GeoNode module here
>> https://github.com/GeoNode/django-geoexplorer
>> It actually depends on this one
>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-geoexplorer
>> which, again, references other git submodules.
>> See instructions here
>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-sources
>> also you need to download sources by uasing
>> git submodule sync
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> 55054  Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Geoexplorer is quite difficult to modify, and I don't know where you
>>> could do such change.
>>> Here's a very minimal documentation on how to make geoexplorer work in
>>> dev mode but then not sure how you can compile it back and deploy
>>> http://docs.geonode.org/en/master/tutorials/devel/dev
>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>>  Yes as told functionality is working properly based on permissions as
>>>> geoserver handling the styling option. But if user is not having permission
>>>> if he does the style change,after that showing error message like as
>>>> follows, user time will waste it is better if we disable based on
>>>> previliges. How Edit option is implemented, kindly tell us where i need to
>>>> modify the functionality
>>>>     [image: Inline image 1]
>>>> Thanks&Regards,
>>>> Naresh
>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>> development. Although the permission should be respected by geoserver
>>>>> anyway,
>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone and all,
>>>>>>   One more query, please help me to do
>>>>>>  If user has option for visualizing the layer and not having style
>>>>>> option, then also Style icon is enabled mode in Map and Layer Window of
>>>>>> GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>> having permission for add/edit style
>>>>>> *NOTE: This kind of enabling/disabling icon is happening for Editing
>>>>>> data icon. In following Edit is disable mode if user has not having edit
>>>>>> option. How ever for Style it is not happening*
>>>>>> *   [image: Inline image 1]*
>>>>>> How to enable/disable style icon based on user privileges for styling
>>>>>> the data
>>>>>> Best Regards,
>>>>>> Naresh
>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <naresh919 at gmail.com>
>>>>>> wrote:
>>>>>>> Dear Simone,
>>>>>>>   Thanks for the response, I will go through the shared link
>>>>>>> Best Regards,
>>>>>>> Naresh
>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>> Hi, GeoNode does not ship this but you can develop it. This is the
>>>>>>>> app geonode is using to implement the activity stream.
>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear All,
>>>>>>>>>    Is it possible Activity Feed of the People  should be visible
>>>>>>>>> to other users based on user settings?
>>>>>>>>>  I mean in following screenshot , I could able to see the activity
>>>>>>>>> of jamesboy.  But is it possible we can provide some option to  user to
>>>>>>>>> share his  Activity  Feed with other based on his choice. How to do it?
>>>>>>>>> Kindly help me to do.
>>>>>>>>> Thanks&Regards,
>>>>>>>>> Naresh
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> Simone
>>>>> Simone
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0c6ebfe2/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0c6ebfe2/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0c6ebfe2/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0c6ebfe2/attachment-0005.png>
More information about the geonode-users mailing list
