[GeoNode-users] Geonode 2.6 and Geoserver integration
Giovani Fronza giovanifronza at gmail.com
Mon Mar 6 06:35:38 PST 2017
I get the code from
https://github.com/GeoNode/geonode/archive/debian/2.6.0+alpha1.zip, unziped
and run '$ sudo pip install -e .'
Geoserver was get from $ sudo paver setup, copied from downloaded to
/var/lib/tomcat7/webapps.
2017-03-06 11:27 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
> Hi Giovani,
> How did you perform the installation? If you rely on ppa this
> configuration is done automatically. Please be careful that only testing
> release is available at the moment since we are managing with few bugs
> before the official stable.
> Hope this helps
> Sent from Nylas Pro
> <https://link.nylas.com/link/43o9gzlmd58gqwkxv3di3wjcc/local-6d2072db-1196/0?redirect=https%3A%2F%2Fnylas.com%2Fnylas-pro%3Fref%3Dn1&r=Z2lvdmFuaWZyb256YUBnbWFpbC5jb20=>,
> the most powerful email app for work
> On mar 6 2017, at 3:12 pm, Giovani Fronza <giovanifronza at gmail.com>
> wrote:
>> Hello list!
>> I'm trying to use version 2.6 for a production server on the local
>> network. It looks like everything is ok with the geonode configuration for
>> local address 10.108.128.38, except for integration with geoserver.
>> So I tried to adjust the settings for authentication in the geoserver by
>> replacing the localhost:8000 parameters with my local address
>> 10.108.128.38, resulting in the following configuration:
>> [image: Imagem inline 2]
>> I still can not access the geoserver in authenticated mode from the
>> geonode. When I try to perform authentication using the geonode logo button
>> on the geoserver interface I get the following notification:
>> Error: invalid_request
>> Invalid client_id parameter value.
>> What could be wrong here? How to get valid values for Client ID and
>> Client Secret for Oauth2 authentication?
>> Giovani
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170306/4808525b/attachment-0001.html>
More information about the geonode-users mailing list
