[GeoNode-users] Geonode account registrations don't work
Simone Dalmasso simone.dalmasso at gmail.com
Fri Mar 10 23:42:46 PST 2017
I see I might be a circular import issue. I haven't actually tried it :)
usually this type of customization is done through a Geonode project.
So then copy again all installed apps. And also the geonode apps and
uncomment notification.
Il giorno ven 10 mar 2017 alle 23:23 Adam Lawrence <alaw005 at gmail.com> ha
scritto:
> Hi,
> Thank you and I like that solution better! Only problem is I still get an
> 500 error, and when I tried syncdb I get the following error:
> $ sudo geonode syncdb
> Traceback (most recent call last):
>   File "/usr/bin/django-admin.py", line 5, in <module>
>     management.execute_from_command_line()
>   File
> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
> 399, in execute_from_command_line
>     utility.execute()
>   File
> 392, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> 261, in fetch_command
>     commands = get_commands()
>   File
> 107, in get_commands
>     apps = settings.INSTALLED_APPS
>   File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
> 54, in __getattr__
>     self._setup(name)
> 49, in _setup
>     self._wrapped = Settings(settings_module)
> 128, in __init__
>     mod = importlib.import_module(self.SETTINGS_MODULE)
>   File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line
> 40, in import_module
>     __import__(name)
>   File "/usr/local/lib/python2.7/dist-packages/geonode/settings.py", line
> 871, in <module>
>     from local_settings import *  # noqa
>   File "/usr/local/lib/python2.7/dist-packages/geonode/local_settings.py",
> line 110, in <module>
>     INSTALLED_APPS = geonode.settings.INSTALLED_APPS + ('notification',)
> AttributeError: 'module' object has no attribute 'settings'
> On 11 March 2017 at 00:45, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
> oh right I forgot the geonode apps. Ok discard the previous and try with
> this one
> 2017-03-10 12:37 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
> On 11 March 2017 at 00:16, Adam Lawrence <alaw005 at gmail.com> wrote:
> Thank you, but unfortunately it still doesn't work. I have pasted the
> following into my local_sttings.py from
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py but I
> now get a server error 500 code on all pages. I did a sudo service apache2
> restart after the change but do I also need to restart something else?
> INSTALLED_APPS = (
> 'modeltranslation',
> # Boostrap admin theme
> # 'django_admin_bootstrapped.bootstrap3',
> # 'django_admin_bootstrapped',
> # Apps bundled with Django
> 'django.contrib.auth',
> 'django.contrib.contenttypes',
> 'django.contrib.sessions',
> 'django.contrib.sites',
> 'django.contrib.admin',
> 'django.contrib.sitemaps',
> 'django.contrib.staticfiles',
> 'django.contrib.messages',
> 'django.contrib.humanize',
> 'django.contrib.gis',
> # Third party apps
> # Utility
> 'pagination',
> 'taggit',
> 'treebeard',
> 'friendlytagloader',
> 'geoexplorer',
> 'leaflet',
> 'django_extensions',
> #'geonode-client',
> # 'haystack',
> 'autocomplete_light',
> 'mptt',
> # 'modeltranslation',
> 'djcelery',
> 'storages',
> 'floppyforms',
> # Theme
> "pinax_theme_bootstrap_account",
> "pinax_theme_bootstrap",
> 'django_forms_bootstrap',
> # Social
> 'account',
> 'avatar',
> 'dialogos',
> 'agon_ratings',
> # 'notification',
> 'announcements',
> 'actstream',
> 'user_messages',
> 'tastypie',
> 'polymorphic',
> 'guardian',
> 'oauth2_provider',
> ) + GEONODE_APPS
> On 11 March 2017 at 00:01, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
> The easiest way is to copy the installed apps block from the default
> settings, see in github, and copy in your /etc/geonode/local_settings.py
> uncommenting notifications.
> Il giorno ven 10 mar 2017 alle 11:36 Adam Lawrence <alaw005 at gmail.com> ha
> scritto:
> Hi, thank  you for the advice. Can you please advise how to access the
> installed apps settings if I've used the PPA install method or is that not
> possible?
> On 10 March 2017 at 21:55, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
> Hi, you have to also uncomment "notifications" in the settings installed
> apps. then run syncdb. If that is missing from the doc then we need to fix
> it.
> 2017-03-10 5:09 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
> Hi,
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170311/69a6b227/attachment-0001.html>
More information about the geonode-users mailing list
