[GeoNode-users] Notes abour the windows version 2.6
Francesco Bartoli xbartolone at gmail.com
Mon Jun 5 11:06:16 PDT 2017
GeoNode 2.6 is still using geoexplorer as default webgis viewer/composer, you can optionally install and use the new react-based client which supports OL3 https://github.com/GeoNode/geonode-client#integrating-into-geonodedjango.  I don’t know why you get old libraries, maybe if confirmed you can file a ticket in our issue tracker on github https://github.com/GeoNode/geonode/issues.
Il giorno 05/giu/2017, alle ore 15:57, José Carlos Martínez Llario <jomarlla at cgf.upv.es> ha scritto:
> Hi List,
> I just installed the version 2.6 for the MS Windows from the exe build. The installation was perfect, but I was expecting some new versions from postgresql/postgis and Open layers in this Geonode 2.6 version.
> Im getting the PostgreSQL 8.4 and PostGIS 1.5 which are really old versions, and specially the map default viewer is made with Geoexplorer which is using the really old openlayers 2.13.
> Am I correct or I am doing something wrong? I read in the docs about  "A new alternative client based on the React JavaScript Framework and OpenLayers 3" and "Using recent versions of popular components and libraries such as Django, PostreSQL/PostGIS, pycsw, OWSLib". Thats why Im kind of confused.
> Cheers
> Jose
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170605/658346d8/attachment.html>
More information about the geonode-users mailing list
