[GeoNode-users] error opening map
trocellier estelle trocellier.estelle at gmail.com
Wed Jul 19 01:06:58 PDT 2017
Dear all
I'm working on geonode 2.6 on a windows server.
I've created some map with layer from geoserver connecting to a data base
of postgis 9.5 (i didn't use the initial postgis 8.4 because it was to old
to make my backup...)
My problem is at the first time when i try to open the map i have this
message (go to see the attachment). But when i try to open it a second time
it's work but then i have a seconde message : [image: Images intégrées 1]
It seems that the problem come from the connection between geonode and
geoserver.
What do you think ?
And that should i do ? Can you explain in details please.
Thank you a lot
Regards
Estelle
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/563c8dea/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/563c8dea/attachment-0001.png>
error at /maps/38
10053 Une connexion ?tablie a ?t? abandonn?e par un logiciel de votre ordinateur h?te
Request Method:	GET
Request URL:	http://localhost/maps/38
Django Version:	1.8.17
Exception Type:	error
Exception Value:
Exception Location:	C:\GeoNode-2.6.x\Python27\Lib\socket.py in readline, line 480
Python Executable:	C:\GeoNode-2.6.x\Apache2\bin\Apache.exe
Python Version:	2.7.10
Python Path:
['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\Lib\\site-packages',
 'C:\\GeoNode-2.6.x\\Python27\\python27.zip',
 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\DLLs',
 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib',
 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\plat-win',
 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\lib-tk',
 'C:\\GeoNode-2.6.x\\Apache2\\bin',
 'C:\\GeoNode-2.6.x\\Python27\\Lib',
 'C:\\GeoNode-2.6.x\\Python27\\DLLs',
 'C:\\GeoNode-2.6.x\\Python27\\Lib\\lib-tk',
 'C:\\GeoNode-2.6.x\\geonode-2.6.x',
 'C:\\GeoNode-2.6.x\\geonode-2.6.x\\lib\\site-packages',
 'C:\\GeoNode-2.6.x\\Apache2']
Server time:	mer, 19 Jul 2017 09:43:53 -0500
Error during template rendering
In template C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\templates\maps\map_detail.html, error at line 215
10053
205
206	        <li class="list-group-item">
207	          <h4>{% trans "Copy this map" %}</h4>
208	          <p>{% trans "Duplicate this map and modify it for your own purposes" %}</p>
209	          <a href="{% url "new_map" %}?copy={{ resource.id }}" class="btn btn-default btn-md btn-block">{% trans "Create a New Map" %}</a>
210	        </li>
211
212	        {% if resource.is_public and "change_resourcebase" in perms_list or resource.layer_group %}
213	        <li class="list-group-item">
214	          <h4>{% trans "Map WMS" %}</h4>
215
                <dl>
      {% if resource.layer_group %}
216	            <dt>{% trans "WMS layer group for local map layers" %}:</dt>
217	            <dd><em>{{ resource.layer_group.catalog.name }}</em> ({% trans "on" %} <a href="{{ resource.layer_group.ows }}?service=WMS&request=GetCapabilities">{% trans "local OWS" %}</a>)</dd>
218	            {% endif %}</dl>
219	          {% if "change_resourcebase" in perms_list %}
220	          <p>{% trans "Publish local map layers as WMS layer group" %}</p>
221	          <a id="layer-group" href="{%url "map_wms" resource.id %}" class="btn btn-default btn-md btn-block">{% trans "Publish Map WMS" %}</a>
222	          {% endif %}
223	          <dl id="layer-group-dl"></dl>
224	        </li>
225	        {% endif %}
Traceback Switch to copy-and-paste view
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\core\handlers\base.py in get_response
                                response = wrapped_callback(request, *callback_args, **callback_kwargs) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\views.py in map_detail
                return render_to_response(template, RequestContext(request, context_dict)) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\shortcuts.py in render_to_response
                    content = loader.render_to_string(template_name, context, using=using) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\loader.py in render_to_string
                    return template.render(context, request) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\backends\django.py in render
                    return self.template.render(context) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in render
                                return self._render(context) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in _render
                    return self.nodelist.render(context) ...
? Local vars
                            bit = self.render_node(node, context) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\debug.py in render_node
                        return node.render(context) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\loader_tags.py in render
                    return compiled_parent._render(context) ...
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
                            result = block.nodelist.render(context) ...
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\defaulttags.py in render
                            return nodelist.render(context) ...
? Local vars
? Local vars
? Local vars
                                match = condition.eval(context) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\defaulttags.py in eval
                    return self.value.resolve(context, ignore_failures=True) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in resolve
                            obj = self.var.resolve(context) ...
? Local vars
                        value = self._resolve_lookup(context) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\django\template\base.py in _resolve_lookup
                                    current = getattr(current, bit) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\geonode\maps\models.py in layer_group
                            'catalog': gs_catalog.get_layergroup(lg_name), ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\geoserver\catalog.py in get_layergroup
                        group = self.get_xml(group_url) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\geoserver\catalog.py in get_xml
                        response, content = self.http.request(rest_url) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\httplib2\__init__.py in request
                                (response, content) = self._request(conn, authority, uri, request_uri, method, body, headers, redirections, cachekey) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\httplib2\__init__.py in _request
                    (response, content) = self._conn_request(conn, request_uri, method, body, headers) ...
? Local vars
C:\GeoNode-2.6.x\geonode-2.6.x\lib\site-packages\httplib2\__init__.py in _conn_request
                            response = conn.getresponse() ...
? Local vars
C:\GeoNode-2.6.x\Python27\Lib\httplib.py in getresponse
                        response.begin() ...
? Local vars
C:\GeoNode-2.6.x\Python27\Lib\httplib.py in begin
                        version, status, reason = self._read_status() ...
? Local vars
C:\GeoNode-2.6.x\Python27\Lib\httplib.py in _read_status
                    line = self.fp.readline(_MAXLINE + 1) ...
