[GeoNode-users] Printing Issue - GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Thu Jun 1 02:42:49 PDT 2017
Hi, seems that the server cannot contact the geoserver web site in order to
get the logo. Besides the connection problem itself, did you configure your
printing template in mapfish printing module? Unless you really want a
geoserver logo the you may remove it.
2017-06-01 11:26 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear GeoNode Users,
>  I have deployed GeNode in RHEL 7.2 64 bit machine.  In Layer/Map viewer
> Print icons was in disabled mode.Then to over come this issue,Print-plugin
> is installed and configured using instructions in given in following link
> http://suite.opengeo.org/docs/latest/geoserver/extensions/printing/index.
> html#installation.. Now Print icon is enable mode and Print Window is
> appearing with the layers, how ever when I select the Print icon from Print
> Window it is showing  following error
> [image: Inline image 2]
> With the fire bug , it is getting following *response*
> Error while generating PDF:
> org.mapfish.print.InvalidValueException: url has an invalid value:
> http://geoserver.org/img/geoserver-logo.png
> at org.mapfish.print.PDFUtils.createImage(PDFUtils.java:668)
> at org.mapfish.print.PDFUtils.createImageChunk(PDFUtils.java:656)
> at org.mapfish.print.PDFUtils.createImageChunk(PDFUtils.java:653)
> at org.mapfish.print.config.layout.ImageBlock.render(ImageBlock.java:66)
> at org.mapfish.print.PDFUtils.createCell(PDFUtils.java:624)
> at org.mapfish.print.PDFUtils.buildTable(PDFUtils.java:609)
> at org.mapfish.print.config.layout.ColumnsBlock.render(
> ColumnsBlock.java:72)
> at org.mapfish.print.config.layout.HeaderFooter.render(
> HeaderFooter.java:55)
> at org.mapfish.print.PDFCustomBlocks.addFooter(PDFCustomBlocks.java:134)
> at org.mapfish.print.PDFCustomBlocks.onEndPage(PDFCustomBlocks.java:89)
> at com.itextpdf.text.pdf.PdfDocument.newPage(PdfDocument.java:911)
> at com.itextpdf.text.Document.newPage(Document.java:363)
> at org.mapfish.print.config.layout.Page.render(Page.java:63)
> at org.mapfish.print.config.layout.MainPage.render(MainPage.java:63)
> at org.mapfish.print.config.layout.Layout.render(Layout.java:59)
> at org.mapfish.print.output.AbstractOutputFormat.doPrint(
> AbstractOutputFormat.java:30)
> at org.mapfish.print.output.PdfOutputFactory.print(
> PdfOutputFactory.java:58)
> at org.mapfish.print.MapPrinter.print(MapPrinter.java:173)
> at org.mapfish.print.servlet.MapPrinterServlet.doCreatePDFFile(
> MapPrinterServlet.java:366)
> at org.mapfish.print.servlet.MapPrinterServlet.createPDF(
> MapPrinterServlet.java:184)
> at org.mapfish.print.servlet.MapPrinterServlet.doPost(
> MapPrinterServlet.java:112)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
> at org.springframework.web.servlet.mvc.ServletWrappingController.
> handleRequestInternal(ServletWrappingController.java:159)
> at org.springframework.web.servlet.mvc.AbstractController.handleRequest(
> AbstractController.java:153)
> at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter
> .handle(SimpleControllerHandlerAdapter.java:48)
> at org.springframework.web.servlet.DispatcherServlet.
