[GeoNode-users] issue uploading layer
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jul 19 01:30:45 PDT 2017
Dear all,
GeoNode is not currently working fine on OSGeO Live 10.5 due to a
misconfiguration of GeoServer. Or, to be more precise, it comes with a
vanilla version of GeoServer and it should be updated manually in order to
be able to communicate with GeoNode.
If you just want to do some tests or have a look at the configuration, you
might want to take a look at this Ubuntu VM here
http://training.geonode.geo-solutions.it/
We will try to fix OSGeO Live on the next releases hopefully.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Jul 19, 2017 at 3:12 AM, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Hi Vladimir: thanks for the info. This sounds like the following issue:
> https://trac.osgeo.org/osgeo/ticket/1968
> Perhaps you can try reverting to pycsw 1.10.3 on the VM and try again?
> ..Tom
> On Tue, Jul 18, 2017 at 3:49 PM, vladimir costas
> <vladimiracj at hotmail.com> wrote:
> > ________________________________
> > De: vladimir costas <vladimiracj at hotmail.com>
> > Enviado: martes, 18 de julio de 2017 07:28 p.m.
> > Para: geonode-users at lists.osgeo.org
> > Asunto: issue uploading layer
> > I am using OSGeolive 10.5 virtual machine and I got the message "Metadata
> > record for building does not exist, check the catalogue signals"
> > geonode-users mailing list
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/720bd74a/attachment.html>
More information about the geonode-users mailing list