? Local vars
                                data = self._sock.recv(self._rbufsize) ...
? Local vars
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable	Value
csrftoken
'AmZ4tNEFZSrg1puU1fqARyefJPFTWXfi'
sessionid
'4d39mvu8ksvhq07nz31xh4gz6fwm3b4c'
META
Variable	Value
wsgi.multiprocess
False
HTTP_COOKIE
'sessionid=4d39mvu8ksvhq07nz31xh4gz6fwm3b4c; csrftoken=AmZ4tNEFZSrg1puU1fqARyefJPFTWXfi'
SERVER_PROTOCOL
'HTTP/1.1'
SERVER_SOFTWARE
'Apache/2.4.18 (Win32) mod_wsgi/4.4.21 Python/2.7.10'
SCRIPT_NAME
u''
mod_wsgi.enable_sendfile
'0'
mod_wsgi.handler_script
SERVER_SIGNATURE
REQUEST_METHOD
'GET'
PATH_INFO
u'/maps/38'
SystemRoot
'C:\\Windows'
QUERY_STRING
wsgi.errors
<mod_wsgi.Log object at 0x10DB4098>
HTTP_USER_AGENT
'Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/59.0.3071.115 Safari/537.36'
HTTP_CONNECTION
'keep-alive'
HTTP_REFERER
'http://localhost/maps/?limit=100&offset=0'
SERVER_NAME
'localhost'
REMOTE_ADDR
'::1'
mod_wsgi.request_handler
'wsgi-script'
apache.version
(2, 4, 10)
wsgi.url_scheme
'http'
PATH_TRANSLATED
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\wsgi.py\\maps\\38'
SERVER_PORT
'80'
mod_wsgi.version
(4, 4, 21)
SERVER_ADDR
'::1'
DOCUMENT_ROOT
'C:/GeoNode-2.6.x/geonode-2.6.x/geonode'
mod_wsgi.process_group
CONTEXT_DOCUMENT_ROOT
COMSPEC
'C:\\Windows\\system32\\cmd.exe'
mod_wsgi.path_info
'/maps/38'
SCRIPT_FILENAME
'C:/GeoNode-2.6.x/geonode-2.6.x/geonode/wsgi.py'
SERVER_ADMIN
'webmaster at example.org'
wsgi.input
<mod_wsgi.Input object at 0x131A7380>
HTTP_HOST
'localhost'
CONTEXT_PREFIX
mod_wsgi.callable_object
'application'
wsgi.multithread
True
PATHEXT
'.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC'
REQUEST_URI
'/maps/38'
HTTP_ACCEPT
'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8'
WINDIR
'C:\\Windows'
wsgi.file_wrapper
wsgi.version
(1, 0)
GATEWAY_INTERFACE
'CGI/1.1'
wsgi.run_once
False
mod_wsgi.script_name
REMOTE_PORT
'53996'
HTTP_ACCEPT_LANGUAGE
'fr-FR,fr;q=0.8,en-US;q=0.6,en;q=0.4'
REQUEST_SCHEME
'http'
CSRF_COOKIE_USED
True
mod_wsgi.script_start
'1500450233148350'
HTTP_UPGRADE_INSECURE_REQUESTS
'1'
mod_wsgi.application_group
'localhost|'
mod_wsgi.script_reloading
'1'
mod_wsgi.request_start
'1500450233147357'
CSRF_COOKIE
u'AmZ4tNEFZSrg1puU1fqARyefJPFTWXfi'
HTTP_ACCEPT_ENCODING
'gzip, deflate, br'
Settings
Using settings module geonode.settings
Setting	Value
_DEFAULT_LOCALE_PATHS
('C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\locale',)
CASCADE_WORKSPACE
'geonode'
DEFAULT_WORKSPACE
'geonode'
ACCOUNT_USER_DISPLAY
<function <lambda> at 0x0A8717F0>
DATABASES
{'datastore': {'ATOMIC_REQUESTS': False,
               'AUTOCOMMIT': True,
               'CONN_MAX_AGE': 0,
               'ENGINE': 'django.contrib.gis.db.backends.postgis',
               'HOST': 'localhost',
               'NAME': 'geonode_imports',
               'OPTIONS': {},
               'PASSWORD': u'********************',
               'PORT': '5454',
               'TEST': {'CHARSET': None,
                        'COLLATION': None,
                        'MIRROR': None,
                        'NAME': None},
               'TIME_ZONE': 'America/Chicago',
               'USER': 'geonode'},
 'default': {'ATOMIC_REQUESTS': False,
             'AUTOCOMMIT': True,
             'CONN_MAX_AGE': 0,
             'ENGINE': 'django.db.backends.postgresql_psycopg2',
             'NAME': 'geonode',
             'OPTIONS': {},
             'PORT': '5454',
                      'COLLATION': None,
                      'MIRROR': None,
                      'NAME': None},
             'USER': 'geonode'}}
AWS_QUERYSTRING_AUTH
False
CELERY_CREATE_MISSING_QUEUES
True
GEONODE_CONTRIB_APPS
('geonode.contrib.dynamic',
 'geonode.contrib.exif',
 'geonode.contrib.favorite',
 'geonode.contrib.geogig',
 'geonode.contrib.geosites',
 'geonode.contrib.nlp',
 'geonode.contrib.slack',
 'geonode.contrib.metadataxsl')
CSRF_COOKIE_SECURE
False
CELERY_DEFAULT_QUEUE
'default'
UPLOADER
{'BACKEND': 'geonode.rest',
 'OPTIONS': {'GEOGIG_ENABLED': False,
             'MOSAIC_ENABLED': False,
             'TIME_ENABLED': False}}
LANGUAGE_CODE
'en'
LICENSES
{'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
MANAGERS
DOWNLOAD_FORMATS_METADATA
['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
BROKER_URL
'django://'
SILENCED_SYSTEM_CHECKS
DEFAULT_CHARSET
'utf-8'
IGNORABLE_404_URLS
CELERY_DEFAULT_EXCHANGE_TYPE
'direct'
GDAL_LIBRARY_PATH
'C:\\GeoNode-2.6.x\\GDAL\\gdal111.dll'
DEFAULT_MAP_CENTER
(0, 0)
ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
3
TIME_INPUT_FORMATS
('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
None
ACCOUNT_INVITE_USER_URL
u'account_invite_user'
REGISTRATION_OPEN
0
ALLOWED_HOSTS
['localhost', 'django', 'geonode.brl.intra']
EMAIL_HOST
'localhost'
DOWNLOAD_FORMATS_RASTER
['JPEG',
 'PDF',
 'PNG',
 'ArcGrid',
 'GeoTIFF',
 'Gtopo30',
 'ImageMosaic',
 'KML',
 'View in Google Earth',
 'Tiles',
 'GML',
 'GZIP']
AUTH_EXEMPT_URLS
WSGI_APPLICATION
None
EMAIL_SUBJECT_PREFIX
'[Django] '
SERVER_EMAIL
'root at localhost'
SECURE_HSTS_SECONDS
0
STATICFILES_FINDERS
('django.contrib.staticfiles.finders.FileSystemFinder',
 'django.contrib.staticfiles.finders.AppDirectoriesFinder')
NOTIFICATION_QUEUE_ALL
False
S3_MEDIA_ENABLED
False
CELERY_IMPORTS
('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
SESSION_COOKIE_DOMAIN
None
SESSION_COOKIE_NAME
'sessionid'
GEOSERVER_PUBLIC_LOCATION
'http://geonode.brl.intra:8080/geoserver/'
AWS_STORAGE_BUCKET_NAME
AWS_BUCKET_NAME
SECURE_REDIRECT_EXEMPT
ACCOUNT_USE_AUTH_AUTHENTICATE
False
EMAIL_SSL_KEYFILE
FILE_UPLOAD_DIRECTORY_PERMISSIONS
None
X_FRAME_OPTIONS
'SAMEORIGIN'
FILE_UPLOAD_PERMISSIONS
None
ACCOUNT_TIMEZONES
[('Africa/Abidjan', 'Africa/Abidjan'),
 ('Africa/Accra', 'Africa/Accra'),
 ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
 ('Africa/Algiers', 'Africa/Algiers'),
 ('Africa/Asmara', 'Africa/Asmara'),
 ('Africa/Asmera', 'Africa/Asmera'),
 ('Africa/Bamako', 'Africa/Bamako'),
 ('Africa/Bangui', 'Africa/Bangui'),
 ('Africa/Banjul', 'Africa/Banjul'),
 ('Africa/Bissau', 'Africa/Bissau'),
 ('Africa/Blantyre', 'Africa/Blantyre'),
 ('Africa/Brazzaville', 'Africa/Brazzaville'),
 ('Africa/Bujumbura', 'Africa/Bujumbura'),
 ('Africa/Cairo', 'Africa/Cairo'),
 ('Africa/Casablanca', 'Africa/Casablanca'),
 ('Africa/Ceuta', 'Africa/Ceuta'),
 ('Africa/Conakry', 'Africa/Conakry'),
 ('Africa/Dakar', 'Africa/Dakar'),
 ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
 ('Africa/Djibouti', 'Africa/Djibouti'),
 ('Africa/Douala', 'Africa/Douala'),
 ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
 ('Africa/Freetown', 'Africa/Freetown'),
 ('Africa/Gaborone', 'Africa/Gaborone'),
 ('Africa/Harare', 'Africa/Harare'),
 ('Africa/Johannesburg', 'Africa/Johannesburg'),
 ('Africa/Juba', 'Africa/Juba'),
 ('Africa/Kampala', 'Africa/Kampala'),
 ('Africa/Khartoum', 'Africa/Khartoum'),
 ('Africa/Kigali', 'Africa/Kigali'),
 ('Africa/Kinshasa', 'Africa/Kinshasa'),
 ('Africa/Lagos', 'Africa/Lagos'),
 ('Africa/Libreville', 'Africa/Libreville'),
 ('Africa/Lome', 'Africa/Lome'),
 ('Africa/Luanda', 'Africa/Luanda'),
 ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
 ('Africa/Lusaka', 'Africa/Lusaka'),
 ('Africa/Malabo', 'Africa/Malabo'),
 ('Africa/Maputo', 'Africa/Maputo'),
