[GeoNode-users] Geosites
Simone Dalmasso simone.dalmasso at gmail.com
Wed Mar 1 00:40:06 PST 2017
you can update the
geoserver_data_dir/security/auth/GeonodeAuthProvider/config.xml with the
correct url of GeoNode, and then restart Tomcat.
Hope this helps
2017-02-28 14:12 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
> Hello all,
> I am having broken thumbnails
> and legends of layers on geonode. And it seems the issue is the
> communication between geonode and geoserver. I have tried updating the
> web.xml file and baseUrl but no lack.
> Does anyone know how to solve this problem. Thanks in advance.
> Below is the error am getting from geoserver logs.
> 2017-02-28 10:53:58,155 WARN [geonode.security] - Error connecting to the
> GeoNode server for authentication purposes
> org.springframework.security.authentication.AuthenticationServiceException:
> Communication with GeoNode failed (GeoNodeSessionAuthToken)
>         at org.geonode.security.GeoNodeAuthenticationProvider.
> authenticate(GeoNodeAuthenticationProvider.java:68)
>         at org.geoserver.security.GeoServerAuthenticationProvide
> r.authenticate(GeoServerAuthenticationProvider.java:58)
>         at org.springframework.security.authentication.
> ProviderManager.authenticate(ProviderManager.java:156)
>         at org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(
> GeoNodeCookieProcessingFilter.java:98)
>         at org.springframework.security.web.FilterChainProxy$
> VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>         at org.geoserver.security.filter.GeoServerCompositeFilter$
> NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>         at org.springframework.security.web.context.
> SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilt
> er.java:87)
>         at org.geoserver.security.filter.GeoServerSecurityContextPersis
> tenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
> NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>         at org.geoserver.security.filter.GeoServerCompositeFilter.
> doFilter(GeoServerCompositeFilter.java:92)
>         at org.springframework.security.web.FilterChainProxy.doFilter(
> FilterChainProxy.java:173)
>         at org.geoserver.security.GeoServerSecurityFilterChainPr
> oxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
>         at org.springframework.web.filter.DelegatingFilterProxy.
> invokeDelegate(DelegatingFilterProxy.java:346)
>         at org.springframework.web.filter.DelegatingFilterProxy.doFilter(
> DelegatingFilterProxy.java:259)
>         at org.apache.catalina.core.ApplicationFilterChain.
> internalDoFilter(ApplicationFilterChain.java:241)
>         at org.apache.catalina.core.ApplicationFilterChain.doFilter(
> ApplicationFilterChain.java:208)
>         at org.geoserver.filters.LoggingFilter.doFilter(
> LoggingFilter.java:87)
>         at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>         at org.geoserver.filters.SessionDebugFilter.doFilter(
> SessionDebugFilter.java:48)
>         at org.geoserver.filters.FlushSafeFilter.doFilter(
> FlushSafeFilter.java:44)
> Kind regards
> Gideon Yegon
> Phone: +254 713 280 960
> http://www.linkedin.com/in/gyegon
> <http://www.linkedin.com/in/gideon-yegon-956162ab>
> skype: g.yegon
> On Tue, Feb 28, 2017 at 11:12 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> What version of GeoNode did you install?
>> Seems that Geoserver cannot find geonode but depending on the version,
>> the configuration may be different.
>> 2017-02-28 9:08 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>> Hello Simone
>>> Am seeing two errors;
>>> 2017-02-28 09:36:37,190 INFO [geoserver.wms] -
>>> Request: getServiceInfo
>>> 2017-02-28 09:36:37,191 ERROR [geoserver.ows] -
>>> org.geoserver.platform.ServiceException: Could not find layer
>>> geonode:kewasco_connections
>>> 2017-02-28 09:36:37,205 WARN [geonode.security] - Error connecting to
>>> the GeoNode server for authentication purposes
>>> However i can be redirected automatically from geonode to geoserver and
>>> also be able to preview layers in my geoserver. I think am missing
>>> something out. Kindly assist thank you.
>>> Kind regards
>>> Gideon Yegon
>>> skype: g.yegon
>>> On Tue, Feb 28, 2017 at 10:44 AM, GIDEON YEGON <gyegon2001 at gmail.com>
>>> wrote:
>>>> Hello Simon,
>>>> Thanks for your prompt response, but the redirection from geonode to
>>>> geoserver is working fine, am able to connect automatically.
>>>> Or there could be other problems causing geonode and geoserver not
>>>> communicating well? Sorry for not being smart enough!
>>>> Kind regards
>>>> Gideon Yegon
>>>> skype: g.yegon
>>>> On Tue, Feb 28, 2017 at 10:18 AM, Simone Dalmasso <
>>>>> Hi, could be that geonode and geoserver don't connect properly. Check
>>>>> the geoserver logs.
>>>>> 2017-02-28 7:57 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>>>>> Hello all,
>>>>>> I wanted to know what could be wrong as i was able to successfully
>>>>>> install geosites on my local machine. But am getting broken thumbnails and
>>>>>> legend for the layers.
>>>>>> Kindly assist. Thanks.
>>>>>> Kind regards
>>>>>> Gideon Yegon
>>>>>> skype: g.yegon
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170301/bf09280a/attachment.html>
More information about the geonode-users mailing list
