[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 23 01:20:33 PDT 2017
You can either register the remote source as a geonode service or add it
into the maps/new interface add layer -> add a new server.
2017-06-23 10:14 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>    Thanks for the response.
>     Is it possible to add WMS Layer with Layer Name and URL to GeoNode
> interface. If not where do I need to write a script for taking the input
> WMS URL , Layer Name and adding to Overlay layers section in Map window
> Thanks,
> Naresh
> On Fri, Jun 23, 2017 at 1:32 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi, I think that Toni's answer was complete and actually I've nothing to
>> add. Your sysadmin should help you in figuring out why your GeoNode can't
>> reach that address. It is a server configuration anyway, doesn't seems to
>> be related to geonode config.
>> 2017-06-23 7:28 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>>  Kindly help me to understand better working of WMS Manager
>>> functionality. Kindly answer the my earlier post queries
>>>  Thanks in advance.
>>> Best Regards,
>>> Naresh
>>> On Wed, Jun 21, 2017 at 3:53 PM, Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear Simone,
>>>>  Kindly suggest answers for my earlier mail.
>>>> Thanks,
>>>> Naresh
>>>> On Wed, Jun 21, 2017 at 11:54 AM, Naresh N <naresh919 at gmail.com> wrote:
>>>>> Dear Simone,
>>>>>   Thanks once again. I am trying to resolve, but not able to do.
>>>>> Kindly explain following little more, which will help to resolve
>>>>> 1.The WMS URL request  i.e  http://fase2kort.klimatilpasn
>>>>> ing.dk:80/geoserver/wms is first  reaching to GeoNode deployed system
>>>>> and from it , the request is going to corresponding URL.
>>>>>   In this case GeoNode deployed system to send the url ,it required
>>>>> proxy server our campus network .* Is it true?* If so  I have to
>>>>> specify our proxy server address in GeoNode Code. Where I have to specify?
>>>>> 2. Even if it works the GeoNode deployed system should have internet
>>>>> connectivity.* Is it true*?
>>>>> 3. As of now my GeoNode deployed System has internet connectivity, how
>>>>> ever once we make this application live/production, the internet
>>>>> connectivity will be removed for security concerns
>>>>>              (As you aware production servers should not have internet
>>>>> to avoid possible threats)
>>>>>   *          In this case how to handle?*
>>>>> *4. * Is there any way is available , if user specifies WMS Layer URL
>>>>> and Name it should load  and add corresponding layers to GeoNode  Map/Layer
>>>>> window
>>>>> Please kindly help me to understand
>>>>> Thanks,
>>>>> Naresh
>>>>> On Tue, Jun 20, 2017 at 5:49 PM, Simone Dalmasso <
>>>>>> Unfortunately I don't have any other advice, if the server is
>>>>>> properly connected to the internet and is correctly accessing it, then it
>>>>>> should work without requiring specific settings but the
>>>>>> PROXY_ALLOWED_HOSTS, which you already set.
>>>>>> 2017-06-20 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>> Thanks for the responses
>>>>>>> As you told the following request getting proper response
>>>>>>> http://demo.geonode.org/proxy/?url=http%3A%2F%2Ffase2kort.kl
>>>>>>> imatilpasning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26RE
>>>>>>> QUEST%3DGetCapabilities%26TILED%3Dtrue%26VERSION%3D1.1.1
>>>>>>> and in case of my geonode  the following request is getting the error
>>>>>>> http://localhost/proxy/?url=http%3A%2F%2Ffase2kort.klimatilp
>>>>>>> asning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%3
>>>>>>> However in my browser with the url : http://fase2kort.klimatilpas
>>>>>>> ning.dk/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabilities&TI
>>>>>>> LED=true&VERSION=1.1.1, it is getting proper respone
>>>>>>> Do I need to add *my proxy server address some where in GeoNode
>>>>>>> code*? or proxy address will take directly from the system?  I have
>>>>>>> also asked network administrator, but  they are not able to understand
>>>>>>> As you know, this functionality is very much important, as it will
>>>>>>> connect others server and fetch the data . Please  suggest some clue to
>>>>>>> resolve
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Tue, Jun 20, 2017 at 5:13 PM, Simone Dalmasso <
>>>>>>>> No, that server is not responding to ping so it will never work.
>>>>>>>> Not sure what setting you need for the server but to me it looks an error
>>>>>>>> related to your network. On demo.geonode.org is, for example,
>>>>>>>> working.
>>>>>>>> 2017-06-20 12:45 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone,
>>>>>>>>>   I have opened the terminal in  my server(Geonode deployed
>>>>>>>>> system) and typed the ping  fase2kort.klimatilpasning.dk, but not
>>>>>>>>> getting connected. Do I need to change/add my server settings?
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Tue, Jun 20, 2017 at 3:46 PM, Simone Dalmasso <
>>>>>>>>>> Ok so maybe your server is unable to reach that address, can you
>>>>>>>>>> check that?