 ('Africa/Maseru', 'Africa/Maseru'),
 ('Africa/Mbabane', 'Africa/Mbabane'),
 ('Africa/Mogadishu', 'Africa/Mogadishu'),
 ('Africa/Monrovia', 'Africa/Monrovia'),
 ('Africa/Nairobi', 'Africa/Nairobi'),
 ('Africa/Ndjamena', 'Africa/Ndjamena'),
 ('Africa/Niamey', 'Africa/Niamey'),
 ('Africa/Nouakchott', 'Africa/Nouakchott'),
 ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
 ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
 ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
 ('Africa/Timbuktu', 'Africa/Timbuktu'),
 ('Africa/Tripoli', 'Africa/Tripoli'),
 ('Africa/Tunis', 'Africa/Tunis'),
 ('Africa/Windhoek', 'Africa/Windhoek'),
 ('America/Adak', 'America/Adak'),
 ('America/Anchorage', 'America/Anchorage'),
 ('America/Anguilla', 'America/Anguilla'),
 ('America/Antigua', 'America/Antigua'),
 ('America/Araguaina', 'America/Araguaina'),
 ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
 ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
 ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
 ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
 ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
 ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
 ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
 ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
 ('America/Argentina/Salta', 'America/Argentina/Salta'),
 ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
 ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
 ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
 ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
 ('America/Aruba', 'America/Aruba'),
 ('America/Asuncion', 'America/Asuncion'),
 ('America/Atikokan', 'America/Atikokan'),
 ('America/Atka', 'America/Atka'),
 ('America/Bahia', 'America/Bahia'),
 ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
 ('America/Barbados', 'America/Barbados'),
 ('America/Belem', 'America/Belem'),
 ('America/Belize', 'America/Belize'),
 ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
 ('America/Boa_Vista', 'America/Boa_Vista'),
 ('America/Bogota', 'America/Bogota'),
 ('America/Boise', 'America/Boise'),
 ('America/Buenos_Aires', 'America/Buenos_Aires'),
 ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
 ('America/Campo_Grande', 'America/Campo_Grande'),
 ('America/Cancun', 'America/Cancun'),
 ('America/Caracas', 'America/Caracas'),
 ('America/Catamarca', 'America/Catamarca'),
 ('America/Cayenne', 'America/Cayenne'),
 ('America/Cayman', 'America/Cayman'),
 ('America/Chicago', 'America/Chicago'),
 ('America/Chihuahua', 'America/Chihuahua'),
 ('America/Coral_Harbour', 'America/Coral_Harbour'),
 ('America/Cordoba', 'America/Cordoba'),
 ('America/Costa_Rica', 'America/Costa_Rica'),
 ('America/Creston', 'America/Creston'),
 ('America/Cuiaba', 'America/Cuiaba'),
 ('America/Curacao', 'America/Curacao'),
 ('America/Danmarkshavn', 'America/Danmarkshavn'),
 ('America/Dawson', 'America/Dawson'),
 ('America/Dawson_Creek', 'America/Dawson_Creek'),
 ('America/Denver', 'America/Denver'),
 ('America/Detroit', 'America/Detroit'),
 ('America/Dominica', 'America/Dominica'),
 ('America/Edmonton', 'America/Edmonton'),
 ('America/Eirunepe', 'America/Eirunepe'),
 ('America/El_Salvador', 'America/El_Salvador'),
 ('America/Ensenada', 'America/Ensenada'),
 ('America/Fort_Nelson', 'America/Fort_Nelson'),
 ('America/Fort_Wayne', 'America/Fort_Wayne'),
 ('America/Fortaleza', 'America/Fortaleza'),
 ('America/Glace_Bay', 'America/Glace_Bay'),
 ('America/Godthab', 'America/Godthab'),
 ('America/Goose_Bay', 'America/Goose_Bay'),
 ('America/Grand_Turk', 'America/Grand_Turk'),
 ('America/Grenada', 'America/Grenada'),
 ('America/Guadeloupe', 'America/Guadeloupe'),
 ('America/Guatemala', 'America/Guatemala'),
 ('America/Guayaquil', 'America/Guayaquil'),
 ('America/Guyana', 'America/Guyana'),
 ('America/Halifax', 'America/Halifax'),
 ('America/Havana', 'America/Havana'),
 ('America/Hermosillo', 'America/Hermosillo'),
 ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
 ('America/Indiana/Knox', 'America/Indiana/Knox'),
 ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
 ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
 ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
 ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
 ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
 ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
 ('America/Indianapolis', 'America/Indianapolis'),
 ('America/Inuvik', 'America/Inuvik'),
 ('America/Iqaluit', 'America/Iqaluit'),
 ('America/Jamaica', 'America/Jamaica'),
 ('America/Jujuy', 'America/Jujuy'),
 ('America/Juneau', 'America/Juneau'),
 ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
 ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
 ('America/Knox_IN', 'America/Knox_IN'),
 ('America/Kralendijk', 'America/Kralendijk'),
 ('America/La_Paz', 'America/La_Paz'),
 ('America/Lima', 'America/Lima'),
 ('America/Los_Angeles', 'America/Los_Angeles'),
 ('America/Louisville', 'America/Louisville'),
 ('America/Lower_Princes', 'America/Lower_Princes'),
 ('America/Maceio', 'America/Maceio'),
 ('America/Managua', 'America/Managua'),
 ('America/Manaus', 'America/Manaus'),
 ('America/Marigot', 'America/Marigot'),
 ('America/Martinique', 'America/Martinique'),
 ('America/Matamoros', 'America/Matamoros'),
 ('America/Mazatlan', 'America/Mazatlan'),
 ('America/Mendoza', 'America/Mendoza'),
 ('America/Menominee', 'America/Menominee'),
 ('America/Merida', 'America/Merida'),
 ('America/Metlakatla', 'America/Metlakatla'),
 ('America/Mexico_City', 'America/Mexico_City'),
 ('America/Miquelon', 'America/Miquelon'),
 ('America/Moncton', 'America/Moncton'),
 ('America/Monterrey', 'America/Monterrey'),
 ('America/Montevideo', 'America/Montevideo'),
 ('America/Montreal', 'America/Montreal'),
 ('America/Montserrat', 'America/Montserrat'),
 ('America/Nassau', 'America/Nassau'),
 ('America/New_York', 'America/New_York'),
 ('America/Nipigon', 'America/Nipigon'),
 ('America/Nome', 'America/Nome'),
 ('America/Noronha', 'America/Noronha'),
 ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
 ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
 ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
 ('America/Ojinaga', 'America/Ojinaga'),
 ('America/Panama', 'America/Panama'),
 ('America/Pangnirtung', 'America/Pangnirtung'),
 ('America/Paramaribo', 'America/Paramaribo'),
 ('America/Phoenix', 'America/Phoenix'),
 ('America/Port-au-Prince', 'America/Port-au-Prince'),
 ('America/Port_of_Spain', 'America/Port_of_Spain'),
 ('America/Porto_Acre', 'America/Porto_Acre'),
 ('America/Porto_Velho', 'America/Porto_Velho'),
 ('America/Puerto_Rico', 'America/Puerto_Rico'),
 ('America/Rainy_River', 'America/Rainy_River'),
 ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
 ('America/Recife', 'America/Recife'),
 ('America/Regina', 'America/Regina'),
 ('America/Resolute', 'America/Resolute'),
 ('America/Rio_Branco', 'America/Rio_Branco'),
 ('America/Rosario', 'America/Rosario'),
 ('America/Santa_Isabel', 'America/Santa_Isabel'),
 ('America/Santarem', 'America/Santarem'),
 ('America/Santiago', 'America/Santiago'),
 ('America/Santo_Domingo', 'America/Santo_Domingo'),
 ('America/Sao_Paulo', 'America/Sao_Paulo'),
 ('America/Scoresbysund', 'America/Scoresbysund'),
