[GeoNode-users] I: [Geoserver-users] data dir migration from 2.7.x to 2.9.x
Eugenio Trumpy frippe12573 at hotmail.com
Thu Mar 2 05:46:07 PST 2017
I checked the contents of the security directories/files between those you suggested in data-2.9.zip and those I had in my 2.7 data dir.
I just insert the right baseurl in the geonodeAuthProvider/config.xml and it works.
Now I have geonode 2.4 stable with geonode 2.9-snapshot.
I can confirm that layers that had the border (due to tne reprojection on the fly) are well represented!!
So changing the geoserver version solved the issue.
Thank you
E.
Da: alessio.fabiani at gmail.com <alessio.fabiani at gmail.com> per conto di Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Inviato: giovedì 2 marzo 2017 10.13
A: Andrea Aime
Cc: Eugenio Trumpy; geoserver-users at lists.sourceforge.net
Oggetto: Re: [Geoserver-users] data dir migration from 2.7.x to 2.9.x
Hi Eugenio,
try to replace the following "security" folders of your GeoServer data dir with the one here http://build.geonode.org/geoserver/latest/data-2.9.x.zip (backup the old ones first):
1. security\auth\geonodeAuthProvider
2. security\filter\geonodeAnonymousFilter
3. security\filter\geonodeCookieFilter
Later make sure to redo manually the GeoNode authentication filter configuration settings on the new security folder (just do a diff of XML files and be sure the GeoNode and GeoServer URLs are correct)
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
GeoSolutions Enterprise Services<http://goo.gl/it488V>
goo.gl
GeoSolutions offers enterprise support services to help you building enterprise-class Spatial Data Infrastructures leveraging on best-of-breed Open Source
Ing. Alessio Fabiani
@alfa7691
github<https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Thu, Mar 2, 2017 at 9:57 AM, Andrea Aime <andrea.aime at geo-solutions.it<mailto:andrea.aime at geo-solutions.it>> wrote:
Hi Eugenio,
read below:
On Thu, Mar 2, 2017 at 9:10 AM, Eugenio Trumpy <frippe12573 at hotmail.com<mailto:frippe12573 at hotmail.com>> wrote:
 org.geonode.security.HTTPClient.sendGET(HTTPClient.java:89)
        org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
        org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
        org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)You are hitting an issue with a plugin the GeoServer community is not maintaining, not sure we can help.
Plugins are version specific, I'd suggest you check with the GeoNode developers if there is a version compatible
with GeoServer 2.9 and see if there is any upgrade procedure you have to follow to use it
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
phone: +39 0584 962313<tel:0584%20962313>
fax: +39 0584 1660272<tel:0584%20166%200272>
mob: +39  339 8844549<tel:339%20884%204549>
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users at lists.sourceforge.net<mailto:Geoserver-users at lists.sourceforge.net>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170302/f9708565/attachment-0001.html>
More information about the geonode-users mailing list
