[GeoNode-users] python manage.py Error
Ariel Neri ariel.neriw at gmail.com
Thu Jul 13 07:10:20 PDT 2017
Thanks!, I downgraded Django to 1.8.7 and the NullHandler error disapeared.
Most python manage.py commands are working well, except "updatelayers"
(GDAL_ERROR 4: Unable to open...).  I´ll do some research on it first,
before posting in this group.
Thanks again George.
cheers!
2017-07-12 17:56 GMT-03:00 George Petrakis <gkpetrak at gmail.com>:
> I'm still using geonode 2.4 in Ubuntu 16.04 and my django's version is
> 1.6.11. In geonode 2.6, django's version should be 1.8.7 according to this
> file: https://github.com/GeoNode/geonode/blob/2.6.x/requirements.txt#L1
> George
> 2017-07-12 17:06 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
>> Thanks George, I saw that before, but since i´m not  a programmer and not
>> using the same version as the linked issue, i´m afraid to screw it up worse.
>> But i bleieve it´s related to django version, as you said.
>> Is GeoNode 2.6 using DJango 1.11.3? I want to make sure i didn´t change
>> version.
>> Thanks!
>> 2017-07-12 6:04 GMT-03:00 George Petrakis <gkpetrak at gmail.com>:
>>> Check this conversation. It could help. https://github.com/translate/p
>>> ootle/issues/4537
>>> George
>>> 2017-07-11 20:21 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
>>>> I followed the quick install: http://docs.geonode.o
>>>> rg/en/master/tutorials/install_and_admin/quick_install.html
>>>> I also tried to install "django-debug-toolbar" according to this link:
>>>> link: https://geonode.readthedocs.io/en/2.0/tutorials/admin/
>>>> debugging.html
>>>> but since it was throwing an internal server error, I removed the
>>>> changes done in local_settings.py back to original. Maybe that was a bad
>>>> move.
>>>>  Django version 1.11.3   (checked w  print(django.get_version())
>>>> 2017-07-11 12:59 GMT-03:00 George Petrakis <gkpetrak at gmail.com>:
>>>>> Hi Ariel,
>>>>> Maybe this issue is related with your Django version. Which guide did
>>>>> you follow to install GeoNode ?
>>>>> George
>>>>> 2017-07-11 17:57 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
>>>>>> Hi, I´m running GeoNode 2.6 in ubuntu server 16.04. I´m getting the
>>>>>> following errors when running updatelayers:
>>>>>> geonode at geonode:~/my_geonode$ python manage.py updatelayers
>>>>>> Traceback (most recent call last):
>>>>>>   File "manage.py", line 11, in <module>
>>>>>>     execute_from_command_line(sys.argv)
>>>>>>   File "/home/geonode/.local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>> line 363, in execute_from_command_line
>>>>>>     utility.execute()
>>>>>> line 337, in execute
>>>>>>     django.setup()
>>>>>>   File "/home/geonode/.local/lib/python2.7/site-packages/django/__init__.py",
>>>>>> line 22, in setup
>>>>>>     configure_logging(settings.LOGGING_CONFIG, settings.LOGGING)
>>>>>>   File "/home/geonode/.local/lib/python2.7/site-packages/django/utils/log.py",
>>>>>> line 75, in configure_logging
>>>>>>     logging_config_func(logging_settings)
>>>>>>   File "/usr/lib/python2.7/logging/config.py", line 794, in
>>>>>> dictConfig
>>>>>>     dictConfigClass(config).configure()
>>>>>>   File "/usr/lib/python2.7/logging/config.py", line 576, in configure
>>>>>>     '%r: %s' % (name, e))
>>>>>> ValueError: Unable to configure handler 'null': Cannot resolve
>>>>>> 'django.utils.log.NullHandler': No module named NullHandler
>>>>>> I have connected geoserver w a Postgis database, and it worked fine
>>>>>> when i had only those layers. Then I loaded new layers via GeoNode web, and
>>>>>> the command stopped working.
>>>>>>  "Collectstatic" command is throwing the same error.
>>>>>> I did not change LOGGING in settings.py. and did not override in
>>>>>> local_settings.py
>>>>>> I did changes according to this http://docs.geonode.org/e
>>>>>> n/master/tutorials/admin/customize_lookfeel/customize/setup_
>>>>>> admin.html.
>>>>>> I´m not a programmer so please, take that in account on your
>>>>>> suggestions or answers. Thanks!
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Πετράκης Γεώργιος
>>>>> Τοπογράφος Μηχανικός, Msc
>>>>> Τηλ: 2810-288363
>>>>> Κιν: 6984871889
>>> Πετράκης Γεώργιος
>>> Τηλ: 2810-288363
>>> Κιν: 6984871889
> Πετράκης Γεώργιος
> Τηλ: 2810-288363
> Κιν: 6984871889
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/5e3e33d4/attachment.html>
More information about the geonode-users mailing list