 ('America/Shiprock', 'America/Shiprock'),
 ('America/Sitka', 'America/Sitka'),
 ('America/St_Barthelemy', 'America/St_Barthelemy'),
 ('America/St_Johns', 'America/St_Johns'),
 ('America/St_Kitts', 'America/St_Kitts'),
 ('America/St_Lucia', 'America/St_Lucia'),
 ('America/St_Thomas', 'America/St_Thomas'),
 ('America/St_Vincent', 'America/St_Vincent'),
 ('America/Swift_Current', 'America/Swift_Current'),
 ('America/Tegucigalpa', 'America/Tegucigalpa'),
 ('America/Thule', 'America/Thule'),
 ('America/Thunder_Bay', 'America/Thunder_Bay'),
 ('America/Tijuana', 'America/Tijuana'),
 ('America/Toronto', 'America/Toronto'),
 ('America/Tortola', 'America/Tortola'),
 ('America/Vancouver', 'America/Vancouver'),
 ('America/Virgin', 'America/Virgin'),
 ('America/Whitehorse', 'America/Whitehorse'),
 ('America/Winnipeg', 'America/Winnipeg'),
 ('America/Yakutat', 'America/Yakutat'),
 ('America/Yellowknife', 'America/Yellowknife'),
 ('Antarctica/Casey', 'Antarctica/Casey'),
 ('Antarctica/Davis', 'Antarctica/Davis'),
 ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
 ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
 ('Antarctica/Mawson', 'Antarctica/Mawson'),
 ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
 ('Antarctica/Palmer', 'Antarctica/Palmer'),
 ('Antarctica/Rothera', 'Antarctica/Rothera'),
 ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
 ('Antarctica/Syowa', 'Antarctica/Syowa'),
 ('Antarctica/Troll', 'Antarctica/Troll'),
 ('Antarctica/Vostok', 'Antarctica/Vostok'),
 ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
 ('Asia/Aden', 'Asia/Aden'),
 ('Asia/Almaty', 'Asia/Almaty'),
 ('Asia/Amman', 'Asia/Amman'),
 ('Asia/Anadyr', 'Asia/Anadyr'),
 ('Asia/Aqtau', 'Asia/Aqtau'),
 ('Asia/Aqtobe', 'Asia/Aqtobe'),
 ('Asia/Ashgabat', 'Asia/Ashgabat'),
 ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
 ('Asia/Atyrau', 'Asia/Atyrau'),
 ('Asia/Baghdad', 'Asia/Baghdad'),
 ('Asia/Bahrain', 'Asia/Bahrain'),
 ('Asia/Baku', 'Asia/Baku'),
 ('Asia/Bangkok', 'Asia/Bangkok'),
 ('Asia/Barnaul', 'Asia/Barnaul'),
 ('Asia/Beirut', 'Asia/Beirut'),
 ('Asia/Bishkek', 'Asia/Bishkek'),
 ('Asia/Brunei', 'Asia/Brunei'),
 ('Asia/Calcutta', 'Asia/Calcutta'),
 ('Asia/Chita', 'Asia/Chita'),
 ('Asia/Choibalsan', 'Asia/Choibalsan'),
 ('Asia/Chongqing', 'Asia/Chongqing'),
 ('Asia/Chungking', 'Asia/Chungking'),
 ('Asia/Colombo', 'Asia/Colombo'),
 ('Asia/Dacca', 'Asia/Dacca'),
 ('Asia/Damascus', 'Asia/Damascus'),
 ('Asia/Dhaka', 'Asia/Dhaka'),
 ('Asia/Dili', 'Asia/Dili'),
 ('Asia/Dubai', 'Asia/Dubai'),
 ('Asia/Dushanbe', 'Asia/Dushanbe'),
 ('Asia/Famagusta', 'Asia/Famagusta'),
 ('Asia/Gaza', 'Asia/Gaza'),
 ('Asia/Harbin', 'Asia/Harbin'),
 ('Asia/Hebron', 'Asia/Hebron'),
 ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
 ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
 ('Asia/Hovd', 'Asia/Hovd'),
 ('Asia/Irkutsk', 'Asia/Irkutsk'),
 ('Asia/Istanbul', 'Asia/Istanbul'),
 ('Asia/Jakarta', 'Asia/Jakarta'),
 ('Asia/Jayapura', 'Asia/Jayapura'),
 ('Asia/Jerusalem', 'Asia/Jerusalem'),
 ('Asia/Kabul', 'Asia/Kabul'),
 ('Asia/Kamchatka', 'Asia/Kamchatka'),
 ('Asia/Karachi', 'Asia/Karachi'),
 ('Asia/Kashgar', 'Asia/Kashgar'),
 ('Asia/Kathmandu', 'Asia/Kathmandu'),
 ('Asia/Katmandu', 'Asia/Katmandu'),
 ('Asia/Khandyga', 'Asia/Khandyga'),
 ('Asia/Kolkata', 'Asia/Kolkata'),
 ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
 ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
 ('Asia/Kuching', 'Asia/Kuching'),
 ('Asia/Kuwait', 'Asia/Kuwait'),
 ('Asia/Macao', 'Asia/Macao'),
 ('Asia/Macau', 'Asia/Macau'),
 ('Asia/Magadan', 'Asia/Magadan'),
 ('Asia/Makassar', 'Asia/Makassar'),
 ('Asia/Manila', 'Asia/Manila'),
 ('Asia/Muscat', 'Asia/Muscat'),
 ('Asia/Nicosia', 'Asia/Nicosia'),
 ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
 ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
 ('Asia/Omsk', 'Asia/Omsk'),
 ('Asia/Oral', 'Asia/Oral'),
 ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
 ('Asia/Pontianak', 'Asia/Pontianak'),
 ('Asia/Pyongyang', 'Asia/Pyongyang'),
 ('Asia/Qatar', 'Asia/Qatar'),
 ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
 ('Asia/Rangoon', 'Asia/Rangoon'),
 ('Asia/Riyadh', 'Asia/Riyadh'),
 ('Asia/Saigon', 'Asia/Saigon'),
 ('Asia/Sakhalin', 'Asia/Sakhalin'),
 ('Asia/Samarkand', 'Asia/Samarkand'),
 ('Asia/Seoul', 'Asia/Seoul'),
 ('Asia/Shanghai', 'Asia/Shanghai'),
 ('Asia/Singapore', 'Asia/Singapore'),
 ('Asia/Srednekolymsk', 'Asia/Srednekolymsk'),
 ('Asia/Taipei', 'Asia/Taipei'),
 ('Asia/Tashkent', 'Asia/Tashkent'),
 ('Asia/Tbilisi', 'Asia/Tbilisi'),
 ('Asia/Tehran', 'Asia/Tehran'),
 ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
 ('Asia/Thimbu', 'Asia/Thimbu'),
 ('Asia/Thimphu', 'Asia/Thimphu'),
 ('Asia/Tokyo', 'Asia/Tokyo'),
 ('Asia/Tomsk', 'Asia/Tomsk'),
 ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
 ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
 ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
 ('Asia/Urumqi', 'Asia/Urumqi'),
 ('Asia/Ust-Nera', 'Asia/Ust-Nera'),
 ('Asia/Vientiane', 'Asia/Vientiane'),
 ('Asia/Vladivostok', 'Asia/Vladivostok'),
 ('Asia/Yakutsk', 'Asia/Yakutsk'),
 ('Asia/Yangon', 'Asia/Yangon'),
 ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
 ('Asia/Yerevan', 'Asia/Yerevan'),
 ('Atlantic/Azores', 'Atlantic/Azores'),
 ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
 ('Atlantic/Canary', 'Atlantic/Canary'),
 ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
 ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
 ('Atlantic/Faroe', 'Atlantic/Faroe'),
 ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
 ('Atlantic/Madeira', 'Atlantic/Madeira'),
 ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
 ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
 ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
 ('Atlantic/Stanley', 'Atlantic/Stanley'),
 ('Australia/ACT', 'Australia/ACT'),
 ('Australia/Adelaide', 'Australia/Adelaide'),
 ('Australia/Brisbane', 'Australia/Brisbane'),
 ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
 ('Australia/Canberra', 'Australia/Canberra'),
 ('Australia/Currie', 'Australia/Currie'),
 ('Australia/Darwin', 'Australia/Darwin'),
 ('Australia/Eucla', 'Australia/Eucla'),
 ('Australia/Hobart', 'Australia/Hobart'),
 ('Australia/LHI', 'Australia/LHI'),
 ('Australia/Lindeman', 'Australia/Lindeman'),
 ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
 ('Australia/Melbourne', 'Australia/Melbourne'),
 ('Australia/NSW', 'Australia/NSW'),
 ('Australia/North', 'Australia/North'),
 ('Australia/Perth', 'Australia/Perth'),
 ('Australia/Queensland', 'Australia/Queensland'),
 ('Australia/South', 'Australia/South'),
 ('Australia/Sydney', 'Australia/Sydney'),
 ('Australia/Tasmania', 'Australia/Tasmania'),
 ('Australia/Victoria', 'Australia/Victoria'),
 ('Australia/West', 'Australia/West'),
 ('Australia/Yancowinna', 'Australia/Yancowinna'),
 ('Brazil/Acre', 'Brazil/Acre'),
 ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
 ('Brazil/East', 'Brazil/East'),
 ('Brazil/West', 'Brazil/West'),
 ('CET', 'CET'),
 ('CST6CDT', 'CST6CDT'),
 ('Canada/Atlantic', 'Canada/Atlantic'),
 ('Canada/Central', 'Canada/Central'),
 ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
 ('Canada/Eastern', 'Canada/Eastern'),
