[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 20 02:44:57 PDT 2017
It might be. Are you able to access that wms backend from in the browser?
http://fase2kort.klimatilpasning.dk:80/geoserver/wms
<http://fase2kort.klimatilpasning.dk/geoserver/wms>
it should give you an XML containing the geoserver error related to missing
request parameter.
2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>   Yes we are in office campus, we are using proxy server. So  is this the
> reason?  if so where I need to do the changes?
> Thanks,
> Naresh
> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> At this point I would check your local internet connection, are you
>> behind a proxy that may block it?
>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>>   Thanks for the responding.  As per I understand from below code in the
>>> proxy/views.py
>>> if not settings.DEBUG:
>>>         if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>>>             return HttpResponse("DEBUG is set to False but the host of
>>> the path provided to the proxy service"
>>>                                 " is not in the PROXY_ALLOWED_HOSTS
>>> setting.",
>>>                                 status=403,
>>>                                 content_type="text/plain"
>>>  if GeoNode  debug mode value is flase, the wms url may not be required
>>> to add in  PROXY_ALLOWED_HOSTS. And even if debug mode value is ture,
>>> it should show the following error 'DEBUG is set to False but the host
>>> of the path provided to the proxy service"
>>> setting',. In my case nothing this kind of error/alert message is not
>>> getting
>>> And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode site, it
>>> is fetching the layers
>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it is
>>> showing same error.
>>> I have been trying from last two days to overcome this issue, but not
>>> able to do. Please suggest anywhere more I need to investigate the
>>> code/settings?
>>> Thanks,
>>> Naresh
>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
>>>> PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
>>>> there.
>>>> I tested locally and seems to work.
>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>> is solved.
>>>>> How ever, not able to add any WMS Layer url, it is showing the
>>>>> following error.
>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>> Internal Server Error: /proxy/
>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback (most
>>>>> recent call last):
>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line
>>>>> 112, in get_response
>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
>>>>> wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>> conn.request(request.method, locator, request.body, headers)
>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>> self._send_request(method, url, body, headers)
>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>> self.endheaders(body)
>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>> self._send_output(message_body)
>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629] self.send(msg)
>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629] self.connect()
>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629] self.timeout,
>>>>> self.source_address)
>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error: [Errno
>>>>> 111] Connection refused
>>>>> Even I went to httplib.py and socket.py with the alerts I could able
>>>>> to see the following WMS server IP and port details ('188.64.159.9', 80)
>>>>> and source_address is none
>>>>> Please help me how to resolve the issue, is that any where my GeoNode
>>>>> Deployed System Ip need to place?
>>>>> Thanks,
>>>>> Naresh
>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>> It must be an array and not a tuple.
>>>>>> I don't know what ssl misconfiguration could be
>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com>
>>>>>> ha scritto:
>>>>>>> Dear Simone,
>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal
>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback
>>>>>>> (most recent call last):
>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>>>>>> line 112, in get_response
>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response
>>>>>>> = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError:
>>>>>>> cannot concatenate 'str' and 'tuple' objects
>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal
>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback
>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response
>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>> name.
>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library
>>>>>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>>>>>> length
>>>>>>> if in proxy/views.py if i add in place of hostname ip adress of the
>>>>>>> GeoNode, The error '*TypeError: cannot concatenate 'str' and
>>>>>>> 'tuple' objects ' *will go, how ever the error which I mentioned in
>>>>>>> my earlier mail retains.
>>>>>>> Please suggest how to overcome above error '*TypeError: cannot
>>>>>>> concatenate 'str' and 'tuple' objects ' *with out editing
>>>>>>> proxy/views.py
>>>>>>> And also kindly suggest me how to correct misconfiguration of SSL
>>>>>>> error, since I am not using https any where
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>> Not a good idea to modify the python files, You can add the
>>>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>>>> Anyway, seems you are running under ssl. Seems a misconfiguration
>>>>>>>> of it.
>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone,
>>>>>>>>>  I have tried with the url provided http://demo.genode.org/geoserv
>>>>>>>>> er/wms, getting the following error.
>>>>>>>>> [image: Inline image 1]
>>>>>>>>> *Please find the apaahe error log file and attached views.py file
>>>>>>>>> from proxy folder of geonode for the reference. In view.py in line no: 37
>>>>>>>>> is modified (commented host name and placed IP adrdress of GeoNode
>>>>>>>>> installed system)*
>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal
>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback
>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>> self.send(msg)
>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>> self.connect()
>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise
>>>>>>>>> err
>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error:
>>>>>>>>> [Errno 111] Connection refused
>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal
>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback
>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>> self.send(msg)
>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>> self.connect()
>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise
>>>>>>>>> err
>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error:
>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>> name.
>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library
>>>>>>>>> length
>>>>>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not
>>>>>>>>>>> sure about our other question, don't think is possible in the standard code.
>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS Layer url
>>>>>>>>>>>> is available ,please share me to test.  Is that any mechanism is available
>>>>>>>>>>>> in case if WFS of Geoserver is disabled,not enabling EDIT option while
>>>>>>>>>>>> reading error code.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an issue
>>>>>>>>>>>>> of that geoserver.
>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode using
>>>>>>>>>>>>>> Layers ->Add server option. It is adding but it shows the issue which I
>>>>>>>>>>>>>> mentioned in my earlier mail.
>>>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>> /bhuvan/wms. in demo GeoNode site  and  can be observed same
>>>>>>>>>>>>>> issue.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance i
>>>>>>>>>>>>>>>>  have fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html  which contains
>>>>>>>>>>>>>>>> the steps I followed to install.
>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and version is
>>>>>>>>>>>>>>>> 2.7.4. Not able to understand from where you  observed my Geoserver version
>>>>>>>>>>>>>>>> is 2.0.2?.
>>>>>>>>>>>>>>>>  Please let me know any other information required to solve
>>>>>>>>>>>>>>>> the issue
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be
>>>>>>>>>>>>>>>>> 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>> _admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>>>>>>>> to configure Geoserver with GeoNode
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation
>>>>>>>>>>>>>>>>>>>>> of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org)
>>>>>>>>>>>>>>>>>>>>> also I have tested with the url
>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am
>>>>>>>>>>>>>>>>>>>>> getting same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this
>>>>>>>>>>>>>>>>>>>>>>> mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>>>>>>>>> van/wms* tested with GeoNode demo site  and facing
>>>>>>>>>>>>>>>>>>>>>>> similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/363178bf/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/363178bf/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/363178bf/attachment-0003.png>
More information about the geonode-users mailing list
