[GeoNode-users] Enable notifications
Toni Schönbuchner toni.schoenbuchner at csgis.de
Wed Jun 21 06:46:26 PDT 2017
Hey Gideon,
I´ve edited the subject. (I forgot to edit it to something meaningful before.)
I´ve only had a quick look at 2.6 so far thus cannot say much. But I think
notifications app should be installed with 2.6 like it is with 2.4.
Do you see a folder for it in your geonode dir? If not have a look here:
https://github.com/GeoNode/geonode/blob/2.6.x/requirements.txt#L45 <https://github.com/GeoNode/geonode/blob/2.6.x/requirements.txt#L45>
It´s mentioned in pip requirement.txt and here is a git repository
https://github.com/GeoNode/geonode-notification
 <https://github.com/GeoNode/geonode-notification>
https://pypi.python.org/pypi/geonode-notification/1.1.3 <https://pypi.python.org/pypi/geonode-notification/1.1.3>
Means if something went wrong with your install I would just try to add this
app as you do with other django apps ;)
let me know if this helps.
cheers,
toni
> Am 21.06.2017 um 15:17 schrieb GIDEON YEGON <gyegon2001 at gmail.com>:
> Hello Toni,
> Thanks for your prompt response. I have tried that with no lack.
> Another issue is how can I enable notification link like the one in geonode 2.4. Its seems like its not accommodated already in 2.6
> Thanks.
> Kind regards
> Gideon Yegon
> Phone: +254 713 280 960
> http://www.linkedin.com/in/gyegon <http://www.linkedin.com/in/gideon-yegon-956162ab>
> skype: g.yegon
> On Wed, Jun 21, 2017 at 4:08 PM, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Hi Gideon,
> have you run db migrations after enabling notifications app in settings?
> I´ve had problems there as well. What helped me was setting debug = true.
> After that I´ve seen that something was wrong with templates. If I remember
> correctly I´ve copied some templates from github and it worked. Your problem
> might be somewhere else but debug will bring you on track.
> cheers,
> toni
>> Am 21.06.2017 um 12:23 schrieb geonode-users-request at lists.osgeo.org <mailto:geonode-users-request at lists.osgeo.org>:
>> Message: 1
>> Date: Wed, 21 Jun 2017 11:11:30 +0300
>> From: GIDEON YEGON <gyegon2001 at gmail.com <mailto:gyegon2001 at gmail.com>>
>> To: Simone Dalmasso <simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>>,
>> 	geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>, geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
>> Subject: [GeoNode-users] Geonode 2.6
>> Message-ID:
>> 	<CA+-FCQUVUVxmsKpMuWTBG-Zng5=b-UdTF3TNzzebLVF7edpWBA at mail.gmail.com <mailto:CA+-FCQUVUVxmsKpMuWTBG-Zng5=b-UdTF3TNzzebLVF7edpWBA at mail.gmail.com>>
>> Content-Type: text/plain; charset="utf-8"
>> Hi all,
>> Am  getting this error "NoticeType matching query does not exit" when i try
>> to upload a shapefile. Has anyone experience this before?. Also for me to
>> upload a layer i found a workround, commenting the notification app in the
>> settings file and the upload is successful. But this is a problem because i
>> need notification for the purpose of registration of users and email
>> approvals.
> <Screenshot at 2017-06-21 11:14:39.png>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/c09833cd/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/c09833cd/attachment.sig>
More information about the geonode-users mailing list