 ('Canada/Mountain', 'Canada/Mountain'),
 ('Canada/Newfoundland', 'Canada/Newfoundland'),
 ('Canada/Pacific', 'Canada/Pacific'),
 ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
 ('Canada/Yukon', 'Canada/Yukon'),
 ('Chile/Continental', 'Chile/Continental'),
 ('Chile/EasterIsland', 'Chile/EasterIsland'),
 ('Cuba', 'Cuba'),
 ('EET', 'EET'),
 ('EST', 'EST'),
 ('EST5EDT', 'EST5EDT'),
 ('Egypt', 'Egypt'),
 ('Eire', 'Eire'),
 ('Etc/GMT', 'Etc/GMT'),
 ('Etc/GMT+0', 'Etc/GMT+0'),
 ('Etc/GMT+1', 'Etc/GMT+1'),
 ('Etc/GMT+10', 'Etc/GMT+10'),
 ('Etc/GMT+11', 'Etc/GMT+11'),
 ('Etc/GMT+12', 'Etc/GMT+12'),
 ('Etc/GMT+2', 'Etc/GMT+2'),
 ('Etc/GMT+3', 'Etc/GMT+3'),
 ('Etc/GMT+4', 'Etc/GMT+4'),
 ('Etc/GMT+5', 'Etc/GMT+5'),
 ('Etc/GMT+6', 'Etc/GMT+6'),
 ('Etc/GMT+7', 'Etc/GMT+7'),
 ('Etc/GMT+8', 'Etc/GMT+8'),
 ('Etc/GMT+9', 'Etc/GMT+9'),
 ('Etc/GMT-0', 'Etc/GMT-0'),
 ('Etc/GMT-1', 'Etc/GMT-1'),
 ('Etc/GMT-10', 'Etc/GMT-10'),
 ('Etc/GMT-11', 'Etc/GMT-11'),
 ('Etc/GMT-12', 'Etc/GMT-12'),
 ('Etc/GMT-13', 'Etc/GMT-13'),
 ('Etc/GMT-14', 'Etc/GMT-14'),
 ('Etc/GMT-2', 'Etc/GMT-2'),
 ('Etc/GMT-3', 'Etc/GMT-3'),
 ('Etc/GMT-4', 'Etc/GMT-4'),
 ('Etc/GMT-5', 'Etc/GMT-5'),
 ('Etc/GMT-6', 'Etc/GMT-6'),
 ('Etc/GMT-7', 'Etc/GMT-7'),
 ('Etc/GMT-8', 'Etc/GMT-8'),
 ('Etc/GMT-9', 'Etc/GMT-9'),
 ('Etc/GMT0', 'Etc/GMT0'),
 ('Etc/Greenwich', 'Etc/Greenwich'),
 ('Etc/UCT', 'Etc/UCT'),
 ('Etc/UTC', 'Etc/UTC'),
 ('Etc/Universal', 'Etc/Universal'),
 ('Etc/Zulu', 'Etc/Zulu'),
 ('Europe/Amsterdam', 'Europe/Amsterdam'),
 ('Europe/Andorra', 'Europe/Andorra'),
 ('Europe/Astrakhan', 'Europe/Astrakhan'),
 ('Europe/Athens', 'Europe/Athens'),
 ('Europe/Belfast', 'Europe/Belfast'),
 ('Europe/Belgrade', 'Europe/Belgrade'),
 ('Europe/Berlin', 'Europe/Berlin'),
 ('Europe/Bratislava', 'Europe/Bratislava'),
 ('Europe/Brussels', 'Europe/Brussels'),
 ('Europe/Bucharest', 'Europe/Bucharest'),
 ('Europe/Budapest', 'Europe/Budapest'),
 ('Europe/Busingen', 'Europe/Busingen'),
 ('Europe/Chisinau', 'Europe/Chisinau'),
 ('Europe/Copenhagen', 'Europe/Copenhagen'),
 ('Europe/Dublin', 'Europe/Dublin'),
 ('Europe/Gibraltar', 'Europe/Gibraltar'),
 ('Europe/Guernsey', 'Europe/Guernsey'),
 ('Europe/Helsinki', 'Europe/Helsinki'),
 ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
 ('Europe/Istanbul', 'Europe/Istanbul'),
 ('Europe/Jersey', 'Europe/Jersey'),
 ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
 ('Europe/Kiev', 'Europe/Kiev'),
 ('Europe/Kirov', 'Europe/Kirov'),
 ('Europe/Lisbon', 'Europe/Lisbon'),
 ('Europe/Ljubljana', 'Europe/Ljubljana'),
 ('Europe/London', 'Europe/London'),
 ('Europe/Luxembourg', 'Europe/Luxembourg'),
 ('Europe/Madrid', 'Europe/Madrid'),
 ('Europe/Malta', 'Europe/Malta'),
 ('Europe/Mariehamn', 'Europe/Mariehamn'),
 ('Europe/Minsk', 'Europe/Minsk'),
 ('Europe/Monaco', 'Europe/Monaco'),
 ('Europe/Moscow', 'Europe/Moscow'),
 ('Europe/Nicosia', 'Europe/Nicosia'),
 ('Europe/Oslo', 'Europe/Oslo'),
 ('Europe/Paris', 'Europe/Paris'),
 ('Europe/Podgorica', 'Europe/Podgorica'),
 ('Europe/Prague', 'Europe/Prague'),
 ('Europe/Riga', 'Europe/Riga'),
 ('Europe/Rome', 'Europe/Rome'),
 ('Europe/Samara', 'Europe/Samara'),
 ('Europe/San_Marino', 'Europe/San_Marino'),
 ('Europe/Sarajevo', 'Europe/Sarajevo'),
 ('Europe/Saratov', 'Europe/Saratov'),
 ('Europe/Simferopol', 'Europe/Simferopol'),
 ('Europe/Skopje', 'Europe/Skopje'),
 ('Europe/Sofia', 'Europe/Sofia'),
 ('Europe/Stockholm', 'Europe/Stockholm'),
 ('Europe/Tallinn', 'Europe/Tallinn'),
 ('Europe/Tirane', 'Europe/Tirane'),
 ('Europe/Tiraspol', 'Europe/Tiraspol'),
 ('Europe/Ulyanovsk', 'Europe/Ulyanovsk'),
 ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
 ('Europe/Vaduz', 'Europe/Vaduz'),
 ('Europe/Vatican', 'Europe/Vatican'),
 ('Europe/Vienna', 'Europe/Vienna'),
 ('Europe/Vilnius', 'Europe/Vilnius'),
 ('Europe/Volgograd', 'Europe/Volgograd'),
 ('Europe/Warsaw', 'Europe/Warsaw'),
 ('Europe/Zagreb', 'Europe/Zagreb'),
 ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
 ('Europe/Zurich', 'Europe/Zurich'),
 ('GB', 'GB'),
 ('GB-Eire', 'GB-Eire'),
 ('GMT', 'GMT'),
 ('GMT+0', 'GMT+0'),
 ('GMT-0', 'GMT-0'),
 ('GMT0', 'GMT0'),
 ('Greenwich', 'Greenwich'),
 ('HST', 'HST'),
 ('Hongkong', 'Hongkong'),
 ('Iceland', 'Iceland'),
 ('Indian/Antananarivo', 'Indian/Antananarivo'),
 ('Indian/Chagos', 'Indian/Chagos'),
 ('Indian/Christmas', 'Indian/Christmas'),
 ('Indian/Cocos', 'Indian/Cocos'),
 ('Indian/Comoro', 'Indian/Comoro'),
 ('Indian/Kerguelen', 'Indian/Kerguelen'),
 ('Indian/Mahe', 'Indian/Mahe'),
 ('Indian/Maldives', 'Indian/Maldives'),
 ('Indian/Mauritius', 'Indian/Mauritius'),
 ('Indian/Mayotte', 'Indian/Mayotte'),
 ('Indian/Reunion', 'Indian/Reunion'),
 ('Iran', 'Iran'),
 ('Israel', 'Israel'),
 ('Jamaica', 'Jamaica'),
 ('Japan', 'Japan'),
 ('Kwajalein', 'Kwajalein'),
 ('Libya', 'Libya'),
 ('MET', 'MET'),
 ('MST', 'MST'),
 ('MST7MDT', 'MST7MDT'),
 ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
 ('Mexico/BajaSur', 'Mexico/BajaSur'),
 ('Mexico/General', 'Mexico/General'),
 ('NZ', 'NZ'),
 ('NZ-CHAT', 'NZ-CHAT'),
 ('Navajo', 'Navajo'),
 ('PRC', 'PRC'),
 ('PST8PDT', 'PST8PDT'),
 ('Pacific/Apia', 'Pacific/Apia'),
 ('Pacific/Auckland', 'Pacific/Auckland'),
 ('Pacific/Bougainville', 'Pacific/Bougainville'),
 ('Pacific/Chatham', 'Pacific/Chatham'),
 ('Pacific/Chuuk', 'Pacific/Chuuk'),
 ('Pacific/Easter', 'Pacific/Easter'),
 ('Pacific/Efate', 'Pacific/Efate'),
 ('Pacific/Enderbury', 'Pacific/Enderbury'),
 ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
 ('Pacific/Fiji', 'Pacific/Fiji'),
 ('Pacific/Funafuti', 'Pacific/Funafuti'),
 ('Pacific/Galapagos', 'Pacific/Galapagos'),
 ('Pacific/Gambier', 'Pacific/Gambier'),
 ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
 ('Pacific/Guam', 'Pacific/Guam'),
 ('Pacific/Honolulu', 'Pacific/Honolulu'),
 ('Pacific/Johnston', 'Pacific/Johnston'),
 ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
 ('Pacific/Kosrae', 'Pacific/Kosrae'),
 ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
 ('Pacific/Majuro', 'Pacific/Majuro'),
 ('Pacific/Marquesas', 'Pacific/Marquesas'),
 ('Pacific/Midway', 'Pacific/Midway'),
 ('Pacific/Nauru', 'Pacific/Nauru'),
 ('Pacific/Niue', 'Pacific/Niue'),
 ('Pacific/Norfolk', 'Pacific/Norfolk'),
 ('Pacific/Noumea', 'Pacific/Noumea'),
 ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
 ('Pacific/Palau', 'Pacific/Palau'),
 ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
 ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
 ('Pacific/Ponape', 'Pacific/Ponape'),
 ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
 ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
 ('Pacific/Saipan', 'Pacific/Saipan'),
 ('Pacific/Samoa', 'Pacific/Samoa'),
 ('Pacific/Tahiti', 'Pacific/Tahiti'),
 ('Pacific/Tarawa', 'Pacific/Tarawa'),
 ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
 ('Pacific/Truk', 'Pacific/Truk'),
 ('Pacific/Wake', 'Pacific/Wake'),
 ('Pacific/Wallis', 'Pacific/Wallis'),
 ('Pacific/Yap', 'Pacific/Yap'),
 ('Poland', 'Poland'),
 ('Portugal', 'Portugal'),
 ('ROC', 'ROC'),
 ('ROK', 'ROK'),
 ('Singapore', 'Singapore'),
 ('Turkey', 'Turkey'),
 ('UCT', 'UCT'),
 ('US/Alaska', 'US/Alaska'),
 ('US/Aleutian', 'US/Aleutian'),
 ('US/Arizona', 'US/Arizona'),
 ('US/Central', 'US/Central'),
 ('US/East-Indiana', 'US/East-Indiana'),
