[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Fri Jun 23 01:14:45 PDT 2017
Dear Simone,
   Thanks for the response.
    Is it possible to add WMS Layer with Layer Name and URL to GeoNode
interface. If not where do I need to write a script for taking the input
WMS URL , Layer Name and adding to Overlay layers section in Map window
Thanks,
Naresh
On Fri, Jun 23, 2017 at 1:32 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, I think that Toni's answer was complete and actually I've nothing to
> add. Your sysadmin should help you in figuring out why your GeoNode can't
> reach that address. It is a server configuration anyway, doesn't seems to
> be related to geonode config.
> 2017-06-23 7:28 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>>  Kindly help me to understand better working of WMS Manager
>> functionality. Kindly answer the my earlier post queries
>>  Thanks in advance.
>> Best Regards,
>> Naresh
>> On Wed, Jun 21, 2017 at 3:53 PM, Naresh N <naresh919 at gmail.com> wrote:
>>> Dear Simone,
>>>  Kindly suggest answers for my earlier mail.
>>> Thanks,
>>> Naresh
>>> On Wed, Jun 21, 2017 at 11:54 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear Simone,
>>>>   Thanks once again. I am trying to resolve, but not able to do. Kindly
>>>> explain following little more, which will help to resolve
>>>> 1.The WMS URL request  i.e  http://fase2kort.klimatilpasn
>>>> ing.dk:80/geoserver/wms is first  reaching to GeoNode deployed system
>>>> and from it , the request is going to corresponding URL.
>>>>   In this case GeoNode deployed system to send the url ,it required
>>>> proxy server our campus network .* Is it true?* If so  I have to
>>>> specify our proxy server address in GeoNode Code. Where I have to specify?
>>>> 2. Even if it works the GeoNode deployed system should have internet
>>>> connectivity.* Is it true*?
>>>> 3. As of now my GeoNode deployed System has internet connectivity, how
>>>> ever once we make this application live/production, the internet
>>>> connectivity will be removed for security concerns
>>>>              (As you aware production servers should not have internet
>>>> to avoid possible threats)
>>>>   *          In this case how to handle?*
>>>> *4. * Is there any way is available , if user specifies WMS Layer URL
>>>> and Name it should load  and add corresponding layers to GeoNode  Map/Layer
>>>> window
>>>> Please kindly help me to understand
>>>> Thanks,
>>>> Naresh
>>>> On Tue, Jun 20, 2017 at 5:49 PM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> wrote:
>>>>> Unfortunately I don't have any other advice, if the server is properly
>>>>> connected to the internet and is correctly accessing it, then it should
>>>>> work without requiring specific settings but the PROXY_ALLOWED_HOSTS, which
>>>>> you already set.
>>>>> 2017-06-20 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>> Thanks for the responses
>>>>>> As you told the following request getting proper response
>>>>>> http://demo.geonode.org/proxy/?url=http%3A%2F%2Ffase2kort.kl
>>>>>> imatilpasning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26RE
>>>>>> QUEST%3DGetCapabilities%26TILED%3Dtrue%26VERSION%3D1.1.1
>>>>>> and in case of my geonode  the following request is getting the error
>>>>>> http://localhost/proxy/?url=http%3A%2F%2Ffase2kort.klimatilp
>>>>>> asning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%3
>>>>>> However in my browser with the url : http://fase2kort.klimatilpas
>>>>>> ning.dk/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabilities&TI
>>>>>> LED=true&VERSION=1.1.1, it is getting proper respone
>>>>>> Do I need to add *my proxy server address some where in GeoNode code*?
>>>>>> or proxy address will take directly from the system?  I have also asked
>>>>>> network administrator, but  they are not able to understand
>>>>>> As you know, this functionality is very much important, as it will
>>>>>> connect others server and fetch the data . Please  suggest some clue to
>>>>>> resolve
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Tue, Jun 20, 2017 at 5:13 PM, Simone Dalmasso <
>>>>>>> No, that server is not responding to ping so it will never work. Not
>>>>>>> sure what setting you need for the server but to me it looks an error
>>>>>>> related to your network. On demo.geonode.org is, for example,
>>>>>>> working.
>>>>>>> 2017-06-20 12:45 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>>   I have opened the terminal in  my server(Geonode deployed system)
>>>>>>>> and typed the ping  fase2kort.klimatilpasning.dk, but not getting
>>>>>>>> connected. Do I need to change/add my server settings?
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Tue, Jun 20, 2017 at 3:46 PM, Simone Dalmasso <
>>>>>>>>> Ok so maybe your server is unable to reach that address, can you
>>>>>>>>> check that?
