[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 20 03:16:30 PDT 2017
Ok so maybe your server is unable to reach that address, can you check that?
2017-06-20 12:01 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>  when I opened the http://fase2kort.klimatilpasning.dk:80/geoserver/wms
> <http://fase2kort.klimatilpasning.dk/geoserver/wms> in browsers, it is
> showine geoserver related error. Please find the attached response file for
> you  reference.
> Thanks,
> Naresh
> On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> It might be. Are you able to access that wms backend from in the browser?
>> it should give you an XML containing the geoserver error related to
>> missing request parameter.
>> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>>   Yes we are in office campus, we are using proxy server. So  is this
>>> the reason?  if so where I need to do the changes?
>>> Thanks,
>>> Naresh
>>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>>>> At this point I would check your local internet connection, are you
>>>> behind a proxy that may block it?
>>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>>   Thanks for the responding.  As per I understand from below code in
>>>>> the proxy/views.py
>>>>> if not settings.DEBUG:
>>>>>         if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>>>>>             return HttpResponse("DEBUG is set to False but the host of
>>>>> the path provided to the proxy service"
>>>>>                                 " is not in the PROXY_ALLOWED_HOSTS
>>>>> setting.",
>>>>>                                 status=403,
>>>>>                                 content_type="text/plain"
>>>>>  if GeoNode  debug mode value is flase, the wms url may not be
>>>>> required to add in  PROXY_ALLOWED_HOSTS. And even if debug mode value
>>>>> is ture, it should show the following error 'DEBUG is set to False
>>>>> but the host of the path provided to the proxy service"
>>>>> setting',. In my case nothing this kind of error/alert message is not
>>>>> getting
>>>>> And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode site,
>>>>> it is fetching the layers
>>>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it is
>>>>> showing same error.
>>>>> I have been trying from last two days to overcome this issue, but not
>>>>> able to do. Please suggest anywhere more I need to investigate the
>>>>> code/settings?
>>>>> Thanks,
>>>>> Naresh
>>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
>>>>>> PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
>>>>>> there.
>>>>>> I tested locally and seems to work.
>>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>>> is solved.
>>>>>>> How ever, not able to add any WMS Layer url, it is showing the
>>>>>>> following error.
>>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>>> Internal Server Error: /proxy/
>>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback
>>>>>>> (most recent call last):
>>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py",
>>>>>>> line 112, in get_response
>>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
>>>>>>> wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>>> self._send_request(method, url, body, headers)
>>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>>> self.endheaders(body)
>>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>>> self._send_output(message_body)
>>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629] self.send(msg)
>>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629] self.connect()
>>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629] self.timeout,
>>>>>>> self.source_address)
>>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>>>> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
>>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error: [Errno
>>>>>>> 111] Connection refused
>>>>>>> Even I went to httplib.py and socket.py with the alerts I could able
>>>>>>> to see the following WMS server IP and port details ('188.64.159.9', 80)
>>>>>>> and source_address is none
>>>>>>> Please help me how to resolve the issue, is that any where my
>>>>>>> GeoNode Deployed System Ip need to place?
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>>> It must be an array and not a tuple.
>>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com>
>>>>>>>> ha scritto:
>>>>>>>>> Dear Simone,
>>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal
>>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback
>>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
>>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]
>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError:
>>>>>>>>> cannot concatenate 'str' and 'tuple' objects
>>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal
>>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback
>>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
>>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]
>>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
>>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>>> name.
>>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library
>>>>>>>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>>>>>>>> length
>>>>>>>>> if in proxy/views.py if i add in place of hostname ip adress of
>>>>>>>>> the GeoNode, The error '*TypeError: cannot concatenate 'str' and
>>>>>>>>> 'tuple' objects ' *will go, how ever the error which I mentioned
>>>>>>>>> in my earlier mail retains.
>>>>>>>>> Please suggest how to overcome above error '*TypeError: cannot
>>>>>>>>> concatenate 'str' and 'tuple' objects ' *with out editing
>>>>>>>>> proxy/views.py
>>>>>>>>> And also kindly suggest me how to correct misconfiguration of SSL
>>>>>>>>> error, since I am not using https any where
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>>> Not a good idea to modify the python files, You can add the
>>>>>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>>> Anyway, seems you are running under ssl. Seems a misconfiguration
>>>>>>>>>> of it.
>>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>  I have tried with the url provided
>>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the following
>>>>>>>>>>> error.
>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>> *Please find the apaahe error log file and attached views.py
>>>>>>>>>>> file from proxy folder of geonode for the reference. In view.py in line no:
>>>>>>>>>>> 37 is modified (commented host name and placed IP adrdress of GeoNode
>>>>>>>>>>> installed system)*
>>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal
>>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback
>>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>>> self.send(msg)
>>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>>> self.connect()
>>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise
>>>>>>>>>>> err
>>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error:
>>>>>>>>>>> [Errno 111] Connection refused
>>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal
>>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback
>>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>>> self.send(msg)
>>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>>> self.connect()
>>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise
>>>>>>>>>>> err
>>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error:
>>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>>> name.
>>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL
>>>>>>>>>>> Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>>> permissible length
>>>>>>>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not
>>>>>>>>>>>>> sure about our other question, don't think is possible in the standard code.
>>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS Layer url
>>>>>>>>>>>>>> is available ,please share me to test.  Is that any mechanism is available
>>>>>>>>>>>>>> in case if WFS of Geoserver is disabled,not enabling EDIT option while
>>>>>>>>>>>>>> reading error code.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an
>>>>>>>>>>>>>>> issue of that geoserver.
>>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode
>>>>>>>>>>>>>>>> using Layers ->Add server option. It is adding but it shows the issue which
>>>>>>>>>>>>>>>> I mentioned in my earlier mail.
>>>>>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>> /bhuvan/wms. in demo GeoNode site  and  can be observed
>>>>>>>>>>>>>>>> same issue.
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your guidance i
>>>>>>>>>>>>>>>>>>  have fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html  which contains
>>>>>>>>>>>>>>>>>> the steps I followed to install.
>>>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and version is
>>>>>>>>>>>>>>>>>> 2.7.4. Not able to understand from where you  observed my Geoserver version
>>>>>>>>>>>>>>>>>> is 2.0.2?.
>>>>>>>>>>>>>>>>>>  Please let me know any other information required to
>>>>>>>>>>>>>>>>>> solve the issue
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be
>>>>>>>>>>>>>>>>>>> 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>  Yes, I followed steps from  http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>>> _geoserver_application.html  to configure Geoserver
>>>>>>>>>>>>>>>>>>>> with GeoNode
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation
>>>>>>>>>>>>>>>>>>>>>>> of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org)
>>>>>>>>>>>>>>>>>>>>>>> also I have tested with the url
>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am
>>>>>>>>>>>>>>>>>>>>>>> getting same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this
>>>>>>>>>>>>>>>>>>>>>>>>> mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *
>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/5c5a0751/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/5c5a0751/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/5c5a0751/attachment-0003.png>
More information about the geonode-users mailing list