 ('US/Eastern', 'US/Eastern'),
 ('US/Hawaii', 'US/Hawaii'),
 ('US/Indiana-Starke', 'US/Indiana-Starke'),
 ('US/Michigan', 'US/Michigan'),
 ('US/Mountain', 'US/Mountain'),
 ('US/Pacific', 'US/Pacific'),
 ('US/Pacific-New', 'US/Pacific-New'),
 ('US/Samoa', 'US/Samoa'),
 ('UTC', 'UTC'),
 ('Universal', 'Universal'),
 ('W-SU', 'W-SU'),
 ('WET', 'WET'),
 ('Zulu', 'Zulu')]
FILE_UPLOAD_HANDLERS
('django.core.files.uploadhandler.MemoryFileUploadHandler',
 'django.core.files.uploadhandler.TemporaryFileUploadHandler')
DEFAULT_CONTENT_TYPE
'text/html'
DEBUG_STATIC
0
ACCOUNT_APPROVAL_REQUIRED
0
BING_API_KEY
DATABASE_URL
'sqlite:///C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\development.db'
APPEND_SLASH
True
FIRST_DAY_OF_WEEK
0
DATABASE_ROUTERS
DEFAULT_TABLESPACE
STAMEN_BASEMAPS
False
GEOSERVER_LOCATION
YEAR_MONTH_FORMAT
'F Y'
STATICFILES_STORAGE
'django.contrib.staticfiles.storage.StaticFilesStorage'
CACHES
{'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
1
CKAN_ORIGINS
[{'css_class': 'hdx',
  'label': 'Humanitarian Data Exchange (HDX)',
  'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}&notes={abstract}&caveats={caveats}'}]
SLACK_WEBHOOK_URLS
['https://hooks.slack.com/services/T000/B000/XX']
ACCOUNT_EMAIL_CONFIRMATION_EMAIL
0
SESSION_COOKIE_PATH
ALT_OSM_BASEMAPS
False
USE_X_FORWARDED_HOST
False
ACCOUNT_OPEN_SIGNUP
True
ROOT_URLCONF
'geonode.urls'
CATALOGUE
{'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
             'URL': 'http://localhost:8000/catalogue/csw'}}
MAPBOX_ACCESS_TOKEN
MISSING_THUMBNAIL
'geonode/img/missing_thumb.png'
FILE_UPLOAD_TEMP_DIR
None
MIDDLEWARE_CLASSES
('django.middleware.common.CommonMiddleware',
 'django.contrib.sessions.middleware.SessionMiddleware',
 'django.contrib.messages.middleware.MessageMiddleware',
 'django.middleware.locale.LocaleMiddleware',
 'pagination.middleware.PaginationMiddleware',
 'django.middleware.csrf.CsrfViewMiddleware',
 'django.contrib.auth.middleware.AuthenticationMiddleware',
 'django.middleware.clickjacking.XFrameOptionsMiddleware',
 'django.contrib.auth.middleware.SessionAuthenticationMiddleware',
 'oauth2_provider.middleware.OAuth2TokenMiddleware')
USE_I18N
1
THOUSAND_SEPARATOR
SECRET_KEY
MODELTRANSLATION_FALLBACK_LANGUAGES
('en',)
LANGUAGE_COOKIE_NAME
'django_language'
OGC_SERVER
{'default': {'BACKEND': 'geonode.geoserver',
             'BACKEND_WRITE_ENABLED': True,
             'DATASTORE': 'datastore',
             'GEOGIG_DATASTORE_DIR': '',
             'GEONODE_SECURITY_ENABLED': True,
             'LOCATION': 'http://localhost:8080/geoserver/',
             'LOG_FILE': 'C:\\GeoNode-2.6.x\\geonode-2.6.x/geoserver/data/logs/geoserver.log',
             'MAPFISH_PRINT_ENABLED': True,
             'PRINT_NG_ENABLED': True,
             'PUBLIC_LOCATION': 'http://localhost/geoserver/',
             'TIMEOUT': 10,
             'USER': 'admin',
             'WMST_ENABLED': False,
             'WPS_ENABLED': False}}
ACCOUNT_REMEMBER_ME_EXPIRY
315360000
ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
DEFAULT_MAP_CRS
'EPSG:900913'
EMAIL_USE_SSL
False
ACCOUNT_EMAIL_UNIQUE
True
THESAURI
LOGGING_CONFIG
'logging.config.dictConfig'
_DEFAULT_LANGUAGES
(('en', 'English'),
 ('es', 'Espa\xc3\xb1ol'),
 ('it', 'Italiano'),
 ('fr', 'Fran\xc3\xa7ais'),
 ('de', 'Deutsch'),
 ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
 ('id', 'Bahasa Indonesia'),
 ('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
 ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
 ('fa', 'Persian'),
 ('ar', 'Arabic'),
 ('bn', 'Bengali'),
 ('ne', 'Nepali'),
 ('sq', 'Albanian'),
 ('af', 'Afrikaans'),
 ('sw', 'Swahili'),
 ('pt', 'Portuguese'),
 ('pt-br', 'Portuguese (Brazil)'),
 ('ru', 'Russian'),
 ('vi', 'Vietnamese'),
 ('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
 ('am', 'Amharic'),
 ('km', 'Khmer'),
 ('pl', 'Polish'),
 ('sv', 'Swedish'),
 ('th', '\xe0\xb9\x84\xe0\xb8\x97\xe0\xb8\xa2'),
 ('uk', 'Ukranian'),
 ('si', 'Sinhala'),
 ('ta', 'Tamil'),
 ('tl', 'Tagalog'))
TEMPLATE_LOADERS
('django.template.loaders.filesystem.Loader',
 'django.template.loaders.app_directories.Loader')
GEOS_LIBRARY_PATH
'C:\\GeoNode-2.6.x\\GDAL\\geos_c.dll'
TASTYPIE_DEFAULT_FORMATS
['json']
TEMPLATE_DEBUG
False
AUTO_GENERATE_AVATAR_SIZES
(20, 30, 32, 40, 50, 65, 70, 80, 100, 140, 200, 240)
CSRF_COOKIE_NAME
'csrftoken'
THEME_ACCOUNT_CONTACT_EMAIL
'admin at example.com'
'default'
OAUTH2_PROVIDER
{'CLIENT_ID_GENERATOR_CLASS': 'oauth2_provider.generators.ClientIdGenerator',
 'SCOPES': {'groups': 'Access to your groups',
            'read': 'Read scope',
            'write': 'Write scope'}}
CELERY_DEFAULT_ROUTING_KEY
ACCOUNT_LOGIN_REDIRECT_URL
u'/'
TWITTER_HASHTAGS
['geonode']
CELERY_ALWAYS_EAGER
True
EMAIL_TIMEOUT
None
MODIFY_TOPICCATEGORY
0
SIGNING_BACKEND
'django.core.signing.TimestampSigner'
SESSION_COOKIE_SECURE
False
NLP_ENABLED
False
ACCOUNT_LOGIN_URL
u'account_login'
MESSAGE_STORAGE
'django.contrib.messages.storage.fallback.FallbackStorage'
CACHE_TIME
0
SECURE_BROWSER_XSS_FILTER
False
PYCSW
{'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
                                        'contact_email': 'Email Address',
                                        'contact_name': 'Organization Name',
                                        'date': 'YYYY-MM-DD',
                                        'default_language': 'eng',
                                        'enabled': 'true',
                                        'gemet_keywords': 'Utility and governmental services',
                                        'languages_supported': 'eng,gre',
                                        'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
                   'metadata:main': {'contact_address': 'Mailing Address',
                                     'contact_city': 'City',
                                     'contact_country': 'Country',
                                     'contact_fax': '+xx-xxx-xxx-xxxx',
                                     'contact_hours': 'Hours of Service',
                                     'contact_instructions': 'During hours of service. Off on weekends.',
                                     'contact_name': 'Lastname, Firstname',
                                     'contact_phone': '+xx-xxx-xxx-xxxx',
                                     'contact_position': 'Position Title',
                                     'contact_postalcode': 'Zip or Postal Code',
                                     'contact_role': 'pointOfContact',
                                     'contact_stateorprovince': 'Administrative Area',
                                     'contact_url': 'Contact URL',
                                     'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing, and collaborative use of geospatial data',
                                     'identification_accessconstraints': 'None',
                                     'identification_fees': 'None',
                                     'identification_keywords': 'sdi, catalogue, discovery, metadata, GeoNode',
                                     'identification_keywords_type': 'theme',
                                     'identification_title': 'GeoNode Catalogue',
