[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 16 04:38:02 PDT 2017
Not a good idea to modify the python files, You can add the
PROXY_ALLOWED_HOSTS in settings.
Anyway, seems you are running under ssl. Seems a misconfiguration of it.
2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>  I have tried with the url provided http://demo.genode.org/geoserver/wms,
> getting the following error.
> [image: Inline image 1]
> *Please find the apaahe error log file and attached views.py file from
> proxy folder of geonode for the reference. In view.py in line no: 37 is
> modified (commented host name and placed IP adrdress of GeoNode installed
> system)*
> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal Server
> Error: /proxy/
> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback (most
> recent call last):
> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line
> 112, in get_response
> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]     response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
> conn.request(request.method, locator, request.body, headers)
> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
> "/usr/lib64/python2.7/httplib.py", line 1017, in request
> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
> self._send_request(method, url, body, headers)
> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
> self.endheaders(body)
> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
> self._send_output(message_body)
> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]     self.send(msg)
> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
> "/usr/lib64/python2.7/httplib.py", line 826, in send
> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]     self.connect()
> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
> "/usr/lib64/python2.7/httplib.py", line 807, in connect
> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]     self.timeout,
> self.source_address)
> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise err
> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error: [Errno 111]
> Connection refused
> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal Server
> Error: /proxy/
> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback (most
> recent call last):
> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]     response =
> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]     self.send(msg)
> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]     self.connect()
> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]     self.timeout,
> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise err
> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error: [Errno 111]
> Connection refused
> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208] Misconfiguration of
> certificate's CN and virtual name. The certificate CN has
> localhost4.localdomain4. We expected localhost.localdomain as virtual name.
> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library Error:
> -12263 SSL received a record that exceeded the maximum permissible length
> Please kindly suggest me, do i need to modify some where else?
> Thanks,
> Naresh
> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com> wrote:
>> Dear Simone,
>>   Thanks. I will try with the provided url.
>> Thanks,
>> Naresh
>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> You can try with http://demo.geonode.org/geoserver/wms. Not sure about
>>> our other question, don't think is possible in the standard code.
>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>>   Thanks for the replies. Is any other External WMS Layer url is
>>>> available ,please share me to test.  Is that any mechanism is available in
>>>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>>>> error code.
>>>> Thanks,
>>>> Naresh
>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>> Ah I see, then is not your or geonode fault. This is an issue of that
>>>>> geoserver.
>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>>>>> Geoserver of others and I am adding thishttp://bhuvan5.nrsc.gov.in
>>>>>> /bhuvan/web/ url to GeoNode using Layers ->Add server option. It is
>>>>>> adding but it shows the issue which I mentioned in my earlier mail.
>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in
>>>>>> demo GeoNode site  and  can be observed same issue.
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>>   Earlier I faced layer issue and with your guidance i  have fixed
>>>>>>>> the issue. Please find the link our earlier converstaion
>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td53
>>>>>>>> 23603.html  which contains the steps I followed to install.
>>>>>>>>  I have verified my geoserver instance  and version is 2.7.4. Not
>>>>>>>> able to understand from where you  observed my Geoserver version is 2.0.2?.
>>>>>>>>  Please let me know any other information required to solve the
>>>>>>>> issue
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be 2.7.x.
>>>>>>>>> Could you clarify how you installed it?
>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>>>>>>> _geoserver_application.html  to configure Geoserver with GeoNode
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org) also I
>>>>>>>>>>>>> have tested with the url http://bhuvan5.nrsc.gov.in/bhuvan/wms
>>>>>>>>>>>>>    , I am getting same issue. Please help me to resolve
>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>> Hi seems that you are missing a configuration in geoserver.
>>>>>>>>>>>>>> How did you install geonode?
>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver_
>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>> Please also find the attached screenshot with this mail. The
>>>>>>>>>>>>>>> WMS url  added  is http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/9f1bfc86/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/9f1bfc86/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/9f1bfc86/attachment-0003.png>
More information about the geonode-users mailing list
