[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Tue Jun 20 02:00:43 PDT 2017
Dear Simone,
  Yes we are in office campus, we are using proxy server. So  is this the
reason?  if so where I need to do the changes?
Thanks,
Naresh
On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> At this point I would check your local internet connection, are you behind
> a proxy that may block it?
> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>>   Thanks for the responding.  As per I understand from below code in the
>> proxy/views.py
>> if not settings.DEBUG:
>>         if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>>             return HttpResponse("DEBUG is set to False but the host of
>> the path provided to the proxy service"
>>                                 " is not in the PROXY_ALLOWED_HOSTS
>> setting.",
>>                                 status=403,
>>                                 content_type="text/plain"
>>  if GeoNode  debug mode value is flase, the wms url may not be required
>> to add in  PROXY_ALLOWED_HOSTS. And even if debug mode value is ture, it
>> should show the following error 'DEBUG is set to False but the host of
>> setting',. In my case nothing this kind of error/alert message is not
>> getting
>> And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode site, it
>> is fetching the layers
>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it is
>> showing same error.
>> I have been trying from last two days to overcome this issue, but not
>> able to do. Please suggest anywhere more I need to investigate the
>> code/settings?
>> Thanks,
>> Naresh
>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
>>> PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
>>> there.
>>> I tested locally and seems to work.
>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>> is solved.
>>>> How ever, not able to add any WMS Layer url, it is showing the
>>>> following error.
>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>> Internal Server Error: /proxy/
>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback (most
>>>> recent call last):
>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line
>>>> 112, in get_response
>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
>>>> wrapped_callback(request, *callback_args, **callback_kwargs)
>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>> conn.request(request.method, locator, request.body, headers)
>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>> self._send_request(method, url, body, headers)
>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>> self.endheaders(body)
>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>> self._send_output(message_body)
>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629] self.send(msg)
>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629] self.connect()
>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629] self.timeout,
>>>> self.source_address)
>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error: [Errno
>>>> 111] Connection refused
>>>> Even I went to httplib.py and socket.py with the alerts I could able to
>>>> see the following WMS server IP and port details ('188.64.159.9', 80) and
>>>> source_address is none
>>>> Please help me how to resolve the issue, is that any where my GeoNode
>>>> Deployed System Ip need to place?
>>>> Thanks,
>>>> Naresh
>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>> It must be an array and not a tuple.
>>>>> I don't know what ssl misconfiguration could be
>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com>
>>>>> ha scritto:
>>>>>> Dear Simone,
>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS = ('192.168.198.209')
>>>>>> and in proxy/views.py linenumber: 37 is reverted means removed ip adress
>>>>>> and kept as hostname. It is showing following error
>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal
>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback
>>>>>> (most recent call last):
>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>>>>> line 112, in get_response
>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response =
>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError:
>>>>>> cannot concatenate 'str' and 'tuple' objects
>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal
>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback
>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response =
>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>> name.
>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library
>>>>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>>>>> length
>>>>>> if in proxy/views.py if i add in place of hostname ip adress of the
>>>>>> GeoNode, The error '*TypeError: cannot concatenate 'str' and 'tuple'
>>>>>> objects ' *will go, how ever the error which I mentioned in my
>>>>>> earlier mail retains.
>>>>>> Please suggest how to overcome above error '*TypeError: cannot
>>>>>> concatenate 'str' and 'tuple' objects ' *with out editing
>>>>>> proxy/views.py
>>>>>> And also kindly suggest me how to correct misconfiguration of SSL
>>>>>> error, since I am not using https any where
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>> Not a good idea to modify the python files, You can add the
>>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>>> Anyway, seems you are running under ssl. Seems a misconfiguration of
>>>>>>> it.
>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>>  I have tried with the url provided http://demo.genode.org/geoserv
>>>>>>>> er/wms, getting the following error.
>>>>>>>> [image: Inline image 1]
>>>>>>>> *Please find the apaahe error log file and attached views.py file
>>>>>>>> from proxy folder of geonode for the reference. In view.py in line no: 37
>>>>>>>> is modified (commented host name and placed IP adrdress of GeoNode
>>>>>>>> installed system)*
>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal
>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback
>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]     response
>>>>>>>> = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>> self.send(msg)
>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>> self.connect()
>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>> self.timeout, self.source_address)
>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>>>>>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise err
>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error:
>>>>>>>> [Errno 111] Connection refused
>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal
>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback
>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]     response
>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>> self.send(msg)
>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>> self.connect()
>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise err
>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error:
>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>> name.
>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library
>>>>>>>> length
>>>>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Dear Simone,
>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not sure
>>>>>>>>>> about our other question, don't think is possible in the standard code.
>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>   Thanks for the replies. Is any other External WMS Layer url is
>>>>>>>>>>> available ,please share me to test.  Is that any mechanism is available in
>>>>>>>>>>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>>>>>>>>>>> error code.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an issue
>>>>>>>>>>>> of that geoserver.
>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode using
>>>>>>>>>>>>> Layers ->Add server option. It is adding but it shows the issue which I
>>>>>>>>>>>>> mentioned in my earlier mail.
>>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>> /bhuvan/wms. in demo GeoNode site  and  can be observed same
>>>>>>>>>>>>> issue.
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance i  have
>>>>>>>>>>>>>>> fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td53
>>>>>>>>>>>>>>> 23603.html  which contains the steps I followed to install.
>>>>>>>>>>>>>>>  I have verified my geoserver instance  and version is
>>>>>>>>>>>>>>> 2.7.4. Not able to understand from where you  observed my Geoserver version
>>>>>>>>>>>>>>> is 2.0.2?.
>>>>>>>>>>>>>>>  Please let me know any other information required to solve
>>>>>>>>>>>>>>> the issue
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be
>>>>>>>>>>>>>>>> 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>> _admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>>>>>>> to configure Geoserver with GeoNode
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org)
>>>>>>>>>>>>>>>>>>>> also I have tested with the url
>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am getting
>>>>>>>>>>>>>>>>>>>> same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this
>>>>>>>>>>>>>>>>>>>>>> mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>>>>>>>> van/wms* tested with GeoNode demo site  and facing
>>>>>>>>>>>>>>>>>>>>>> similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/8e2d8beb/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/8e2d8beb/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/8e2d8beb/attachment-0003.png>
More information about the geonode-users mailing list
