[GeoNode-users] geonode database for user account layer list , and about erd
Cezary Statkiewicz cezary.statkiewicz at geo-solutions.it
Wed Jun 14 23:40:12 PDT 2017
On Thursday, June 15, 2017 7:28:21 AM CEST Simone Dalmasso wrote:
> Hi, I don't think there's such diagram. The description of the geonode
> tables are the django models which you can find in the geonode codebase,
> models.py files.
> 2017-06-15 2:11 GMT+02:00 원영진 <icetiger at nate.com>:
> > We are studying GEONODE for our business and It helps so much more than we
> > imagined.
> > I am searching the information about database which stores users , layers
> > and so on.
> > And at last I found the database and tables in my postgresql
> > But I can not find the database document in the internet
> > The description about each table, filed and erd(entity relationship
> > diagram)
> > Is there something for reference?
> > I look forward to hearing from you soon.
> > Thank you.
 Side note: you can generate model diagram with graph_models command (provided
by django_extensions app). You'll need to install pydot or pygraphviz for
image output.
 To get diagram image for all apps (using pydot), call:
 ./manage.py  graph_models  --all-applications --verbose-names --pydot --
 Best Regards,
 Cezary Statkiewicz
Regards,
Cezary Statkiewicz
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Cezary Statkiewicz
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
http://www.geo-solutions.it
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo
dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the
attention and use of the named addressee(s) and may be confidential or
proprietary in nature or covered by the provisions of privacy act (Legislative
Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not
in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly
forbidden except previous formal approval of the named addressee(s). If you
are not the intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message that has
been received in error. The sender does not give any warranty or accept
liability as the content, accuracy or completeness of sent messages and
accepts no responsibility  for changes made after they were sent or for other
risks which arise as a result of e-mail transmission, viruses, etc.
More information about the geonode-users mailing list
