[GeoNode-users] Data Issue When assessing GeoNode IP
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 14 00:28:32 PDT 2017
Now you can run the command "geonode updatelayers", this should fix it. The
thumbnail can be set rom the layer detail page. For maps you need to run
"geonode updatemaplayerip"
2017-07-13 11:36 GMT+02:00 Nizam ud Din <nizam_space at hotmail.com>:
> Dear Toni & Simone
> thanks for the guidance.
> I set the ip via settings.py & local_settings.py, and now problem is
> resolved for new data uploaded.
> But same problem for already up-loaded data, please guide.
> Best Regards
> * Nizam-ud-Din*
> *Sr. Manager GIS **The Urban Unit*
> (Urban Sector Planning & Management Services Unit (Private) Limited)
> * Government of The Punjab,*
> * 503-**Shaheen Complex
> <https://maps.google.com/maps?q=31.562863%2c+74.332847&num=1&t=h&vpsrc=6&ie=UTF8&ll=31.562749%2c74.33297&spn=0.001296%2c0.002642&z=19&iwloc=A>
> , **5th Floor, ** Egerton Road, Lahore. Pakista*n
> *------------------------------------ *Mob: +92-321-4243824
> <+92%20321%204243824>
> Office: +92-042-99205316 <+92%2042%2099205316>-22,042-36376365
> fax: 042-99205323
> Email: nizam at urbanunit.gov.pk, nizam_space at hotmail.com
> *http://www.urbanunit.gov.pk <http://www.urbanunit.gov.pk/>*
> http://www.irispunjab.gov.pk
> *From:* Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> *Sent:* Tuesday, July 11, 2017 2:00 PM
> *To:* nizam_space at hotmail.com
> *Cc:* geonode-users
> *Subject:* Data Issue When assessing GeoNode IP
> Hi Nizam,
> start by checking your geoserver
> settings in settings.py or local_settings.py.
> Pay attention to the URL´s and ports as well.
> Does this all fit with your setup?
> cheers,
> Toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198 <+49%20176%2066803198>
> Tel  +49/ (0) 341 24 04 738 <+49%20341%202404738>
> Fax  +49/ (0) 341 24 04 73 <+49%20341%20240473>
> Web http://csgis.de
> Anfang der weitergeleiteten Nachricht:
> *Von: *geonode-users-request at lists.osgeo.org
> *Betreff: **geonode-users Digest, Vol 30, Issue 27*
> *Datum: *11. Juli 2017 um 10:12:30 MESZ
> *An: *geonode-users at lists.osgeo.org
> *Antwort an: *geonode-users at lists.osgeo.org
> Message: 1
> Date: Tue, 11 Jul 2017 10:11:57 +0200
> From: Simone Dalmasso <simone.dalmasso at gmail.com>
> To: Nizam ud Din <nizam_space at hotmail.com>
> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] Data Issue When assessing GeoNode IP
> address
> Message-ID:
> <CAAHAC+dpRey9uvRLwAbSM2ep26vOGsdt+tHNKt2ZeSWAujiLAg at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> From the geoserver web page you can access the geoserver logs and see if
> there are errors related to authentication. If yes then you need to follow
> that guide to fix.
> 2017-07-11 9:00 GMT+02:00 Nizam ud Din <nizam_space at hotmail.com>:
> Dear Simone
> Thanks for the quick reply.
> Sir I checked and Geoserver is active and showing all data (Layers &
> documents) on the computer where GeoNode is installed.
> I am in trouble when I access GeoNode to another computer via IP address
> of that computer where GeoNode is installed.
> Sir Layers can not be viewed, downloaded and no thumbnail.
> Sir some maps and documents (which are not compressed) can be downloaded,
> while not showing thumbnails but .rar document give Internal server error.
> Sir I am not a developer and I want to know in step wise.
> Best Regards
> * Nizam-ud-Din*
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170714/69a96d61/attachment-0001.html>
More information about the geonode-users mailing list
