[GeoNode-users] Fwd: can't log into geoverser with the "geonode button"
Elisa Pruvot pruvotelisa at gmail.com
Fri Jun 9 07:19:18 PDT 2017
Thanks a lot for your quick and clear answer Alessio.
I did exactly what you wrote (indeed the geoserver proxy base url was not
up to date), but it still doesn't work.
Maybe it takes a little time to update ? I even restarted my computer just
in case.
But I still get the same error message and the same url :
http://192.168.1.23/o/authorize/?response_type=code&client_id=
ue4aJt4AXIlXiiCs32OIVeMFNrQcGHsYRJgxj2Kn&scope=write&
*redirect_uri=http://127.0.0.1/geoserver/ <http://127.0.0.1/geoserver/>*
2017-06-09 15:15 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Hi,
> you need to add the new GeoServer URL on allowed Redirect URIs from
> GeoNode Admin Dashboard
> [image: Inline image 1]
> [image: Inline image 2]
> [image: Inline image 3]
> And Save.
> Also, *make sure* GeoServer Proxy Base URL has been set to* http://192.168.1.23/geoserver
> <http://192.168.1.23/geoserver>*
> *[image: Inline image 6]*
> *[image: Inline image 5]*
> And Save again.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <0584%20962313>
> fax:     +39 0584 1660272 <0584%20166%200272>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Fri, Jun 9, 2017 at 3:05 PM, Elisa Pruvot <pruvotelisa at gmail.com>
> wrote:
>> Hi all !
>> Running GeoNode 2.6 installed with ppa on ubuntu 16.04.
>> I got a new little problem i'd like to share..
>> So far I had no problem to log into GeoServer with the "geonode button"
>> on the left of the username and password fields.
>> But now that i've updated the ip (-> "sudo geonode-updateip 192.168.1.23"
>> to access geonode with others computers) it doesn't work anymore.
>> This is the error I get when i click on the "geonode button" to log in:
>> Error : invalid_request
>> Mismatching redirect URI
>> and the url field is :
>> id=ue4aJt4AXIlXiiCs32OIVeMFNrQcGHsYRJgxj2Kn&scope=write&redi
>> here is my local_settings file in case
>> I can still log into GeoServer the "old" way, but i'm logged as "admin"
>> and not with my geonode username, like it did when logging in with that new
>> geonode button.
>> Does anyone know what should i do to log into GeoServer with that button ?
>> Thanks,
>> Elisa
>> Elisa Pruvot
>> M2 SIGAT
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
Elisa Pruvot
M2 SIGAT
Elisa Pruvot
M2 SIGAT
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/9723b81f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/9723b81f/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/9723b81f/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/9723b81f/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/9723b81f/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/9723b81f/attachment-0009.png>
More information about the geonode-users mailing list
