[GeoNode-users] Geonode account registrations don't work
Adam Lawrence alaw005 at gmail.com
Fri Mar 10 03:37:22 PST 2017
On 11 March 2017 at 00:16, Adam Lawrence <alaw005 at gmail.com> wrote:
> Thank you, but unfortunately it still doesn't work. I have pasted the
> following into my local_sttings.py from https://github.com/
> GeoNode/geonode/blob/master/geonode/settings.py but I now get a server
> error 500 code on all pages. I did a sudo service apache2 restart after the
> change but do I also need to restart something else?
> INSTALLED_APPS = (
> 'modeltranslation',
> # Boostrap admin theme
> # 'django_admin_bootstrapped.bootstrap3',
> # 'django_admin_bootstrapped',
> # Apps bundled with Django
> 'django.contrib.auth',
> 'django.contrib.contenttypes',
> 'django.contrib.sessions',
> 'django.contrib.sites',
> 'django.contrib.admin',
> 'django.contrib.sitemaps',
> 'django.contrib.staticfiles',
> 'django.contrib.messages',
> 'django.contrib.humanize',
> 'django.contrib.gis',
> # Third party apps
> # Utility
> 'pagination',
> 'taggit',
> 'treebeard',
> 'friendlytagloader',
> 'geoexplorer',
> 'leaflet',
> 'django_extensions',
> #'geonode-client',
> # 'haystack',
> 'autocomplete_light',
> 'mptt',
> # 'modeltranslation',
> 'djcelery',
> 'storages',
> 'floppyforms',
> # Theme
> "pinax_theme_bootstrap_account",
> "pinax_theme_bootstrap",
> 'django_forms_bootstrap',
> # Social
> 'account',
> 'avatar',
> 'dialogos',
> 'agon_ratings',
> # 'notification',
> 'announcements',
> 'actstream',
> 'user_messages',
> 'tastypie',
> 'polymorphic',
> 'guardian',
> 'oauth2_provider',
> ) + GEONODE_APPS
> On 11 March 2017 at 00:01, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
>> The easiest way is to copy the installed apps block from the default
>> settings, see in github, and copy in your /etc/geonode/local_settings.py
>> uncommenting notifications.
>> Il giorno ven 10 mar 2017 alle 11:36 Adam Lawrence <alaw005 at gmail.com>
>> ha scritto:
>>> Hi, thank  you for the advice. Can you please advise how to access the
>>> installed apps settings if I've used the PPA install method or is that not
>>> possible?
>>> On 10 March 2017 at 21:55, Simone Dalmasso <simone.dalmasso at gmail.com>
>>> wrote:
>>> Hi, you have to also uncomment "notifications" in the settings installed
>>> apps. then run syncdb. If that is missing from the doc then we need to fix
>>> it.
>>> 2017-03-10 5:09 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
>>> Hi,
>>> I have using the Ubuntu PPA install of geonode but user registration
>>> does not work. I get the error below and understand that the
>>> "notifications" module is not enabled in python, e.g. refer
>>> https://github.com/GeoNode/geonode/issues/2114. How do I enable
>>> notifications given I used the quick install method?
>>> The steps I followed to configure email server and user registration
>>> were
>>>       Open config file::
>>>             sudo nano /etc/geonode/local_settings.py
>>>       Locate the following email and user registration settings::
>>>             #REGISTRATION_OPEN = False
>>>             #ACCOUNT_APPROVAL_REQUIRED = False
>>>             #ACCOUNT_EMAIL_CONFIRMATION_EMAIL = False
>>>             #ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = False
>>>             # Uncomment the following to receive emails whenever there
>>> are errors in GeoNode
>>>             # or to be notified of new user requests when
>>> ACCOUNT_APPROVAL_REQUIRED has been set.
>>>             #ADMINS = (
>>>             #            ('John', 'john at example.com'),
>>>             # Uncomment the following to use a Gmail account as the
>>> email backend
>>>             #EMAIL_USE_TLS = True
>>>             #EMAIL_HOST = 'smtp.gmail.com'
>>>             #EMAIL_HOST_USER = 'youremail at gmail.com'
>>>             #EMAIL_HOST_PASSWORD = 'yourpassword'
>>>             #EMAIL_PORT = 587
>>>       Update these settings according to your requirements. Then do the
>>> following to ensure works:
>>>             sudo geonode syncdb
>>>             sudo service tomcat7 restart
>>> [[This does not work as "notification" module not enabled in django
>>> settings file]]
>>> ProgrammingError at /account/signup/
>>> relation "notification_noticetype" does not exist
>>> LINE 1: ...iption", "notification_noticetype"."default" FROM "notificat...
>>> Regards
>>> Adam
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170311/cb32a399/attachment-0001.html>
More information about the geonode-users mailing list