>>>>>>>>>> 2017-06-20 12:01 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>  when I opened the http://fase2kort.klimatilp
>>>>>>>>>>> asning.dk:80/geoserver/wms
>>>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> in
>>>>>>>>>>> browsers, it is showine geoserver related error. Please find the attached
>>>>>>>>>>> response file for you  reference.
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <
>>>>>>>>>>>> It might be. Are you able to access that wms backend from in
>>>>>>>>>>>> the browser? http://fase2kort.klim
>>>>>>>>>>>> atilpasning.dk:80/geoserver/wms
>>>>>>>>>>>> it should give you an XML containing the geoserver error
>>>>>>>>>>>> related to missing request parameter.
>>>>>>>>>>>> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>   Yes we are in office campus, we are using proxy server. So
>>>>>>>>>>>>>  is this the reason?  if so where I need to do the changes?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>>>>>>>>>>>>>> At this point I would check your local internet connection,
>>>>>>>>>>>>>> are you behind a proxy that may block it?
>>>>>>>>>>>>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>   Thanks for the responding.  As per I understand from below
>>>>>>>>>>>>>>> code in the proxy/views.py
>>>>>>>>>>>>>>> if not settings.DEBUG:
>>>>>>>>>>>>>>>         if not validate_host(url.hostname,
>>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS):
>>>>>>>>>>>>>>>             return HttpResponse("DEBUG is set to False but
>>>>>>>>>>>>>>> the host of the path provided to the proxy service"
>>>>>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting.",
>>>>>>>>>>>>>>>                                 status=403,
>>>>>>>>>>>>>>>                                 content_type="text/plain"
>>>>>>>>>>>>>>>  if GeoNode  debug mode value is flase, the wms url may not
>>>>>>>>>>>>>>> be required to add in  PROXY_ALLOWED_HOSTS. And even if
>>>>>>>>>>>>>>> debug mode value is ture, it should show the following error 'DEBUG
>>>>>>>>>>>>>>> is set to False but the host of the path provided to the proxy service"
>>>>>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting',. In my case nothing this kind of error/alert
>>>>>>>>>>>>>>> message is not getting
>>>>>>>>>>>>>>> And I added the  fase2kort.klimatilpasning.dk  in Demo
>>>>>>>>>>>>>>> GeoNode site, it is fetching the layers
>>>>>>>>>>>>>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>>>>>>>>>>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but
>>>>>>>>>>>>>>> it is showing same error.
>>>>>>>>>>>>>>> I have been trying from last two days to overcome this
>>>>>>>>>>>>>>> issue, but not able to do. Please suggest anywhere more I need to
>>>>>>>>>>>>>>> investigate the code/settings?
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>>>>>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string
>>>>>>>>>>>>>>>> in the PROXY_ALLOWED_HOSTS directive as every remote address should be
>>>>>>>>>>>>>>>> authorised there.
>>>>>>>>>>>>>>>> I tested locally and seems to work.
>>>>>>>>>>>>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>>>>>>>>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>>>>>>>>>>>>> is solved.
>>>>>>>>>>>>>>>>> How ever, not able to add any WMS Layer url, it is showing
>>>>>>>>>>>>>>>>> the following error.
>>>>>>>>>>>>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>>>>>>>>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>>>>>>>>>>>>> Internal Server Error: /proxy/
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib/python2.7/site-packa
>>>>>>>>>>>>>>>>> ges/django/core/handlers/base.py", line 112, in
>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/data/cms/geonode/geonode/proxy/views.py", line 82,
>>>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1017, in
>>>>>>>>>>>>>>>>> request
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> self._send_request(method, url, body, headers)
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1051, in
>>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> self.endheaders(body)
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1013, in
>>>>>>>>>>>>>>>>> endheaders
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> self._send_output(message_body)
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 864, in
>>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 807, in
>>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/socket.py", line 577, in
>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> raise err
>>>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>>>> error: [Errno 111] Connection refused
>>>>>>>>>>>>>>>>> Even I went to httplib.py and socket.py with the alerts I
>>>>>>>>>>>>>>>>> could able to see the following WMS server IP and port details
>>>>>>>>>>>>>>>>> ('188.64.159.9', 80) and source_address is none
>>>>>>>>>>>>>>>>> Please help me how to resolve the issue, is that any where
>>>>>>>>>>>>>>>>> my GeoNode Deployed System Ip need to place?
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> It must be an array and not a tuple.
