[GeoNode-users] Layer Editing Error
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 9 07:17:21 PDT 2017
Dear Naresh, as mentioned before, geonode requires it's own geoserver that
you can get with "paver setup".
2017-06-09 15:55 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear ALL,
>  Although all the functionalities of GeoNode working except permissions of
> Layers. Please kindly help me to resolve the issue.
> 1. Layers Uploaded with  Username: XXXXX  with password:XXXX and
> permission for visualize is given to specific user. But with layer name and
> layer url with out credentials layer is loading.
>  Please help me how to over come the issue. As I mentioned in my earlier
> mail I am configured GeoNode2.4.x  in RHEL 7.2 64 bit machine.
>  Since I could not able find geoserver.war file in geonode2.4.zip file ,I
> have  downloaded  Geoserver2.7.4 war from Geoserver official site and
> followed the rest of the steps.
>  Thanks,
> Naresh
> On Fri, Jun 9, 2017 at 2:21 PM, Naresh N <naresh919 at gmail.com> wrote:
>> Dear Bartoli,Simone,
>>  Thanks for the helping. Downloaded Geosever2.7.4 war from Geoserver
>> official site and replaced  with Geoserver2.11.1, the layer editing
>> functionality is worked. Now i understand that basically issue is with
>> Geoserver version . Now I am checking all other functionalities, hoping  I
>> will not get any unexpected error/behaviour.
>> Thanks again........
>> Thanks,
>> Naresh
>> On Fri, Jun 9, 2017 at 1:12 PM, Francesco Bartoli <xbartolone at gmail.com>
>> wrote:
>>> Naresh,
>>> the same command suggested by Simone should download the correct
>>> GeoServer version which relies on the old authentication system.
>>> Francesco
>>> Il giorno 09/giu/2017, alle ore 09:39, Naresh N <naresh919 at gmail.com>
>>> ha scritto:
>>> Dear Simone,
>>> I have deployed GeoNode 2.4 version. I think there is no concept of
>>> oauth in GeoNode 2.4 version.I am facing the issue with GeoNode 2.4. Please
>>> suggest how to overcome the issue in GeoNode2.4 version
>>> Thanks,
>>> Naresh
>>> On Fri, Jun 9, 2017 at 12:57 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Running "paver setup" in your geonode virtualenv will download it into
>>>> the "downloaded folder" Then you will have to configure the oauth2
>>>> mechanism http://docs.geonode.org/en/master/tutorials/admin/
>>>> geoserver_geonode_security/index.html#geonode-and-geoserver-
>>>> a-a-interaction
>>>> 2017-06-09 9:19 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>>  Thanks for the response.
>>>>>  But I have configured GeoNode2.4 in my RHEL machine. In downloaded
>>>>> GeoNode Zip Geoserver.war file is not available. How to get shipped
>>>>> geoserver.war file in case of GeoNode deployment in Linux.
>>>>> Thanks,
>>>>> Naresh
>>>>> On Fri, Jun 9, 2017 at 12:44 PM, Simone Dalmasso <
>>>>>> Hi,
>>>>>> GeoNode requires it's own Geoserver. It is shipped with it and is
>>>>>> version 2.9. Security and permissions won't work otherwise.
>>>>>> 2017-06-09 8:58 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear ALL,
>>>>>>> When I am editing the layer it is showing following error. Please
>>>>>>> suggest to fix
>>>>>>> <ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema"
>>>>>>> xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="
>>>>>>> http://www.w3.org/2001/XMLSchema-instance" version="1.0.0"
>>>>>>> xsi:schemaLocation="http://www.opengis.net/ows
>>>>>>> http://192.168.198.209/geoserver/schemas/ows/1.0.0/owsExcept
>>>>>>> ionReport.xsd">
>>>>>>>   <ows:Exception exceptionCode="NoApplicableCode">
>>>>>>>     <ows:ExceptionText>{http://192.168.198.209/geoserver/cite}_6
>>>>>>> _9_2017_9657073 is read-only</ows:ExceptionText>
>>>>>>>   </ows:Exception>
>>>>>>> </ows:ExceptionReport>
>>>>>>> System Details : Geo Node is configured in RHEL7.2 64 bit machine
>>>>>>>                          Geoserver version 2.11.1
>>>>>>>                             jre version is 1.8
>>>>>>> * Note:  If login the geoserver with admin credential in another tab
>>>>>>> and layer editing functionality is working*
>>>>>>> *Please kindly suggest any layer security settings need to update in
>>>>>>> Geoserver2.11.1*
>>>>>>> *Thanks,*
>>>>>>> *Naresh*
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> Simone
>>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/f727ff36/attachment.html>
More information about the geonode-users mailing list
