[GeoNode-users] Installation Problems with version 2.6 on Ubuntu 16.04
Simone Dalmasso simone.dalmasso at gmail.com
Mon Jun 19 22:53:34 PDT 2017
@Cliff, could you describe again how you install GeoNode? if using apt-get
you should get errors during installation, please report them here.
@Israel, that is just an info due to db design, we can clean it up in the
future but is not an issue.
2017-06-19 22:46 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
> No previous version installed. It was installed on a fresh OS.
> On Jun 19, 2017 4:43 PM, "Israel López" <asralf at gmail.com> wrote:
> Hi, did you have a previous version of genode installed???
> I'm testing Geonode 2.6 too, but on Develoment mode, I had similar issues,
> but "log-in" problem I solved running the create superuser command again.
> The issue that remains is this one:
> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
> ManyToManyField.
> I don't understand it, but Geonode is running and working, if somebody
> could explain me
> how to fix it I will appreciate it.
> Greetings.
> 2017-06-19 11:29 GMT-05:00 Cliff Patterson <cliffpatterson at gmail.com>:
>> I finally reinstalled on a clean Ubuntu 16.04.2 (64 bit) VPS with 4GB of
>> ram and still having the same issues:
>>    1. Unable to log in with superuser credentials
>>    2. unable to fully update IP. The system hangs at "Inspecting the
>>    available layers in GeoServer ..."
>>    3. Getting the following warning during install and when running
>>    createssuperuser:
>> WARNINGS:
>> ?: (1_8.W001) The standalone TEMPLATE_* settings were deprecated in
>> Django 1.8 and the TEMPLATES dictionary takes precedence. You must put the
>> values of the following settings into your default TEMPLATES dict:
>> TEMPLATE_DIRS.
>> ManyToManyField.
>> Bottom line, even on a 4GB machine, I cannot get Geonode working. Have
>> the installation instructions changed or am I missing some critical step?
>> I'm using these: http://geonode.org/blog/2017/05/17/geonode-2.6-released/
>> Big thanks!
>> Cliff
>> On Fri, Jun 9, 2017 at 7:25 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi, well 2 GB are probably not enough. 4GB are the minimum I think. You
>>> shopuld be able to find geoserver with locate geoserver, it is uncompressed
>>> in /usr/share if I'm no wrong.
>>> 2017-06-09 13:03 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
>>>> Thanks for the reply!
>>>> I didn't see any errors (except for template warnings) during
>>>> installation. I even saw that geonode-geoserver was installed but I can't
>>>> find it post installation.
>>>> I spun it up on a VM with 4 cores and 2GB of ram on Digital Ocean. Is
>>>> this enough power for GeoNode?
>>>> Thanks again for your help!
>>>> Cheers,
>>>> Cliff
>>>> On Jun 9, 2017 3:17 AM, "Simone Dalmasso" <simone.dalmasso at gmail.com>
>>>> wrote:
>>>>> Hi, yes definitely geoserver needs to be there and the package should
>>>>> install it. Make sure your machine is powerful enough, also during the
>>>>> installation you should have gotten some errors.
>>>>> 2017-06-08 18:22 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
>>>>>> PS: and I am unable to authenticate via the geonode website.
>>>>>> On Thu, Jun 8, 2017 at 12:20 PM, Cliff Patterson <
>>>>>> cliffpatterson at gmail.com> wrote:
>>>>>>> Hello,
>>>>>>> I decided to give Geonode 2.6 a go and installed it on a fresh VM
>>>>>>> running Ubuntu 16.04.2 x64. I installed it with the following commands:
>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>> sudo apt-get update
>>>>>>> sudo apt-get install geonode
>>>>>>> geonode createsuperuser
>>>>>>> sudo geonode-updateip 67.207.87.119
>>>>>>> When creating the super user, I get the following warning:
>>>>>>> System check identified some issues:
>>>>>>> WARNINGS:
>>>>>>> TEMPLATE_DIRS.
>>>>>>> ManyToManyField.
>>>>>>> Username: test
>>>>>>> Email address:
>>>>>>> Password:
>>>>>>> Password (again):
>>>>>>> Superuser created successfully.
>>>>>>> When running sudo geonode-updateip 67.207.87.119, the following
>>>>>>> happens:
>>>>>>> 1) Hangs on "Inspecting the available layers in GeoServer ..."
>>>>>>> 2) Geonode does get up and running at 67.207.87.119 but no ability
>>>>>>> to login
>>>>>>> Replacing SITEURL value with '67.207.87.119' in
>>>>>>> /etc/geonode/local_settings.py ... done.
>>>>>>> Adding entry for '67.207.87.119' in /usr/share/geoserver/data/printing/config.yaml
>>>>>>> ... done.
>>>>>>> Adding ALLOWED_HOSTS with in /etc/geonode/local_settings.py ... done.
>>>>>>> Setting up oauth
>>>>>>> Am I missing something in the instructions? Do we need to install
>>>>>>> Geoserver on Tomcat7 first, then Geonode? As far as I can see, Geoserver
>>>>>>> has not been installed, which I thought was part of the geonode
>>>>>>> installation, but I could be wrong.
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Simone
>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/ac038df9/attachment.html>
More information about the geonode-users mailing list