>>>>>>>>>>>>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>>>>>>>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <
>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> ha scritto:
>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>>>>>>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>>>>>>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>> 37, in proxy
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>>   PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>>>> TypeError: cannot concatenate 'str' and 'tuple' objects
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>>> 37, in proxy
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>>>>>>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>>>>>>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535]
>>>>>>>>>>>>>>>>>>> SSL Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>>>>> if in proxy/views.py if i add in place of hostname ip
>>>>>>>>>>>>>>>>>>> adress of the GeoNode, The error '*TypeError: cannot
>>>>>>>>>>>>>>>>>>> concatenate 'str' and 'tuple' objects ' *will go, how
>>>>>>>>>>>>>>>>>>> ever the error which I mentioned in my earlier mail retains.
>>>>>>>>>>>>>>>>>>> Please suggest how to overcome above error '*TypeError:
>>>>>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects ' *with
>>>>>>>>>>>>>>>>>>> out editing proxy/views.py
>>>>>>>>>>>>>>>>>>> And also kindly suggest me how to correct
>>>>>>>>>>>>>>>>>>> misconfiguration of SSL error, since I am not using https any where
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>> Not a good idea to modify the python files, You can add
>>>>>>>>>>>>>>>>>>>> the PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>>>>>>>>>>>>> Anyway, seems you are running under ssl. Seems a
>>>>>>>>>>>>>>>>>>>> misconfiguration of it.
>>>>>>>>>>>>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>  I have tried with the url provided
>>>>>>>>>>>>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the
>>>>>>>>>>>>>>>>>>>>> following error.
>>>>>>>>>>>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>>>>>>>>>>>> *Please find the apaahe error log file and attached
>>>>>>>>>>>>>>>>>>>>> views.py file from proxy folder of geonode for the reference. In view.py in
>>>>>>>>>>>>>>>>>>>>> line no: 37 is modified (commented host name and placed IP adrdress of
>>>>>>>>>>>>>>>>>>>>> GeoNode installed system)*
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> line 67, in proxy
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in request
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in _send_request
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in endheaders
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in _send_output
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>>     self.send(msg)
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in send
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>>     self.connect()
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in connect
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>>   File "/usr/lib64/python2.7/socket.py", line 571, in
>>>>>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>>     raise err
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> line 67, in proxy
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in request
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in _send_request
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in endheaders
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in _send_output
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>>     self.send(msg)
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in send
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>>     self.connect()
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> in connect
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>>     raise err
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135]
>>>>>>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>>>>>>> Please kindly suggest me, do i need to modify some
>>>>>>>>>>>>>>>>>>>>> where else?
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>> You can try with http://demo.geonode.org/g
>>>>>>>>>>>>>>>>>>>>>>> eoserver/wms. Not sure about our other question,
>>>>>>>>>>>>>>>>>>>>>>> don't think is possible in the standard code.
>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS
>>>>>>>>>>>>>>>>>>>>>>>> Layer url is available ,please share me to test.  Is that any mechanism is
>>>>>>>>>>>>>>>>>>>>>>>> available in case if WFS of Geoserver is disabled,not enabling EDIT option
>>>>>>>>>>>>>>>>>>>>>>>> while reading error code.
>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This
>>>>>>>>>>>>>>>>>>>>>>>>> is an issue of that geoserver.
>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.i
>>>>>>>>>>>>>>>>>>>>>>>>>> n/bhuvan/web/ is external Geoserver of others
>>>>>>>>>>>>>>>>>>>>>>>>>> and I am adding thishttp://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>>>>>>>>>>> /bhuvan/web/ url to GeoNode using Layers ->Add
>>>>>>>>>>>>>>>>>>>>>>>>>> server option. It is adding but it shows the issue which I mentioned in my
>>>>>>>>>>>>>>>>>>>>>>>>>> earlier mail.
>>>>>>>>>>>>>>>>>>>>>>>>>> Please kindly add the url
>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms. in demo
>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode site  and  can be observed same issue.
>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso
>>>>>>>>>>>>>>>>>>>>>>>>>> <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.
>>>>>>>>>>>>>>>>>>>>>>>>>>> in/bhuvan/web/
>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your
>>>>>>>>>>>>>>>>>>>>>>>>>>>> guidance i  have fixed the issue. Please find the link our earlier
>>>>>>>>>>>>>>>>>>>>>>>>>>>> converstaion http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  which contains the steps I followed to install.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and
>>>>>>>>>>>>>>>>>>>>>>>>>>>> version is 2.7.4. Not able to understand from where you  observed my
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver version is 2.0.2?.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Please let me know any other information
>>>>>>>>>>>>>>>>>>>>>>>>>>>> required to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dalmasso <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> should be 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Yes, I followed steps from
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _geoserver_application.html  to configure
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver with GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2.4 guide? http://docs.geonode.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Installation of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> folder.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://demo.geonode.org) also I have
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> tested with the url
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   ,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I am getting same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> configuration in geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode  using ADDLayrers---> Addsever option the following error is
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> getting and EDIT options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with this mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ______________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/0cf2b571/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/0cf2b571/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/0cf2b571/attachment-0003.png>
More information about the geonode-users mailing list
