[GeoNode-users] How to establish a relation between a layer and a document in the GeoNode database
Eloi eloi at openmailbox.org
Wed Mar 8 05:09:18 PST 2017
Thanks for your quick reply Simone.
It was very helpful. Now I can see in a SQL query how Documents and
Layers relate:
SELECT d.resourcebase_ptr_id AS doc_id,
        l.resourcebase_ptr_id AS lay_id,
        d.title_en AS doc_title,
        l.title_en AS lay_title
FROM documents_document AS d
LEFT JOIN layers_layer  AS l ON l.resourcebase_ptr_id = d.object_id
ORDER BY l.title_en;
And I was wrong when I said "every time I run the command "python
manage.py updatelayers" all established relations (between a layers and
a documents) disappear". That is not true, they did disappear because I
have delete the layers in order to restore them again in the update. So
my fault. Still learning.
Thank you very much for the help.
Cheers,
Eloi
On 2017-03-08 11:50, Simone Dalmasso wrote:
> Hi,
> The layers are actually saved in the layer_layer table but the relation
> is in document_document and points to the ContentType model. It is a
> generic relation since it can point to any other geonode resource. The
> two fields that you have to compile in the document table are the
> contenty_type (the id if the layer content type in your case) and
> object_id(the id of the target layer.)
> Hope this helps
> 2017-03-08 10:05 GMT+01:00 Eloi <eloi at openmailbox.org>:
>> Good morning,
>> I would like to establish the relation between a layer and a document
>> using the GeoNode database and not using the web interface.
>> I saw that the layers are listed in table 'base_resourcebase' and
>> documents in 'documents_document'. So I wonder in which table the
>> relation between the previous two is recorded. Then I would just run
>> my SQL code to define does relations.
>> Why I want to do this? Because every time I run the command "python
>> and a documents) disappear.
>> Thank you in advance!
>> Cheers,
>> Eloi
More information about the geonode-users mailing list
