[GeoNode-users] how to make the local geonode accessible on the world wide web
Toni Schönbuchner toni.schoenbuchner at csgis.de
Thu Jul 27 02:23:26 PDT 2017
Hi Elisa,
if I´m understanding your setup now looks like this.
In your lan you have a virtual machine or server which
after booting always gets the same static ip from your router.
Further geonode is configured to „accept“ this adress and
can be reached by other computer with it´s ip: F.e.
http:/192.168.0.11
The next steps would be that you:
- open the ports in your router setup: 80, 8080
- forward needed ports to the geonode device (above descriped as 192.168.0.11)
Aftzer that check what´s your ip: https://www.whatismyip.com/ <https://www.whatismyip.com/>
If you did everything correct with your port forwarding (in theory)
you should be able to visit http://YOUR_IP in your Browser and see geonode.
(> unsure maybe you have to accept the public IP for geonode as well)
As a last step, depending on your provider you have a static or dynamic
ip. Dynamic means your IP will change (often during the night). In other
words visiting your public IP from above will not work anymore by tomorrow.
You can work around this with a service like https://www.duckdns.org/ <https://www.duckdns.org/>.
With this you can inform duckdns (done f.e. with a batch script) about your
changed IP, and visit your local setup with the DNS duckdns provides you.
As said, depending on your local networks more configuration is needed.
F.e. I do not know if you run a firewal, router, switches etc. which couls sit between
your geonde and the www world ;)
Let me know if this helps,
good luck also with the upstream speed ;),
Toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil	+49/ (0) 176 6680 3198
Tel 		+49/ (0) 341 24 04 738
Fax 		+49/ (0) 341 24 04 73
Web		http://csgis.de
Hinweis gemäß § 33 BDSG
Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> Am 27.07.2017 um 11:06 schrieb Elisa Pruvot <pruvotelisa at gmail.com>:
> I am not really at ease with computing.. So my questions are :
> - Is this port number the intern port I should indicate to open geonode thanks to the NAT/PAT home gateway configuration ?
> - Also what would be the url to access our GeoNode once it is opened ? Would it be something like :
> http://home_gateway_adress/computer_static_ip:8000 <http://home_gateway_adress/computer_static_ip:8000> ?
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170727/781285da/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170727/781285da/attachment.sig>
More information about the geonode-users mailing list
