[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 20 01:41:04 PDT 2017
At this point I would check your local internet connection, are you behind
a proxy that may block it?
2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>   Thanks for the responding.  As per I understand from below code in the
> proxy/views.py
> if not settings.DEBUG:
>         if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>             return HttpResponse("DEBUG is set to False but the host of the
> path provided to the proxy service"
>                                 " is not in the PROXY_ALLOWED_HOSTS
> setting.",
>                                 status=403,
>                                 content_type="text/plain"
>  if GeoNode  debug mode value is flase, the wms url may not be required to
> add in  PROXY_ALLOWED_HOSTS. And even if debug mode value is ture, it
> should show the following error 'DEBUG is set to False but the host of
> the path provided to the proxy service"
> setting',. In my case nothing this kind of error/alert message is not
> getting
> And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode site, it
> is fetching the layers
> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it is showing
> same error.
> I have been trying from last two days to overcome this issue, but not able
> to do. Please suggest anywhere more I need to investigate the code/settings?
> Thanks,
> Naresh
> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Naresh, you should add the fase2kort.klimatilpasning.dk
>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
>> PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
>> there.
>> I tested locally and seems to work.
>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>> is solved.
>>> How ever, not able to add any WMS Layer url, it is showing the following
>>> error.
>>> For example Layer URL: http://fase2kort.klimatilpasni
>>> ng.dk:80/geoserver/wms. Getting the following error.
>>> Internal Server Error: /proxy/
>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback (most
>>> recent call last):
>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line
>>> 112, in get_response
>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
>>> wrapped_callback(request, *callback_args, **callback_kwargs)
>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>> conn.request(request.method, locator, request.body, headers)
>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>> self._send_request(method, url, body, headers)
>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>> self.endheaders(body)
>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>> self._send_output(message_body)
>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629] self.send(msg)
>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629] self.connect()
>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629] self.timeout,
>>> self.source_address)
>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error: [Errno
>>> 111] Connection refused
>>> Even I went to httplib.py and socket.py with the alerts I could able to
>>> see the following WMS server IP and port details ('188.64.159.9', 80) and
>>> source_address is none
>>> Please help me how to resolve the issue, is that any where my GeoNode
>>> Deployed System Ip need to place?
>>> Thanks,
>>> Naresh
>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>> It must be an array and not a tuple.
>>>> I don't know what ssl misconfiguration could be
>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com> ha
>>>> scritto:
>>>>> Dear Simone,
>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS = ('192.168.198.209')
>>>>> and in proxy/views.py linenumber: 37 is reverted means removed ip adress
>>>>> and kept as hostname. It is showing following error
>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal Server
>>>>> Error: /proxy/
>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback (most
>>>>> recent call last):
>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response =
>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError:
>>>>> cannot concatenate 'str' and 'tuple' objects
>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal Server
>>>>> Error: /proxy/
>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback (most
>>>>> recent call last):
>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response =
>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>> name.
>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library
>>>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>>>> length
>>>>> if in proxy/views.py if i add in place of hostname ip adress of the
>>>>> GeoNode, The error '*TypeError: cannot concatenate 'str' and 'tuple'
>>>>> objects ' *will go, how ever the error which I mentioned in my
>>>>> earlier mail retains.
>>>>> Please suggest how to overcome above error '*TypeError: cannot
>>>>> concatenate 'str' and 'tuple' objects ' *with out editing
>>>>> proxy/views.py
>>>>> And also kindly suggest me how to correct misconfiguration of SSL
>>>>> error, since I am not using https any where
>>>>> Thanks,
>>>>> Naresh
>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>> Not a good idea to modify the python files, You can add the
>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>> Anyway, seems you are running under ssl. Seems a misconfiguration of
>>>>>> it.
>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>>  I have tried with the url provided http://demo.genode.org/geoserv
>>>>>>> er/wms, getting the following error.
>>>>>>> [image: Inline image 1]
>>>>>>> *Please find the apaahe error log file and attached views.py file
>>>>>>> from proxy folder of geonode for the reference. In view.py in line no: 37
>>>>>>> is modified (commented host name and placed IP adrdress of GeoNode
>>>>>>> installed system)*
>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal
>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback
>>>>>>> (most recent call last):
>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>>>>>> line 112, in get_response
>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]     response
>>>>>>> = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>> self.send(msg)
>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>> self.connect()
>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>> self.timeout, self.source_address)
>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>>>>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise err
>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error: [Errno
>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal
>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback
>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]     response
>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>> self.send(msg)
>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>> self.connect()
>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise err
>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error: [Errno
>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>> name.
>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library
>>>>>>> length
>>>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Dear Simone,
>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not sure
>>>>>>>>> about our other question, don't think is possible in the standard code.
>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>   Thanks for the replies. Is any other External WMS Layer url is
>>>>>>>>>> available ,please share me to test.  Is that any mechanism is available in
>>>>>>>>>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>>>>>>>>>> error code.
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an issue of
>>>>>>>>>>> that geoserver.
>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>>>>>>>>>>> Geoserver of others and I am adding this
>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode using
>>>>>>>>>>>> Layers ->Add server option. It is adding but it shows the issue which I
>>>>>>>>>>>> mentioned in my earlier mail.
>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms
>>>>>>>>>>>> . in demo GeoNode site  and  can be observed same issue.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance i  have
>>>>>>>>>>>>>> fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td53
>>>>>>>>>>>>>> 23603.html  which contains the steps I followed to install.
>>>>>>>>>>>>>>  I have verified my geoserver instance  and version is 2.7.4.
>>>>>>>>>>>>>> Not able to understand from where you  observed my Geoserver version is
>>>>>>>>>>>>>> 2.0.2?.
>>>>>>>>>>>>>>  Please let me know any other information required to solve
>>>>>>>>>>>>>> the issue
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be
>>>>>>>>>>>>>>> 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>> _admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>>>>>> to configure Geoserver with GeoNode
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org)
>>>>>>>>>>>>>>>>>>> also I have tested with the url
>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am getting
>>>>>>>>>>>>>>>>>>> same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this
>>>>>>>>>>>>>>>>>>>>> mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>>>>>>> van/wms* tested with GeoNode demo site  and facing
>>>>>>>>>>>>>>>>>>>>> similar  issue as above*
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/09b249ac/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/09b249ac/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/09b249ac/attachment-0003.png>
More information about the geonode-users mailing list
