[GeoNode-users] Layer Editing Error
Francesco Bartoli xbartolone at gmail.com
Fri Jun 9 00:42:43 PDT 2017
Naresh,
the same command suggested by Simone should download the correct GeoServer version which relies on the old authentication system.
Francesco
Il giorno 09/giu/2017, alle ore 09:39, Naresh N <naresh919 at gmail.com> ha scritto:
> Dear Simone,
> I have deployed GeoNode 2.4 version. I think there is no concept of oauth in GeoNode 2.4 version.I am facing the issue with GeoNode 2.4. Please suggest how to overcome the issue in GeoNode2.4 version
> Thanks,
> Naresh
> On Fri, Jun 9, 2017 at 12:57 PM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Running "paver setup" in your geonode virtualenv will download it into the "downloaded folder" Then you will have to configure the oauth2 mechanism http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html#geonode-and-geoserver-a-a-interaction
> 2017-06-09 9:19 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>  Thanks for the response.
>  But I have configured GeoNode2.4 in my RHEL machine. In downloaded GeoNode Zip Geoserver.war file is not available. How to get shipped geoserver.war file in case of GeoNode deployment in Linux.
> Thanks,
> Naresh
> On Fri, Jun 9, 2017 at 12:44 PM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Hi,
> GeoNode requires it's own Geoserver. It is shipped with it and is version 2.9. Security and permissions won't work otherwise.
> 2017-06-09 8:58 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear ALL,
> When I am editing the layer it is showing following error. Please suggest to fix
> <ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows http://192.168.198.209/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
>   <ows:Exception exceptionCode="NoApplicableCode">
>     <ows:ExceptionText>{http://192.168.198.209/geoserver/cite}_6_9_2017_9657073 is read-only</ows:ExceptionText>
>   </ows:Exception>
> </ows:ExceptionReport>
> System Details : Geo Node is configured in RHEL7.2 64 bit machine
>                          Geoserver version 2.11.1
>                             jre version is 1.8
>  Note:  If login the geoserver with admin credential in another tab and layer editing functionality is working
> Please kindly suggest any layer security settings need to update in Geoserver2.11.1
> Thanks,
> Naresh
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/bcee8ca5/attachment-0001.html>
More information about the geonode-users mailing list
