[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 20 00:49:55 PDT 2017
Naresh, you should add the fase2kort.klimatilpasning.dk
<http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
there.
I tested locally and seems to work.
2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS =
> ('192.168.198.209', ) the error, str and tupple can not be concatenated is
> solved.
> How ever, not able to add any WMS Layer url, it is showing the following
> error.
> For example Layer URL: http://fase2kort.klimatilpasni
> ng.dk:80/geoserver/wms. Getting the following error.
> Internal Server Error: /proxy/
> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback (most
> recent call last):
> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line
> 112, in get_response
> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
> conn.request(request.method, locator, request.body, headers)
> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
> "/usr/lib64/python2.7/httplib.py", line 1017, in request
> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
> self._send_request(method, url, body, headers)
> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
> self.endheaders(body)
> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
> self._send_output(message_body)
> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629] self.send(msg)
> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
> "/usr/lib64/python2.7/httplib.py", line 826, in send
> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629] self.connect()
> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
> "/usr/lib64/python2.7/httplib.py", line 807, in connect
> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629] self.timeout,
> self.source_address)
> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error: [Errno 111]
> Connection refused
> Even I went to httplib.py and socket.py with the alerts I could able to
> see the following WMS server IP and port details ('188.64.159.9', 80) and
> source_address is none
> Please help me how to resolve the issue, is that any where my GeoNode
> Deployed System Ip need to place?
> Thanks,
> Naresh
> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> It must be an array and not a tuple.
>> I don't know what ssl misconfiguration could be
>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com> ha
>> scritto:
>>> Dear Simone,
>>> Now I added in settings.py PROXY_ALLOWED_HOSTS = ('192.168.198.209')
>>> and in proxy/views.py linenumber: 37 is reverted means removed ip adress
>>> and kept as hostname. It is showing following error
>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal Server
>>> Error: /proxy/
>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback (most
>>> recent call last):
>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response =
>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>> PROXY_ALLOWED_HOSTS +=hostname
>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError: cannot
>>> concatenate 'str' and 'tuple' objects
>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal Server
>>> Error: /proxy/
>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback (most
>>> recent call last):
>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response =
>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>> cannot concatenate 'str' and 'tuple' objects*
>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622] Misconfiguration
>>> of certificate's CN and virtual name. The certificate CN has
>>> localhost4.localdomain4. We expected localhost.localdomain as virtual name.
>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library
>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>> length
>>> if in proxy/views.py if i add in place of hostname ip adress of the
>>> GeoNode, The error '*TypeError: cannot concatenate 'str' and 'tuple'
>>> objects ' *will go, how ever the error which I mentioned in my earlier
>>> mail retains.
>>> Please suggest how to overcome above error '*TypeError: cannot
>>> concatenate 'str' and 'tuple' objects ' *with out editing proxy/views.py
>>> And also kindly suggest me how to correct misconfiguration of SSL error,
>>> since I am not using https any where
>>> Thanks,
>>> Naresh
>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>> Not a good idea to modify the python files, You can add the
>>>> PROXY_ALLOWED_HOSTS in settings.
>>>> Anyway, seems you are running under ssl. Seems a misconfiguration of it.
>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>>  I have tried with the url provided http://demo.genode.org/geoserv
>>>>> er/wms, getting the following error.
>>>>> [image: Inline image 1]
>>>>> *Please find the apaahe error log file and attached views.py file from
>>>>> proxy folder of geonode for the reference. In view.py in line no: 37 is
>>>>> modified (commented host name and placed IP adrdress of GeoNode installed
>>>>> system)*
>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal Server
>>>>> Error: /proxy/
>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback (most
>>>>> recent call last):
>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]     response =
>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>> self.send(msg)
>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>> self.connect()
>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>> self.timeout, self.source_address)
>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise err
>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error: [Errno
>>>>> 111] Connection refused
>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal Server
>>>>> Error: /proxy/
>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback (most
>>>>> recent call last):
>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]     response =
>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>> self.send(msg)
>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>> self.connect()
>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise err
>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error: [Errno
>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>> name.
>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library
>>>>> length
>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>> Thanks,
>>>>> Naresh
>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com> wrote:
>>>>>> Dear Simone,
>>>>>>   Thanks. I will try with the provided url.
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not sure
>>>>>>> about our other question, don't think is possible in the standard code.
>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>>   Thanks for the replies. Is any other External WMS Layer url is
>>>>>>>> available ,please share me to test.  Is that any mechanism is available in
>>>>>>>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>>>>>>>> error code.
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>> Ah I see, then is not your or geonode fault. This is an issue of
>>>>>>>>> that geoserver.
>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>>>>>>>>> Geoserver of others and I am adding this
>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode using
>>>>>>>>>> Layers ->Add server option. It is adding but it shows the issue which I
>>>>>>>>>> mentioned in my earlier mail.
>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in
>>>>>>>>>> demo GeoNode site  and  can be observed same issue.
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance i  have
>>>>>>>>>>>> fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td53
>>>>>>>>>>>> 23603.html  which contains the steps I followed to install.
>>>>>>>>>>>>  I have verified my geoserver instance  and version is 2.7.4.
>>>>>>>>>>>> Not able to understand from where you  observed my Geoserver version is
>>>>>>>>>>>> 2.0.2?.
>>>>>>>>>>>>  Please let me know any other information required to solve the
>>>>>>>>>>>> issue
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be
>>>>>>>>>>>>> 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>>>>>>>>>>> _geoserver_application.html  to configure Geoserver with
>>>>>>>>>>>>>> GeoNode
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org)
>>>>>>>>>>>>>>>>> also I have tested with the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>> /bhuvan/wms   , I am getting same issue. Please help me
>>>>>>>>>>>>>>>>> to resolve
>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_geonode_security/index.html
>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this mail.
>>>>>>>>>>>>>>>>>>> The WMS url  added  is http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>>>>> van/wms.
>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>>>>> van/wms* tested with GeoNode demo site  and facing
>>>>>>>>>>>>>>>>>>> similar  issue as above*
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/44b406d7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/44b406d7/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/44b406d7/attachment-0003.png>
More information about the geonode-users mailing list
