[GeoNode-users] can't switch to 3D viewer
Elisa Pruvot pruvotelisa at gmail.com
Thu Jun 8 06:12:42 PDT 2017
Yes indeed I found it there : /usr/local/lib/python2.7/dist-
packages/geonode/templates/geonode
(to me it looks like it chose a random place..)
Anyway here it is the button is gone !
Thanks a lot for your help !!
2017-06-08 10:34 GMT+02:00 Jonathan Doig <j.doig at unsw.edu.au>:
> The folder location is tricky …see here:
> https://github.com/GeoNode/geonode/tree/master/geonode/templates/geonode
> *From:* Elisa Pruvot [mailto:pruvotelisa at gmail.com]
> *Sent:* Thursday, 8 June 2017 5:50 PM
> *To:* Jonathan Doig <j.doig at unsw.edu.au>
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] can't switch to 3D viewer
> Thanks for these informations Jonathan !
> I wanted to remove it from the map viewer just like shown in the link you
> gave (even though after all it's not that annoying),
> and just realised i got no file at all in /etc/geonode/templates/ !!
> and there's no geo_header.html file nor geo_header_debug.html file
> elsewhere.
> I did the installation with apt-get.
> Do you have any idea why those files are missing ?
> regards,
> Elisa
> 2017-06-08 1:37 GMT+02:00 Jonathan Doig <j.doig at unsw.edu.au>:
> Yes Google no longer supports their browser-based 3D viewer. I thought the
> button had been removed in Geonode 2.6:
> https://github.com/GeoNode/geonode/issues/2921
> Here’s how I removed the button from map view in 2.4:
> https://github.com/geosolutions-it/geonode/commit/
> d6aebeafb265ec9acb15ad27b31f192964171b52
> But just realised it’s still in the embedded map viewer in the layer page…
> Jonathan
> *From:* geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] *On
> Behalf Of *Elisa Pruvot
> *Sent:* Wednesday, 7 June 2017 11:36 PM
> *To:* geonode-users at lists.osgeo.org
> *Subject:* [GeoNode-users] can't switch to 3D viewer
> Hi all !
> Running GeoNode 2.6 on Ubuntu 16.04.
> I would like to know if the 3D viewer button is supposed to work when
> creating a map ?
> I've seen we need to add a google API key in the local_settings file, or
> that it requires a certain version of the Google Earth plugin,
> but i've also seen people writing about deleting that option because it'd
> be broken, though it's still present in the new 2.6 version.
> Should I try to get a key or is it useless ?
> if it does works, is it the Google Static Maps API I need ? there are
> several -> https://console.developers.google.com/apis/library
> or what version of google earth should I install on my machine ?
> Thanks, Elisa
> Elisa Pruvot
> M2 SIGAT
> Elisa Pruvot
> M2 SIGAT
Elisa Pruvot
M2 SIGAT
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170608/c3655e71/attachment.html>
More information about the geonode-users mailing list
