[GeoNode-users] Cannot upload shapefiles most of the time
Jeremiah Zellers jeremiah.zellers.wf0d at statefarm.com
Tue Jun 13 12:54:57 PDT 2017
Hello again,
I’m using the Windows Binary Installer… I just uninstalled everything and downloaded GeoNode 2.6.x again. Same issues.
From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Sent: Tuesday, June 13, 2017 1:49 PM
To: Jeremiah Zellers <jeremiah.zellers.wf0d at statefarm.com>
Subject: Re: [GeoNode-users] Cannot upload shapefiles most of the time
Yeah. As I said, the Geonode geoserver is customized and you cannot just get it from the geoserver s repos.
If you install Geonode with apt-get then you'll get the right one, otherwise you have to f tech it with "paver setup" and then deploy and configure following th docs.
Ps please always keep the lists in copy as others may benefit
Il giorno mar 13 giu 2017 alle 20:40 Jeremiah Zellers <jeremiah.zellers.wf0d at statefarm.com<mailto:jeremiah.zellers.wf0d at statefarm.com>> ha scritto:
Hello,
Thank you for the response. I have installed GeoServer 2.9.4 now. When I try to upload the shapefiles that came with it, I still get the:
[Errno 10061] No connection could be made because the target machine actively refused it
and other times:
[Errno 10053] An established connection was aborted by the software in your host machine
This is all new to me. Do you know why this might be??
From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com<mailto:simone.dalmasso at gmail.com>]
Sent: Tuesday, June 13, 2017 1:07 PM
To: Jeremiah Zellers <jeremiah.zellers.wf0d at statefarm.com<mailto:jeremiah.zellers.wf0d at statefarm.com>>
Cc: geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
Hi, the geonode's 2.6 geoserver is version 2.9.x, and is shipped with it. If you used another geoserver the auth won't work.  Documents is working because is not using geoserver
2017-06-13 15:47 GMT+02:00 Jeremiah Zellers <jeremiah.zellers.wf0d at statefarm.com<mailto:jeremiah.zellers.wf0d at statefarm.com>>:
This will be a little wordy so I can present what I have tried.
1.      I am using Geonode 2.6.x and GeoServer 2.1.1.0
a.      At first I was able to get the shapefiles that came preinstalled with GeoServer to upload
To GeoNode. They already had their workspaces/stores set up ahead of time. I could NOT get shapefiles from my local system to upload. I would get a few different Errno 10061, as well as Authentication Errors. This was when I tried to upload directly from my C:\ like you can do with the GeoNode demo program.
2.      I then tried creating my own Workspace/Store/Layers through GeoServer and adding those shapefiles to GeoNode that way. I received the same errors.. despite the fact that the preinstalled GeoServer shapefiles uploaded fine.
3.      I then simply copied my shapefiles into the preinstalled GeoServer Stores where I had successfully installed from previously. This is NOT work.
4.      I uninstalled everything, reinstalled. And now I cannot even upload the preinstalled shapefiles from GeoServer like I was previously. I get Errno 10061.
I have been trying to do this for a couple of weeks. I have tried manual Windows installations with no success. I have tried Linux installations with no success.  I would really appreciate any help you can provide.
I should add… DOCUMENTS upload just fine…………….. I am profoundly confused by this.
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170613/3445c46b/attachment-0001.html>
More information about the geonode-users mailing list
