[GeoNode-users] Connection error
Francesco Bartoli xbartolone at gmail.com
Thu Mar 23 00:43:33 PDT 2017
So the command you have to run is:
geonode updatelayers
Francesco
23 mar 2017, 08:26 +0100, Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it>, ha scritto:
> unfortunately I have not install master version but production one.
> Thanks again
> Il 03/22/2017 05:54 PM, Francesco Bartoli ha scritto:
> > Then you should use the command ‘updatelayers’ as Simone already suggested. GeoNode needs that layer within its configuration data.
> > Hope this helps
> > Il giorno 22/mar/2017, alle ore 17:47, Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it (mailto:carmine.massarelli at ba.irsa.cnr.it)> ha scritto:
> > > Dear,
> > > I created a new db in postgres on geonode server with postgis extension.
> > > We manipulate a layer stored in that db from our local qgis istance using the plugin DB manager for a remote connection.
> > > If I add new store, postgis (sorry for spatialite), directly from geoserver and then I create a map in geonode adding that layer I receive that error.
> > > thanks in advance
> > > carmine
> > > Il 03/22/2017 05:35 PM, Francesco Bartoli ha scritto:
> > > > Hi Carmine,
> > > > what do you mean with upload a spatialite layer in geoserver? Maybe using its extension for spatialite? Can you explain a little better your workflow?
> > > > Il giorno 22/mar/2017, alle ore 17:17, Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it (mailto:carmine.massarelli at ba.irsa.cnr.it)> ha scritto:
> > > > > thanks,
> > > > > but sometimes we need to edit a spatialite layer from different qgis desktop in remote connection to geonode postgresdb. Is it possible without receive that error?
> > > > > many thanks
> > > > > carmine
> > > > > Il 03/22/2017 02:50 PM, Simone Dalmasso ha scritto:
> > > > > > Hi you should use Geonode to load data. Or run the updatelayers commands after you loaded in geoserver.
> > > > > > Il giorno mer 22 mar 2017 alle 14:00 Carmine Massarelli <carmine.massarelli at ba.irsa.cnr.it (mailto:carmine.massarelli at ba.irsa.cnr.it)> ha scritto:
> > > > > > > Dear,
> > > > > > > if I upload a layer (shapefile or spatialite) directly in geoserver and then I create a map using local geoserver option to add a layer, I receive this error:
> > > > > > > Connection Error
> > > > > > > The server returned an error: 404 NOT FOUND.
> > > > > > > If I click on Detail I can only see Page not Found.
> > > > > > > I use geonode version 2.4 on Ubuntu 14.04.
> > > > > > > How could I solve this issue?
> > > > > > > thank in advance
> > > > > > > carmine
> > > > > > > _______________________________________________
> > > > > > > geonode-users mailing list
> > > > > > > geonode-users at lists.osgeo.org (mailto:geonode-users at lists.osgeo.org)
> > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
> > > > > > Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170323/1ca07899/attachment.html>
More information about the geonode-users mailing list
