[GeoNode-users] Connection error
Carmine Massarelli carmine.massarelli at ba.irsa.cnr.it
Wed Mar 22 09:47:35 PDT 2017
Dear,
I created a new db in postgres on geonode server with postgis extension.
We manipulate a layer stored in that db from our local qgis istance
using the plugin DB manager for a remote connection.
If I add new store, postgis (sorry for spatialite), directly from
geoserver and then I create a map in geonode adding that layer I receive
that error.
thanks in advance
carmine
Il 03/22/2017 05:35 PM, Francesco Bartoli ha scritto:
> Hi Carmine,
> what do you mean with upload a spatialite layer in geoserver? Maybe
> using its extension for spatialite? Can you explain a little better
> your workflow?
> Il giorno 22/mar/2017, alle ore 17:17, Carmine Massarelli
> <carmine.massarelli at ba.irsa.cnr.it
> <mailto:carmine.massarelli at ba.irsa.cnr.it>> ha scritto:
>> thanks,
>> but sometimes we need to edit a spatialite layer from different qgis
>> desktop in remote connection to geonode postgresdb. Is it possible
>> without receive that error?
>> many thanks
>> carmine
>> Il 03/22/2017 02:50 PM, Simone Dalmasso ha scritto:
>>> Hi you should use Geonode to load data. Or run the updatelayers
>>> commands after you loaded in geoserver.
>>> Il giorno mer 22 mar 2017 alle 14:00 Carmine Massarelli
>>>     Dear,
>>>     if I upload a layer (shapefile or spatialite) directly in
>>>     geoserver and then I create a map using local geoserver option
>>>     to add a layer, I receive this error:
>>>     /Connection Error//
>>>     //The server returned an error: 404 NOT FOUND./
>>>     If I click on Detail I can only see Page not Found.
>>>     I use geonode version 2.4 on Ubuntu 14.04.
>>>     How could I solve this issue?
>>>     thank in advance
>>>     carmine
>>>     _______________________________________________
>>>     geonode-users mailing list
>>>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>>>     https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170322/c77abb2c/attachment.html>
More information about the geonode-users mailing list
