[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Thu Jun 15 00:42:33 PDT 2017
Dear Simone,
  Thanks for the replies. Is any other External WMS Layer url is available
,please share me to test.  Is that any mechanism is available in case if
WFS of Geoserver is disabled,not enabling EDIT option while reading error
code.
Thanks,
Naresh
On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Ah I see, then is not your or geonode fault. This is an issue of that
> geoserver.
> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external Geoserver
>> of others and I am adding thishttp://bhuvan5.nrsc.gov.in/bhuvan/web/ url
>> to GeoNode using Layers ->Add server option. It is adding but it shows the
>> issue which I mentioned in my earlier mail.
>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in demo
>> GeoNode site  and  can be observed same issue.
>> Thanks,
>> Naresh
>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>>   Earlier I faced layer issue and with your guidance i  have fixed the
>>>> issue. Please find the link our earlier converstaion
>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td5323603.html
>>>>  which contains the steps I followed to install.
>>>>  I have verified my geoserver instance  and version is 2.7.4. Not able
>>>> to understand from where you  observed my Geoserver version is 2.0.2?.
>>>>  Please let me know any other information required to solve the issue
>>>> Thanks,
>>>> Naresh
>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be 2.7.x. Could
>>>>> you clarify how you installed it?
>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>>> _geoserver_application.html  to configure Geoserver with GeoNode
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear simone,
>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Dear Simone,
>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org) also I have
>>>>>>>>> tested with the url http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I
>>>>>>>>> am getting same issue. Please help me to resolve
>>>>>>>>> My System details:
>>>>>>>>> GeoNode 2.4 version
>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>> Hi seems that you are missing a configuration in geoserver. How
>>>>>>>>>> did you install geonode?
>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver_
>>>>>>>>>> geonode_security/index.html
>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear All,
>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using ADDLayrers--->
>>>>>>>>>>> Addsever option the following error is getting and EDIT options getting
>>>>>>>>>>> enabled.
>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>> Please also find the attached screenshot with this mail. The WMS
>>>>>>>>>>> url  added  is http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/11185254/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/11185254/attachment-0001.png>
More information about the geonode-users mailing list
