[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jun 14 23:20:12 PDT 2017
Ah I see, then is not your or geonode fault. This is an issue of that
geoserver.
2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external Geoserver
> of others and I am adding thishttp://bhuvan5.nrsc.gov.in/bhuvan/web/ url
> to GeoNode using Layers ->Add server option. It is adding but it shows the
> issue which I mentioned in my earlier mail.
> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in demo
> GeoNode site  and  can be observed same issue.
> Thanks,
> Naresh
> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>>   Earlier I faced layer issue and with your guidance i  have fixed the
>>> issue. Please find the link our earlier converstaion
>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td5323603.html
>>>  which contains the steps I followed to install.
>>>  I have verified my geoserver instance  and version is 2.7.4. Not able
>>> to understand from where you  observed my Geoserver version is 2.0.2?.
>>>  Please let me know any other information required to solve the issue
>>> Thanks,
>>> Naresh
>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>> I see that your geoserver is 2.0.2 with 2.4 it should be 2.7.x. Could
>>>> you clarify how you installed it?
>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>> _geoserver_application.html  to configure Geoserver with GeoNode
>>>>> Thanks,
>>>>> Naresh
>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear simone,
>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <naresh919 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Dear Simone,
>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org) also I have
>>>>>>>> tested with the url http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am
>>>>>>>> getting same issue. Please help me to resolve
>>>>>>>> My System details:
>>>>>>>> GeoNode 2.4 version
>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>> Hi seems that you are missing a configuration in geoserver. How
>>>>>>>>> did you install geonode?
>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver_
>>>>>>>>> geonode_security/index.html
>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear All,
>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using ADDLayrers--->
>>>>>>>>>> Addsever option the following error is getting and EDIT options getting
>>>>>>>>>> enabled.
>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>> Please also find the attached screenshot with this mail. The WMS
>>>>>>>>>> url  added  is http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/8fed1ac5/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/8fed1ac5/attachment-0001.png>
More information about the geonode-users mailing list
