[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Tue Jun 20 03:01:04 PDT 2017
Dear Simone,
 when I opened the http://fase2kort.klimatilpasning.dk:80/geoserver/wms
<http://fase2kort.klimatilpasning.dk/geoserver/wms> in browsers, it is
showine geoserver related error. Please find the attached response file for
you  reference.
Thanks,
Naresh
On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> It might be. Are you able to access that wms backend from in the browser?
> it should give you an XML containing the geoserver error related to
> missing request parameter.
> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>>   Yes we are in office campus, we are using proxy server. So  is this the
>> reason?  if so where I need to do the changes?
>> Thanks,
>> Naresh
>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> At this point I would check your local internet connection, are you
>>> behind a proxy that may block it?
>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>>   Thanks for the responding.  As per I understand from below code in
>>>> the proxy/views.py
>>>> if not settings.DEBUG:
>>>>         if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>>>>             return HttpResponse("DEBUG is set to False but the host of
>>>> the path provided to the proxy service"
>>>>                                 " is not in the PROXY_ALLOWED_HOSTS
>>>> setting.",
>>>>                                 status=403,
>>>>                                 content_type="text/plain"
>>>>  if GeoNode  debug mode value is flase, the wms url may not be required
>>>> to add in  PROXY_ALLOWED_HOSTS. And even if debug mode value is ture,
>>>> it should show the following error 'DEBUG is set to False but the host
>>>> of the path provided to the proxy service"
>>>> setting',. In my case nothing this kind of error/alert message is not
>>>> getting
>>>> And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode site,
>>>> it is fetching the layers
>>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it is
>>>> showing same error.
>>>> I have been trying from last two days to overcome this issue, but not
>>>> able to do. Please suggest anywhere more I need to investigate the
>>>> code/settings?
>>>> Thanks,
>>>> Naresh
>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
>>>>> PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
>>>>> there.
>>>>> I tested locally and seems to work.
>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>> is solved.
>>>>>> How ever, not able to add any WMS Layer url, it is showing the
>>>>>> following error.
>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>> Internal Server Error: /proxy/
>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback
>>>>>> (most recent call last):
>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py",
>>>>>> line 112, in get_response
>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
>>>>>> wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>> self._send_request(method, url, body, headers)
>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>> self.endheaders(body)
>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>> self._send_output(message_body)
>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629] self.send(msg)
>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629] self.connect()
>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629] self.timeout,
>>>>>> self.source_address)
>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>>> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error: [Errno
>>>>>> 111] Connection refused
>>>>>> Even I went to httplib.py and socket.py with the alerts I could able
>>>>>> to see the following WMS server IP and port details ('188.64.159.9', 80)
>>>>>> and source_address is none
>>>>>> Please help me how to resolve the issue, is that any where my GeoNode
>>>>>> Deployed System Ip need to place?
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>> It must be an array and not a tuple.
>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com>
>>>>>>> ha scritto:
>>>>>>>> Dear Simone,
>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal
>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback
>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response
>>>>>>>> = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError:
>>>>>>>> cannot concatenate 'str' and 'tuple' objects
>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal
>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback
>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response
>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>> name.
>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library
>>>>>>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>>>>>>> length
>>>>>>>> if in proxy/views.py if i add in place of hostname ip adress of the
>>>>>>>> GeoNode, The error '*TypeError: cannot concatenate 'str' and
>>>>>>>> 'tuple' objects ' *will go, how ever the error which I mentioned
>>>>>>>> in my earlier mail retains.
>>>>>>>> Please suggest how to overcome above error '*TypeError: cannot
>>>>>>>> concatenate 'str' and 'tuple' objects ' *with out editing
>>>>>>>> proxy/views.py
>>>>>>>> And also kindly suggest me how to correct misconfiguration of SSL
>>>>>>>> error, since I am not using https any where
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>> Not a good idea to modify the python files, You can add the
>>>>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>> Anyway, seems you are running under ssl. Seems a misconfiguration
>>>>>>>>> of it.
>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>  I have tried with the url provided
>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the following
>>>>>>>>>> error.
>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>> *Please find the apaahe error log file and attached views.py file
>>>>>>>>>> from proxy folder of geonode for the reference. In view.py in line no: 37
>>>>>>>>>> is modified (commented host name and placed IP adrdress of GeoNode
>>>>>>>>>> installed system)*
>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal
>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback
>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>> self.send(msg)
>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>> self.connect()
>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise
>>>>>>>>>> err
>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error:
>>>>>>>>>> [Errno 111] Connection refused
>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal
>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback
>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>> self.send(msg)
>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>> self.connect()
>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise
>>>>>>>>>> err
>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error:
>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>> name.
>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL
>>>>>>>>>> Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>> permissible length
>>>>>>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not
>>>>>>>>>>>> sure about our other question, don't think is possible in the standard code.
>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS Layer url
>>>>>>>>>>>>> is available ,please share me to test.  Is that any mechanism is available
>>>>>>>>>>>>> in case if WFS of Geoserver is disabled,not enabling EDIT option while
>>>>>>>>>>>>> reading error code.
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an issue
>>>>>>>>>>>>>> of that geoserver.
>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode using
>>>>>>>>>>>>>>> Layers ->Add server option. It is adding but it shows the issue which I
>>>>>>>>>>>>>>> mentioned in my earlier mail.
>>>>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>> /bhuvan/wms. in demo GeoNode site  and  can be observed
>>>>>>>>>>>>>>> same issue.
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance i
>>>>>>>>>>>>>>>>>  have fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html  which contains
>>>>>>>>>>>>>>>>> the steps I followed to install.
>>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and version is
>>>>>>>>>>>>>>>>> 2.7.4. Not able to understand from where you  observed my Geoserver version
>>>>>>>>>>>>>>>>> is 2.0.2?.
>>>>>>>>>>>>>>>>>  Please let me know any other information required to
>>>>>>>>>>>>>>>>> solve the issue
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be
>>>>>>>>>>>>>>>>>> 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>> _geoserver_application.html  to configure Geoserver
>>>>>>>>>>>>>>>>>>> with GeoNode
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation
>>>>>>>>>>>>>>>>>>>>>> of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org)
>>>>>>>>>>>>>>>>>>>>>> also I have tested with the url
>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am
>>>>>>>>>>>>>>>>>>>>>> getting same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this
>>>>>>>>>>>>>>>>>>>>>>>> mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhu
>>>>>>>>>>>>>>>>>>>>>>>> van/wms* tested with GeoNode demo site  and facing
>>>>>>>>>>>>>>>>>>>>>>>> similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/5de9f331/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/5de9f331/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/5de9f331/attachment-0003.png>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/5de9f331/attachment-0001.obj>
More information about the geonode-users mailing list