>>>>>>>>> 2017-06-20 12:01 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>  when I opened the http://fase2kort.klimatilp
>>>>>>>>>> asning.dk:80/geoserver/wms
>>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> in browsers,
>>>>>>>>>> it is showine geoserver related error. Please find the attached response
>>>>>>>>>> file for you  reference.
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <
>>>>>>>>>>> It might be. Are you able to access that wms backend from in the
>>>>>>>>>>> browser? http://fase2kort.klimatilpasning.dk:80/geoserver/wms
>>>>>>>>>>> it should give you an XML containing the geoserver error related
>>>>>>>>>>> to missing request parameter.
>>>>>>>>>>> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>   Yes we are in office campus, we are using proxy server. So
>>>>>>>>>>>>  is this the reason?  if so where I need to do the changes?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>>>>>>>>>>>>> At this point I would check your local internet connection,
>>>>>>>>>>>>> are you behind a proxy that may block it?
>>>>>>>>>>>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>   Thanks for the responding.  As per I understand from below
>>>>>>>>>>>>>> code in the proxy/views.py
>>>>>>>>>>>>>> if not settings.DEBUG:
>>>>>>>>>>>>>>         if not validate_host(url.hostname,
>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS):
>>>>>>>>>>>>>>             return HttpResponse("DEBUG is set to False but
>>>>>>>>>>>>>> the host of the path provided to the proxy service"
>>>>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting.",
>>>>>>>>>>>>>>                                 status=403,
>>>>>>>>>>>>>>                                 content_type="text/plain"
>>>>>>>>>>>>>>  if GeoNode  debug mode value is flase, the wms url may not
>>>>>>>>>>>>>> be required to add in  PROXY_ALLOWED_HOSTS. And even if
>>>>>>>>>>>>>> debug mode value is ture, it should show the following error 'DEBUG
>>>>>>>>>>>>>> is set to False but the host of the path provided to the proxy service"
>>>>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting',. In my case nothing this kind of error/alert
>>>>>>>>>>>>>> message is not getting
>>>>>>>>>>>>>> And I added the  fase2kort.klimatilpasning.dk  in Demo
>>>>>>>>>>>>>> GeoNode site, it is fetching the layers
>>>>>>>>>>>>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>>>>>>>>>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but
>>>>>>>>>>>>>> it is showing same error.
>>>>>>>>>>>>>> I have been trying from last two days to overcome this issue,
>>>>>>>>>>>>>> but not able to do. Please suggest anywhere more I need to investigate the
>>>>>>>>>>>>>> code/settings?
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>>>>>>>>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>>>>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string
>>>>>>>>>>>>>>> in the PROXY_ALLOWED_HOSTS directive as every remote address should be
>>>>>>>>>>>>>>> authorised there.
>>>>>>>>>>>>>>> I tested locally and seems to work.
>>>>>>>>>>>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>>>>>>>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>>>>>>>>>>>> is solved.
>>>>>>>>>>>>>>>> How ever, not able to add any WMS Layer url, it is showing
>>>>>>>>>>>>>>>> the following error.
>>>>>>>>>>>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>>>>>>>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>>>>>>>>>>>> Internal Server Error: /proxy/
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib/python2.7/site-packa
>>>>>>>>>>>>>>>> ges/django/core/handlers/base.py", line 112, in
>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in
>>>>>>>>>>>>>>>> proxy
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> self._send_request(method, url, body, headers)
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in
>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> self.endheaders(body)
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> self._send_output(message_body)
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in
>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 577, in
>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> raise err
>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>> error: [Errno 111] Connection refused
>>>>>>>>>>>>>>>> Even I went to httplib.py and socket.py with the alerts I
>>>>>>>>>>>>>>>> could able to see the following WMS server IP and port details
>>>>>>>>>>>>>>>> ('188.64.159.9', 80) and source_address is none
>>>>>>>>>>>>>>>> Please help me how to resolve the issue, is that any where
>>>>>>>>>>>>>>>> my GeoNode Deployed System Ip need to place?
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>> It must be an array and not a tuple.
>>>>>>>>>>>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>>>>>>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <
>>>>>>>>>>>>>>>>> naresh919 at gmail.com> ha scritto:
>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>>>>>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>>>>>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>> File "/usr/lib/python2.7/site-packa
>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>> File "/data/cms/geonode/geonode/proxy/views.py", line
>>>>>>>>>>>>>>>>>> 37, in proxy
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>   PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>> TypeError: cannot concatenate 'str' and 'tuple' objects
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>> 37, in proxy
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>>>>>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>>>>>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>>>>>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535]
>>>>>>>>>>>>>>>>>> SSL Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>>>> if in proxy/views.py if i add in place of hostname ip
>>>>>>>>>>>>>>>>>> adress of the GeoNode, The error '*TypeError: cannot
>>>>>>>>>>>>>>>>>> concatenate 'str' and 'tuple' objects ' *will go, how
>>>>>>>>>>>>>>>>>> ever the error which I mentioned in my earlier mail retains.