> doDispatch(DispatcherServlet.java:923)
> doService(DispatcherServlet.java:852)
> at org.springframework.web.servlet.FrameworkServlet.processRequest(
> FrameworkServlet.java:882)
> doPost(FrameworkServlet.java:789)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(
> ApplicationFilterChain.java:303)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(
> ApplicationFilterChain.java:208)
> at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
> ApplicationFilterChain.java:241)
> at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(
> ThreadLocalsCleanupFilter.java:28)
> at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(
> SpringDelegatingFilter.java:75)
> at org.geoserver.wms.animate.AnimatorFilter.doFilter(
> AnimatorFilter.java:71)
> SpringDelegatingFilter.java:71)
> at org.geoserver.filters.SpringDelegatingFilter.doFilter(
> SpringDelegatingFilter.java:46)
> at org.geoserver.platform.AdvancedDispatchFilter.doFilter(
> AdvancedDispatchFilter.java:50)
> at org.springframework.security.web.FilterChainProxy$
> VirtualFilterChain.doFilter(FilterChainProxy.java:311)
> at org.geoserver.security.filter.GeoServerCompositeFilter$
> NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
> at org.springframework.security.web.access.intercept.
> FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
> FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
> NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
> at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(
> GeoServerCompositeFilter.java:92)
> VirtualFilterChain.doFilter(FilterChainProxy.java:323)
> at org.springframework.security.web.access.ExceptionTranslationFilter.
> doFilter(ExceptionTranslationFilter.java:113)
> at org.geoserver.security.filter.GeoServerAnonymousAuthenticati
> onFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
> at org.springframework.security.web.authentication.www.
> BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
> at org.geoserver.security.filter.GeoServerBasicAuthenticationFi
> lter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
> at org.springframework.security.web.context.SecurityContextPersistenceFilt
> er.doFilter(SecurityContextPersistenceFilter.java:87)
> at org.geoserver.security.filter.GeoServerSecurityContextPersis
> tenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
> at org.springframework.security.web.FilterChainProxy.doFilter(
> FilterChainProxy.java:173)
> at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(
> GeoServerSecurityFilterChainProxy.java:135)
> at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(
> DelegatingFilterProxy.java:346)
> at org.springframework.web.filter.DelegatingFilterProxy.doFilter(
> DelegatingFilterProxy.java:259)
> at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
> at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
> at org.geoserver.filters.SessionDebugFilter.doFilter(
> SessionDebugFilter.java:48)
> at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
> at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(
> SetCharacterEncodingFilter.java:109)
> at org.apache.catalina.core.StandardWrapperValve.invoke(
> StandardWrapperValve.java:220)
> at org.apache.catalina.core.StandardContextValve.invoke(
> StandardContextValve.java:122)
> at org.apache.catalina.authenticator.AuthenticatorBase.invoke(
> AuthenticatorBase.java:505)
> at org.apache.catalina.core.StandardHostValve.invoke(
> StandardHostValve.java:169)
> at org.apache.catalina.valves.ErrorReportValve.invoke(
> ErrorReportValve.java:103)
> at org.apache.catalina.valves.AccessLogValve.invoke(
> AccessLogValve.java:956)
> at org.apache.catalina.core.StandardEngineValve.invoke(
> StandardEngineValve.java:116)
> at org.apache.catalina.connector.CoyoteAdapter.service(
> CoyoteAdapter.java:436)
> at org.apache.coyote.http11.AbstractHttp11Processor.process(
> AbstractHttp11Processor.java:1078)
> at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.
> process(AbstractProtocol.java:625)
> at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.
> run(JIoEndpoint.java:316)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(
> ThreadPoolExecutor.java:1145)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(
> ThreadPoolExecutor.java:615)
> at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(
> TaskThread.java:61)
> at java.lang.Thread.run(Thread.java:748)
> Caused by: java.io.IOException: Connection refused (Connection refused)
> at org.mapfish.print.PDFUtils.handleImageLoadError(PDFUtils.java:357)
> at org.mapfish.print.PDFUtils.loadImageFromUrl(PDFUtils.java:341)
> at org.mapfish.print.PDFUtils.getImageDirect(PDFUtils.java:182)
> at org.mapfish.print.PDFUtils.getImage(PDFUtils.java:102)
> at org.mapfish.print.PDFUtils.createImage(PDFUtils.java:666)
> ... 112 more
> Please help me to overcome this issue?.
> Note:for reference attached my config.yaml file with this mail
> Thanks&Regards,
> Naresh
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170601/5a9ad9b0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170601/5a9ad9b0/attachment-0001.png>
More information about the geonode-users mailing list
