[GeoNode-users] ACTIVITY Feed - Option
Naresh N naresh919 at gmail.com
Tue Jul 11 23:18:54 PDT 2017
Dear Simone,
  Thanks for the response. After commenting following two lines, it did not
working as per expected.
https://github.com/GeoNode/geonode/blob/master/geonode/
people/templates/people/profile_detail.html#L130 and   https://github.com/
GeoNode/geonode/blob/master/geonode/urls.py#L86.
In this case also Not able to see the user list,please find the below
screenshot for reference
[image: Inline image 1]
Please find below my requirement, I want on click of People, the user list
should be available as follows and there should not be no option to see the
activity feed of the user.
[image: Inline image 2]
  Even if user know direct url of the activity feed, he should not able to
see the activity feed, I mean with the url
http://192.168.197.108/activity/actors/31/5/  now I am able to see the
activity feed. So even with direct url user should not see activity feed
Please help me to do the task.
Best Regards,
Naresh. N
On Tue, Jul 11, 2017 at 6:16 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> You have to comment out the activity button in the template of profile
> detail too https://github.com/GeoNode/geonode/blob/master/geonode/
> 2017-07-11 14:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>> Thanks for quick response
>>  I have commented the line 86 i.e. (r'^activity/',
>> include('actstream.urls')), then we are not able to see peoples profile
>> list. I want only activity feed should not be visible/accessible to the
>> users. Please suggest
>> Best Regards,
>> Naresh
>> On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi, you could exclude the activity urls by commenting this line
>>> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86.
>>> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear All,
>>>>  Please any body can share how to disable activity stream option for
>>>> all the users.
>>>> With Best Regards,
>>>> Naresh
>>>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>>> Dear Fabiani,
>>>>>  Thanks for sharing the links, I will go through the links
>>>>> Best Regards,
>>>>> Naresh
>>>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> Hi,
>>>>>> recently I have rebuilt almost from scratch the source code of
>>>>>> GeoExplorer and aligned with live code in order to make it updatable.
>>>>>> You can find the GeoNode module here
>>>>>> https://github.com/GeoNode/django-geoexplorer
>>>>>> It actually depends on this one
>>>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-
>>>>>> geoexplorer
>>>>>> which, again, references other git submodules.
>>>>>> See instructions here
>>>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-sources
>>>>>> also you need to download sources by uasing
>>>>>> git submodule sync
>>>>>> Regards,
>>>>>> Alessio Fabiani
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A
>>>>>> 55054  Massarosa (LU)
>>>>>> Italy
>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>> The information in this message and/or attachments, is intended
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>> information in this message that has been received in error. The sender
>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>> e-mail transmission, viruses, etc.
>>>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>>>>> Geoexplorer is quite difficult to modify, and I don't know where you
>>>>>>> could do such change.
>>>>>>> Here's a very minimal documentation on how to make geoexplorer work
>>>>>>> in dev mode but then not sure how you can compile it back and deploy
>>>>>>> http://docs.geonode.org/en/master/tutorials/devel/dev
>>>>>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>>  Yes as told functionality is working properly based on permissions
>>>>>>>> as geoserver handling the styling option. But if user is not having
>>>>>>>> permission if he does the style change,after that showing error message
>>>>>>>> like as follows, user time will waste it is better if we disable based on
>>>>>>>> previliges. How Edit option is implemented, kindly tell us where i need to
>>>>>>>> modify the functionality
>>>>>>>> Thanks&Regards,
>>>>>>>> Naresh
>>>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>>>>>> development. Although the permission should be respected by geoserver
>>>>>>>>> anyway,
>>>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone and all,
>>>>>>>>>>   One more query, please help me to do
>>>>>>>>>>  If user has option for visualizing the layer and not having
>>>>>>>>>> style option, then also Style icon is enabled mode in Map and Layer Window
>>>>>>>>>> of GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>>>>>> having permission for add/edit style
>>>>>>>>>> *NOTE: This kind of enabling/disabling icon is happening for
>>>>>>>>>> Editing data icon. In following Edit is disable mode if user has not having
>>>>>>>>>> edit option. How ever for Style it is not happening*
>>>>>>>>>> *   [image: Inline image 1]*
>>>>>>>>>> How to enable/disable style icon based on user privileges for
>>>>>>>>>> styling the data
>>>>>>>>>> Best Regards,
>>>>>>>>>> Naresh
>>>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>   Thanks for the response, I will go through the shared link
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it. This is
>>>>>>>>>>>> the app geonode is using to implement the activity stream.
>>>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>    Is it possible Activity Feed of the People  should be
>>>>>>>>>>>>> visible to other users based on user settings?
>>>>>>>>>>>>>  I mean in following screenshot , I could able to see the
>>>>>>>>>>>>> activity of jamesboy.  But is it possible we can provide some option to
>>>>>>>>>>>>>  user to share his  Activity  Feed with other based on his choice. How to
>>>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/38d75543/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/38d75543/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/38d75543/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/38d75543/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/38d75543/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/38d75543/attachment-0009.png>
More information about the geonode-users mailing list