                                     'provider_name': 'Organization Name',
                                     'provider_url': 'http://localhost:8000/'}}}
CSRF_COOKIE_DOMAIN
None
FILE_CHARSET
'utf-8'
DEBUG
1
SECURE_SSL_REDIRECT
False
LANGUAGE_COOKIE_DOMAIN
None
AWS_ACCESS_KEY_ID
DEFAULT_FILE_STORAGE
'django.core.files.storage.FileSystemStorage'
INSTALLED_APPS
('modeltranslation',
 'django.contrib.auth',
 'django.contrib.contenttypes',
 'django.contrib.sessions',
 'django.contrib.sites',
 'django.contrib.admin',
 'django.contrib.sitemaps',
 'django.contrib.staticfiles',
 'django.contrib.messages',
 'django.contrib.humanize',
 'django.contrib.gis',
 'pagination',
 'taggit',
 'treebeard',
 'friendlytagloader',
 'geoexplorer',
 'leaflet',
 'django_extensions',
 'autocomplete_light',
 'mptt',
 'djcelery',
 'storages',
 'pinax_theme_bootstrap_account',
 'pinax_theme_bootstrap',
 'django_forms_bootstrap',
 'account',
 'avatar',
 'dialogos',
 'agon_ratings',
 'announcements',
 'actstream',
 'user_messages',
 'tastypie',
 'polymorphic',
 'guardian',
 'oauth2_provider',
 'geonode.people',
 'geonode.base',
 'geonode.layers',
 'geonode.maps',
 'geonode.proxy',
 'geonode.security',
 'geonode.social',
 'geonode.catalogue',
 'geonode.documents',
 'geonode.api',
 'geonode.groups',
 'geonode.services',
 'geonode.upload',
 'geonode.tasks')
LANGUAGES_BIDI
('he', 'ar', 'fa', 'ur')
USE_L10N
1
SITEURL
'http://localhost/'
STATIC_ROOT
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\static_root'
SECURE_HSTS_INCLUDE_SUBDOMAINS
False
GEONODE_APPS
('geonode.people',
 'geonode.base',
 'geonode.layers',
 'geonode.maps',
 'geonode.proxy',
 'geonode.security',
 'geonode.social',
 'geonode.api',
 'geonode.groups',
 'geonode.services',
 'geonode.upload',
 'geonode.tasks')
LEAFLET_CONFIG
{'PLUGINS': {u'ALL': {u'css': <leaflet.utils.ListWithLazyItems object at 0x0A669390>,
                      u'js': <leaflet.utils.ListWithLazyItems object at 0x1054D610>},
             u'__default__': {u'css': <leaflet.utils.ListWithLazyItems object at 0x1054D670>,
                              u'js': <leaflet.utils.ListWithLazyItems object at 0x1054D6F0>},
             u'__is_normalized__': True,
             'esri-leaflet': {'auto-include': True,
                              u'css': <leaflet.utils.ListWithLazyItems object at 0x1054D710>,
                              'js': <leaflet.utils.ListWithLazyItems object at 0x1054D730>},
             u'forms': {u'auto-include': False,
                        u'css': <leaflet.utils.ListWithLazyItems object at 0x1054D4B0>,
                        u'js': <leaflet.utils.ListWithLazyItems object at 0x0A669470>},
             'leaflet-fullscreen': {'auto-include': True,
                                    'css': <leaflet.utils.ListWithLazyItems object at 0x1054D630>,
                                    'js': <leaflet.utils.ListWithLazyItems object at 0x1054D690>}},
 'RESET_VIEW': False,
 'SRID': 3857,
 'TILES': [('Watercolor',
            'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png',
            'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a>          — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">          CC-BY-SA</a>'),
           ('Toner Lite',
            'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png',
            'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a>          — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">          CC-BY-SA</a>')]}
DOWNLOAD_FORMATS_VECTOR
['JPEG',
 'PDF',
 'PNG',
 'Zipped Shapefile',
 'GML 2.0',
 'GML 3.1.1',
 'CSV',
 'Excel',
 'GeoJSON',
 'KML',
 'Tiles']
PREPEND_WWW
False
SECURE_PROXY_SSL_HEADER
None
AUTH_IP_WHITELIST
TWITTER_CARD
True
ACCOUNT_PASSWORD_RESET_REDIRECT_URL
LANGUAGE_COOKIE_AGE
None
SESSION_COOKIE_HTTPONLY
True
AWS_SECRET_ACCESS_KEY
DEBUG_PROPAGATE_EXCEPTIONS
False
INTERNAL_IPS
DEFAULT_ANONYMOUS_VIEW_PERMISSION
1
_DEFAULT_SECRET_KEY
MONTH_DAY_FORMAT
'F j'
ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
u'account_login'
LOGIN_URL
'/account/login/'
SESSION_EXPIRE_AT_BROWSER_CLOSE
False
SEARCH_FILTERS
{'CATEGORIES_ENABLED': True,
 'DATE_ENABLED': True,
 'EXTENT_ENABLED': True,
 'H_KEYWORDS_ENABLED': u'********************',
 'KEYWORDS_ENABLED': u'********************',
 'OWNERS_ENABLED': True,
 'REGION_ENABLED': True,
 'TEXT_ENABLED': True,
 'TYPE_ENABLED': True,
 'T_KEYWORDS_ENABLED': u'********************'}
OPENGRAPH_ENABLED
True
OGP_URL
'http://geodata.tufts.edu/solr/select'
CELERY_EAGER_PROPAGATES_EXCEPTIONS
True
TIME_FORMAT
'P'
CELERY_IGNORE_RESULT
True
SERVICE_UPDATE_INTERVAL
0
AUTH_USER_MODEL
'people.Profile'
DATE_INPUT_FORMATS
('%Y-%m-%d',
 '%m/%d/%Y',
 '%m/%d/%y',
 '%b %d %Y',
 '%b %d, %Y',
 '%d %b %Y',
 '%d %b, %Y',
 '%B %d %Y',
 '%B %d, %Y',
 '%d %B %Y',
 '%d %B, %Y')
ACCOUNT_LOGOUT_REDIRECT_URL
u'/'
SESSION_SERIALIZER
'django.contrib.sessions.serializers.PickleSerializer'
HAYSTACK_SEARCH
False
AUTHENTICATION_BACKENDS
('oauth2_provider.backends.OAuth2Backend',
 'django.contrib.auth.backends.ModelBackend',
 'guardian.backends.ObjectPermissionBackend')
EMAIL_HOST_PASSWORD
CELERY_DISABLE_RATE_LIMITS
True
PASSWORD_RESET_TIMEOUT_DAYS
SESSION_FILE_PATH
None
CACHE_MIDDLEWARE_ALIAS
'default'
SESSION_SAVE_EVERY_REQUEST
False
NUMBER_GROUPING
0
SHORT_DATETIME_FORMAT
'm/d/Y P'
SESSION_ENGINE
'django.contrib.sessions.backends.db'
CELERY_RESULT_BACKEND
None
ACCOUNT_DELETION_MARK_CALLBACK
<function account_delete_mark at 0x09BE3DB0>
CSRF_COOKIE_PATH
LOGIN_REDIRECT_URL
'/accounts/profile/'
TEMPLATE_STRING_IF_INVALID
NLP_LIBRARY_PATH
'/opt/MITIE/mitielib'
ACCOUNT_DELETION_EXPUNGE_HOURS
48
PROJECT_ROOT
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode'
DECIMAL_SEPARATOR
API_INCLUDE_REGIONS_COUNT
CELERY_SEND_EVENTS
False
EXIF_ENABLED
False
NOSE_ARGS
['--nocapture', '--detailed-errors']
LOCALE_PATHS
NLP_MODEL_PATH
'/opt/MITIE/MITIE-models/english/ner_model.dat'
PASSWORD_HASHERS
PROXY_ALLOWED_HOSTS
LOCAL_MEDIA_URL
'/uploaded/'
CARTODB_BASEMAPS
False
SOCIAL_ORIGINS
[{'css_class': 'email',
  'label': 'Email',
  'url': 'mailto:?subject={name}&body={url}'},
 {'css_class': 'fb',
  'label': 'Facebook',
  'url': 'http://www.facebook.com/sharer.php?u={url}'},
 {'css_class': 'tw',
  'label': 'Twitter',
  'url': 'https://twitter.com/share?url={url}&hashtags={hashtags}'},
 {'css_class': 'gp',
  'label': 'Google +',
  'url': 'https://plus.google.com/share?url={url}'}]
LOGOUT_URL
'/account/logout/'
MAP_BASELAYERS
[{'source': {'ptype': 'gxp_wmscsource',
             'restUrl': '/gs/rest',
             'title': 'Local Geoserver',
             'url': 'http://localhost/geoserver/wms'}},
 {'args': ['No background'],
  'fixed': True,
  'group': 'background',
  'name': 'background',
  'source': {'ptype': 'gxp_olsource'},
  'type': 'OpenLayers.Layer',
  'visibility': False},
 {'fixed': True,
  'name': 'mapnik',
  'source': {'ptype': 'gxp_osmsource'},
  'type': 'OpenLayers.Layer.OSM',
  'visibility': True}]
EMAIL_USE_TLS
False
ACCOUNT_LANGUAGES
[('en', u'English'),
 ('es', u'espa\xf1ol'),
 ('it', u'italiano'),
 ('fr', u'fran\xe7ais'),
 ('de', u'Deutsch'),
 ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
 ('id', u'Bahasa Indonesia'),
 ('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
 ('ja', u'\u65e5\u672c\u8a9e'),
