[GeoNode-users] Geosites
GIDEON YEGON gyegon2001 at gmail.com
Wed Mar 1 01:23:19 PST 2017
I dont think so cause I have another geonode which I installed
automatically and it has no issues. Could it be because the geosites is
served by Geoserver that comes with running automatic geonode installation?
. Thanks
Did you have a  look at this
https://github.com/terranodo/geosites-project/blob/master/GEOSITES-README.md
<https://github.com/terranodo/geosites-project/blob/master/GEOSITES-README.md>
has it be updated or could you please provide me with another link that you
may have used in successfully deploying geosites.
Will greatly appreciate indeed.
Kind regards
Gideon Yegon
Phone: +254 713 280 960
http://www.linkedin.com/in/gyegon
<http://www.linkedin.com/in/gideon-yegon-956162ab>
skype: g.yegon
On Wed, Mar 1, 2017 at 12:02 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> This is strange, are you accessing geonode on localhost right. Could there
> be anything preventing connections on localhost inside the machine?
> 2017-03-01 9:51 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>> Hello Simone
>> Apparently I have done so but it seems its not picking up. This is what I
>> have in my config.xml
>> <baseUrl>http://localhost</baseUrl>
>> Also am running the geosites on my local machine as at now.
>> Kind regards
>> Gideon Yegon
>> skype: g.yegon
>> On Wed, Mar 1, 2017 at 11:40 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi,
>>> you can update the geoserver_data_dir/security/au
>>> th/GeonodeAuthProvider/config.xml with the correct url of GeoNode, and
>>> then restart Tomcat.
>>> Hope this helps
>>> 2017-02-28 14:12 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>>> Hello all,
>>>> I am having broken thumbnails
>>>> and legends of layers on geonode. And it seems the issue is the
>>>> communication between geonode and geoserver. I have tried updating the
>>>> web.xml file and baseUrl but no lack.
>>>> Does anyone know how to solve this problem. Thanks in advance.
>>>> Below is the error am getting from geoserver logs.
>>>> 2017-02-28 10:53:58,155 WARN [geonode.security] - Error connecting to
>>>> the GeoNode server for authentication purposes
>>>> org.springframework.security.authentication.AuthenticationServiceException:
>>>> Communication with GeoNode failed (GeoNodeSessionAuthToken)
>>>>         at org.geonode.security.GeoNodeAuthenticationProvider.authentic
>>>> ate(GeoNodeAuthenticationProvider.java:68)
>>>>         at org.geoserver.security.GeoServerAuthenticationProvider.authe
>>>> nticate(GeoServerAuthenticationProvider.java:58)
>>>>         at org.springframework.security.authentication.ProviderManager.
>>>> authenticate(ProviderManager.java:156)
>>>>         at org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(
>>>> GeoNodeCookieProcessingFilter.java:98)
>>>>         at org.springframework.security.web.FilterChainProxy$VirtualFil
>>>> terChain.doFilter(FilterChainProxy.java:323)
>>>>         at org.geoserver.security.filter.GeoServerCompositeFilter$Neste
>>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>>>>         at org.springframework.security.web.context.SecurityContextPers
>>>> istenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>>         at org.geoserver.security.filter.GeoServerSecurityContextPersis
>>>> tenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFi
>>>> lter.java:53)
>>>> dFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>>>>         at org.geoserver.security.filter.GeoServerCompositeFilter.doFil
>>>> ter(GeoServerCompositeFilter.java:92)
>>>>         at org.springframework.security.web.FilterChainProxy.doFilter(F
>>>> ilterChainProxy.java:173)
>>>>         at org.geoserver.security.GeoServerSecurityFilterChainProxy.doF
>>>> ilter(GeoServerSecurityFilterChainProxy.java:135)
>>>>         at org.springframework.web.filter.DelegatingFilterProxy.invokeD
>>>> elegate(DelegatingFilterProxy.java:346)
>>>>         at org.springframework.web.filter.DelegatingFilterProxy.doFilte
>>>> r(DelegatingFilterProxy.java:259)
>>>>         at org.apache.catalina.core.ApplicationFilterChain.internalDoFi
>>>> lter(ApplicationFilterChain.java:241)
>>>>         at org.apache.catalina.core.ApplicationFilterChain.doFilter(App
>>>> licationFilterChain.java:208)
>>>>         at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.j
>>>> ava:87)
>>>>         at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42
>>>>         at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDeb
>>>> ugFilter.java:48)
>>>>         at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilt
>>>> er.java:44)
>>>> Kind regards
>>>> Gideon Yegon
>>>> skype: g.yegon
>>>> On Tue, Feb 28, 2017 at 11:12 AM, Simone Dalmasso <
>>>>> What version of GeoNode did you install?
>>>>> Seems that Geoserver cannot find geonode but depending on the version,
>>>>> the configuration may be different.
>>>>> 2017-02-28 9:08 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>>>>> Hello Simone
>>>>>> Am seeing two errors;
>>>>>> 2017-02-28 09:36:37,190 INFO [geoserver.wms] -
>>>>>> Request: getServiceInfo
>>>>>> 2017-02-28 09:36:37,191 ERROR [geoserver.ows] -
>>>>>> org.geoserver.platform.ServiceException: Could not find layer
>>>>>> geonode:kewasco_connections
>>>>>> 2017-02-28 09:36:37,205 WARN [geonode.security] - Error connecting to
>>>>>> However i can be redirected automatically from geonode to geoserver
>>>>>> and also be able to preview layers in my geoserver. I think am missing
>>>>>> something out. Kindly assist thank you.
>>>>>> Kind regards
>>>>>> Gideon Yegon
>>>>>> skype: g.yegon
>>>>>> On Tue, Feb 28, 2017 at 10:44 AM, GIDEON YEGON <gyegon2001 at gmail.com>
>>>>>> wrote:
>>>>>>> Hello Simon,
>>>>>>> Thanks for your prompt response, but the redirection from geonode to
>>>>>>> geoserver is working fine, am able to connect automatically.
>>>>>>> Or there could be other problems causing geonode and geoserver not
>>>>>>> communicating well? Sorry for not being smart enough!
>>>>>>> Kind regards
>>>>>>> Gideon Yegon
>>>>>>> skype: g.yegon
>>>>>>> On Tue, Feb 28, 2017 at 10:18 AM, Simone Dalmasso <
>>>>>>>> Hi, could be that geonode and geoserver don't connect properly.
>>>>>>>> Check the geoserver logs.
>>>>>>>> 2017-02-28 7:57 GMT+01:00 GIDEON YEGON <gyegon2001 at gmail.com>:
>>>>>>>>> Hello all,
>>>>>>>>> I wanted to know what could be wrong as i was able to successfully
>>>>>>>>> install geosites on my local machine. But am getting broken thumbnails and
>>>>>>>>> legend for the layers.
>>>>>>>>> Kindly assist. Thanks.
>>>>>>>>> Kind regards
>>>>>>>>> Gideon Yegon
>>>>>>>>> skype: g.yegon
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170301/d454e844/attachment-0001.html>
More information about the geonode-users mailing list
