[GeoNode-users] Again on authentication - geofence
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jul 19 01:42:33 PDT 2017
Mmm I see,
this command "fixgeofencerules" is available only on master branch.
In this case is not so straight forward to fix this for all the layers. You
have two options:
1. For each Layer you need to click on "Permissions" and save again. Double
check that rules are added to GeoFence Data Rules. If more than one Layer
have same permissions, you can also do a bulk update from the Layers List
page
2. Backport that command from master branch and try to execute it again.
You just need to create this file on the same position
https://github.com/GeoNode/geonode/tree/master/geonode/base/management/commands
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Jul 18, 2017 at 1:00 PM, Annalisa Schiavon <
annalisa.schiavon at gmail.com> wrote:
> Hi Alessio and geonode users,
> I still have some issue with geofence.
> I have tried the command you suggest
> system at bender:~$ geonode fixgeofencerules
> Unknown command: 'fixgeofencerules'
> Type 'django-admin help' for usage.
> with no success.
> I should execute from a specific dir?
> I have installed geonode 2.6.1 from apt-get, in standard mode. In geofence
> Admin Page, the connection is successful, but down in the page I found user
> cache misses :
> [image: Immagine incorporata 2]
> Is there documentation on how setting geofence integrated in geonode?
> Any suggestions?
> Please help!
> 2017-07-11 13:14 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> You can try to use the following management command, it should help you
>> to align permissions and geofence rules
>> python manage.py fixgeofencerules
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, Jul 11, 2017 at 1:44 PM, Annalisa Schiavon <
>>> Hi all.
>>> I've still the problem of layer's thumbs not displayed.
>>> But more important, if I don't login in geonode with geonode user, I
>>> can't see most of layers with permission to all users!
>>> Even stranger, if I log in with geonode and than log out, I can see them.
>>> I checked all steps of  http://docs.geonode.org/en
>>> /master/tutorials/admin/geoserver_geonode_security/index.html
>>> <http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html?highlight=oauth2>
>>> but I don't  have generated new OAuth2 UserID and Secret key. How do you do
>>> it?
>>> I've noticed that under GeoFence Data Rules I've only few rules:
>>> [image: Immagine incorporata 1]
>>> I've checked permissions and saved only for a layer, and that is
>>> displayed without problems from anonymous user.
>>> I've to reapply permissions for all my 110 layers??? Is it this the
>>> problem, for you?
>>> I attach tomcat and apache logs.
>>> Thanks,
>>> Annalisa
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/86d3809e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/86d3809e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/86d3809e/attachment-0003.png>
More information about the geonode-users mailing list