>>>>>>>>>>>>>>>>>> Please suggest how to overcome above error '*TypeError:
>>>>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects ' *with out
>>>>>>>>>>>>>>>>>> editing proxy/views.py
>>>>>>>>>>>>>>>>>> And also kindly suggest me how to correct
>>>>>>>>>>>>>>>>>> misconfiguration of SSL error, since I am not using https any where
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>> Not a good idea to modify the python files, You can add
>>>>>>>>>>>>>>>>>>> the PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>>>>>>>>>>>> Anyway, seems you are running under ssl. Seems a
>>>>>>>>>>>>>>>>>>> misconfiguration of it.
>>>>>>>>>>>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>  I have tried with the url provided
>>>>>>>>>>>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the
>>>>>>>>>>>>>>>>>>>> following error.
>>>>>>>>>>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>>>>>>>>>>> *Please find the apaahe error log file and attached
>>>>>>>>>>>>>>>>>>>> views.py file from proxy folder of geonode for the reference. In view.py in
>>>>>>>>>>>>>>>>>>>> line no: 37 is modified (commented host name and placed IP adrdress of
>>>>>>>>>>>>>>>>>>>> GeoNode installed system)*
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> line 67, in proxy
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/httplib.py", line 1017,
>>>>>>>>>>>>>>>>>>>> in request
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/httplib.py", line 1051,
>>>>>>>>>>>>>>>>>>>> in _send_request
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/httplib.py", line 1013,
>>>>>>>>>>>>>>>>>>>> in endheaders
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/httplib.py", line 864, in
>>>>>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>     self.send(msg)
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/httplib.py", line 826, in
>>>>>>>>>>>>>>>>>>>> send
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>     self.connect()
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/httplib.py", line 807, in
>>>>>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/socket.py", line 571, in
>>>>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>     raise err
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> line 67, in proxy
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> in request
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> in _send_request
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> in endheaders
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>     self.send(msg)
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> send
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>     self.connect()
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>     raise err
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135]
>>>>>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>>>>>> Please kindly suggest me, do i need to modify some
>>>>>>>>>>>>>>>>>>>> where else?
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>> You can try with http://demo.geonode.org/g
>>>>>>>>>>>>>>>>>>>>>> eoserver/wms. Not sure about our other question,
>>>>>>>>>>>>>>>>>>>>>> don't think is possible in the standard code.
>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS
>>>>>>>>>>>>>>>>>>>>>>> Layer url is available ,please share me to test.  Is that any mechanism is
>>>>>>>>>>>>>>>>>>>>>>> available in case if WFS of Geoserver is disabled,not enabling EDIT option
>>>>>>>>>>>>>>>>>>>>>>> while reading error code.
>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This
>>>>>>>>>>>>>>>>>>>>>>>> is an issue of that geoserver.
>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to
>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode using Layers ->Add server option. It is adding but it shows the
>>>>>>>>>>>>>>>>>>>>>>>>> issue which I mentioned in my earlier mail.
>>>>>>>>>>>>>>>>>>>>>>>>> Please kindly add the url
>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms. in demo
>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode site  and  can be observed same issue.
>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso
>>>>>>>>>>>>>>>>>>>>>>>>> <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.
>>>>>>>>>>>>>>>>>>>>>>>>>> in/bhuvan/web/
>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your
>>>>>>>>>>>>>>>>>>>>>>>>>>> guidance i  have fixed the issue. Please find the link our earlier
>>>>>>>>>>>>>>>>>>>>>>>>>>> converstaion http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html  which
>>>>>>>>>>>>>>>>>>>>>>>>>>> contains the steps I followed to install.
>>>>>>>>>>>>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and
>>>>>>>>>>>>>>>>>>>>>>>>>>> version is 2.7.4. Not able to understand from where you  observed my
>>>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver version is 2.0.2?.
>>>>>>>>>>>>>>>>>>>>>>>>>>>  Please let me know any other information
>>>>>>>>>>>>>>>>>>>>>>>>>>> required to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>> Dalmasso <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it
>>>>>>>>>>>>>>>>>>>>>>>>>>>> should be 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Yes, I followed steps from
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _geoserver_application.html  to configure
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver with GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2.4 guide? http://docs.geonode.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Installation of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> folder.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://demo.geonode.org) also I have
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> tested with the url
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   ,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I am getting same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> configuration in geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode  using ADDLayrers---> Addsever option the following error is
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> getting and EDIT options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with this mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ______________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/a15bcc7b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/a15bcc7b/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/a15bcc7b/attachment-0003.png>
More information about the geonode-users mailing list