 ('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
 ('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
 ('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
 ('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
 ('sq', u'shqip'),
 ('af', u'Afrikaans'),
 ('sw', u'Kiswahili'),
 ('pt', u'Portugu\xeas'),
 ('pt-br', u'Portugu\xeas Brasileiro'),
 ('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
 ('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
 ('ko', u'\ud55c\uad6d\uc5b4'),
 ('am', 'Amharic'),
 ('km', u'Khmer'),
 ('pl', u'polski'),
 ('sv', u'svenska'),
 ('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
 ('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
 ('si', 'sinhala'),
 ('ta', u'tamil'),
 ('tl', 'tagalog')]
FIXTURE_DIRS
ABSOLUTE_URL_OVERRIDES
DATE_FORMAT
'N j, Y'
NLP_LOCATION_THRESHOLD
1.0
CSRF_FAILURE_VIEW
'django.views.csrf.csrf_failure'
SKIP_PERMS_FILTER
False
ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
MEDIA_ROOT
'C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\uploaded'
AGON_RATINGS_CATEGORY_CHOICES
{'documents.Document': {'document': 'How good is this document?'},
 'layers.Layer': {'layer': 'How good is this layer?'},
 'maps.Map': {'map': 'How good is this map?'}}
SECURE_CONTENT_TYPE_NOSNIFF
False
DEFAULT_EXCEPTION_REPORTER_FILTER
'django.views.debug.SafeExceptionReporterFilter'
ADMINS
FORMAT_MODULE_PATH
None
DEFAULT_FROM_EMAIL
'webmaster at localhost'
STATICFILES_DIRS
['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\static']
MEDIA_URL
'/uploaded/'
DATETIME_FORMAT
'N j, Y, P'
TEMPLATE_DIRS
ALLOWED_DOCUMENT_TYPES
['doc',
 'docx',
 'gif',
 'jpg',
 'jpeg',
 'ods',
 'odt',
 'odp',
 'pdf',
 'png',
 'ppt',
 'pptx',
 'rar',
 'sld',
 'tif',
 'tiff',
 'txt',
 'xls',
 'xlsx',
 'xml',
 'zip',
 'gz',
 'qml']
NOTIFICATION_LANGUAGE_MODULE
'account.Account'
ACCOUNT_DELETION_EXPUNGE_CALLBACK
<function account_delete_expunge at 0x09BE3D70>
RESOURCE_PUBLISHING
False
ACCOUNT_HOOKSET
<account.hooks.AccountDefaultHookSet object at 0x09BE2750>
PROXY_URL
'/proxy/?url='
SITE_ID
1
DISALLOWED_USER_AGENTS
ALLOWED_INCLUDE_ROOTS
API_LIMIT_PER_PAGE
THUNDERFOREST_BASEMAPS
False
ACCOUNT_SETTINGS_REDIRECT_URL
u'account_settings'
USE_THOUSAND_SEPARATOR
False
EXTRA_LANG_INFO
{'am': {'bidi': False,
        'code': 'am',
        'name': 'Amharic',
        'name_local': 'Amharic'},
 'si': {'bidi': False,
        'code': 'si',
        'name': 'Sinhala',
        'name_local': 'sinhala'},
 'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local': u'tamil'},
 'tl': {'bidi': False,
        'code': 'tl',
        'name': 'Tagalog',
        'name_local': 'tagalog'}}
SRID
{'DETAIL': 'never'}
LOGGING
{'disable_existing_loggers': True,
 'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
 'formatters': {'simple': {'format': '%(message)s'},
                'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
 'handlers': {'console': {'class': 'logging.StreamHandler',
                          'formatter': 'simple',
                          'level': 'ERROR'},
              'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
                              'filters': ['require_debug_false'],
                              'level': 'ERROR'},
              'null': {'class': 'django.utils.log.NullHandler',
                       'level': 'ERROR'}},
 'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
             'geonode': {'handlers': ['console'], 'level': 'ERROR'},
             'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
             'owslib': {'handlers': ['console'], 'level': 'ERROR'},
             'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
 'version': 1}
_DEFAULT_STATICFILES_DIRS
SHORT_DATE_FORMAT
'm/d/Y'
TWITTER_SITE
'@GeoNode'
SLACK_ENABLED
False
TEMPLATES
[{'APP_DIRS': True,
  'BACKEND': 'django.template.backends.django.DjangoTemplates',
  'DIRS': ['C:\\GeoNode-2.6.x\\geonode-2.6.x\\geonode\\templates'],
  'NAME': 'GeoNode Project Templates',
  'OPTIONS': {'context_processors': ['django.contrib.auth.context_processors.auth',
                                     'django.core.context_processors.debug',
                                     'django.core.context_processors.i18n',
                                     'django.core.context_processors.tz',
                                     'django.core.context_processors.media',
                                     'django.core.context_processors.static',
                                     'django.core.context_processors.request',
                                     'django.contrib.messages.context_processors.messages',
                                     'account.context_processors.account',
                                     'geonode.context_processors.resource_urls',
                                     'geonode.geoserver.context_processors.geoserver_urls'],
              'debug': 1}}]
TEST_RUNNER
'django_nose.NoseTestSuiteRunner'
ACTSTREAM_SETTINGS
{'FETCH_RELATIONS': True,
 'GFK_FETCH_DEPTH': 1,
 'USE_JSONFIELD': True,
 'USE_PREFETCH': False}
MODELTRANSLATION_LANGUAGES
['en']
HAYSTACK_FACET_COUNTS
False
CACHE_MIDDLEWARE_KEY_PREFIX
AWS_S3_BUCKET_DOMAIN
'.s3.amazonaws.com'
TIME_ZONE
'America/Chicago'
FILE_UPLOAD_MAX_MEMORY_SIZE
2621440
LOCAL_GEOSERVER
SESSION_CACHE_ALIAS
'default'
EMAIL_BACKEND
'django.core.mail.backends.smtp.EmailBackend'
ANONYMOUS_USER_ID
'-1'
DEFAULT_MAP_ZOOM
0
TEMPLATE_CONTEXT_PROCESSORS
('django.contrib.auth.context_processors.auth',
 'django.template.context_processors.debug',
 'django.template.context_processors.i18n',
 'django.template.context_processors.media',
 'django.template.context_processors.static',
 'django.template.context_processors.tz',
 'django.contrib.messages.context_processors.messages')
LOCKDOWN_GEONODE
0
S3_STATIC_ENABLED
False
SESSION_COOKIE_AGE
1209600
SETTINGS_MODULE
'geonode.settings'
GUARDIAN_GET_INIT_ANONYMOUS_USER
'geonode.people.models.get_anonymous_user_instance'
USE_ETAGS
False
SOCIAL_BUTTONS
True
LANGUAGES
(('en', 'English'),
 ('it', 'Italiano'),
 ('de', 'Deutsch'),
 ('fa', 'Persian'),
 ('ar', 'Arabic'),
 ('bn', 'Bengali'),
 ('ne', 'Nepali'),
 ('sq', 'Albanian'),
 ('sw', 'Swahili'),
 ('ru', 'Russian'),
 ('am', 'Amharic'),
 ('km', 'Khmer'),
 ('pl', 'Polish'),
 ('sv', 'Swedish'),
 ('uk', 'Ukranian'),
 ('si', 'Sinhala'),
 ('ta', 'Tamil'),
 ('tl', 'Tagalog'))
CELERY_TASK_RESULT_EXPIRES
1
DEFAULT_INDEX_TABLESPACE
CSRF_COOKIE_AGE
31449600
STATIC_URL
'/static/'
EMAIL_PORT
25
LAYER_PREVIEW_LIBRARY
'geoext'
USE_TZ
False
DEFAULT_SEARCH_SIZE
10
CLIENT_RESULTS_LIMIT
100
TEST_NON_SERIALIZED_APPS
USE_QUEUE
0
MODELTRANSLATION_DEFAULT_LANGUAGE
'en'
ACCOUNT_SIGNUP_REDIRECT_URL
u'/'
LANGUAGE_COOKIE_PATH
MIGRATION_MODULES
CACHE_MIDDLEWARE_SECONDS
600
EMAIL_SSL_CERTFILE
None
ACCOUNT_CREATE_ON_SAVE
True
VERSION
'2.6'
CSRF_COOKIE_HTTPONLY
False
DATETIME_INPUT_FORMATS
('%Y-%m-%d %H:%M:%S',
 '%Y-%m-%d %H:%M:%S.%f',
 '%Y-%m-%d %H:%M',
 '%Y-%m-%d',
 '%m/%d/%Y %H:%M:%S',
 '%m/%d/%Y %H:%M:%S.%f',
 '%m/%d/%Y %H:%M',
 '%m/%d/%Y',
 '%m/%d/%y %H:%M:%S',
 '%m/%d/%y %H:%M:%S.%f',
 '%m/%d/%y %H:%M',
 '%m/%d/%y')
ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
0
FORCE_SCRIPT_NAME
None
SECURE_SSL_HOST
None
EMAIL_HOST_USER
MAX_DOCUMENT_SIZE
2
More information about the geonode-users mailing list
