[GeoNode-users] Javascript+html
Yogini Sonawane yogini.sonawane92 at gmail.com
Tue Mar 7 23:19:53 PST 2017
Okay Sir,
       1) My aim is to run  my coding on GeoNode. I want to make an
application using GeoNode. I thought that.. after storing and publishing
the .html file on Geoserver it will show on GeoNode too, like I done with
spatial data (.shp, .prj, .shx, .dbf )
I have this .doc file. In that I made a coding using open layers, html, css
and javascript. It is an application to digitize geographical features
using line, point and polygon. I want to apply it on GeoNode thats why i
made it in .html format.
           How the code is running in .html file.. i wish to create same
application which will run on Geonode.. .On the openLayer I can digitize
the area or I can show the pop up etc.
       2)  Where can i do coding to make an application which will run in
GeoNode ? If i did some coding with python or some another language, How
can i apply it on GeoNode?
       3)I have school data in .excel format.. with address, lat long and
facilities. i want to store it in database like PostGIS/ Postgree . Then a
coding which should apply in Geonode and then want to make an application
using CartoView.
On Wed, Mar 8, 2017 at 12:04 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, I don't understand what you want to achieve. It is not possible to
> load an html file in geoserver. Geoserver can only publish spatial data,
> and this is done through geonode.
> 2017-03-08 7:33 GMT+01:00 Yogini Sonawane <yogini.sonawane92 at gmail.com>:
>> ---------- Forwarded message ----------
>> From: Yogini Jalidar Sonawane <yoginij.sonawane at st.niituniversity.in>
>> Date: Wed, Mar 8, 2017 at 12:00 PM
>> Subject: Fwd: Javascript+html
>> To: Yogini Sonawane <yogini.sonawane92 at gmail.com>
>> Date: Thu, Mar 2, 2017 at 11:43 AM
>> Subject: Re: Javascript+html
>> To: jitendra shah <jituviju at gmail.com>
>> To save .html file in user/share/geoserver/data... I dont have the www
>> named file in user/share/geoserver/data in Geosever , where i can publish
>> my .html file on Geoserver
>> On Thu, Mar 2, 2017 at 11:12 AM, Yogini Jalidar Sonawane <
>> yoginij.sonawane at st.niituniversity.in> wrote:
>>> Sir,
>>> I want to run .html file on GeoNode. How can it possible ?
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170308/385e9ef5/attachment-0001.html>
Type: application/msword
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170308/385e9ef5/attachment-0001.doc>
More information about the geonode-users mailing list
