[GeoNode-users] Geonode and latest Geoserver
Francesco Bartoli xbartolone at gmail.com
Tue Mar 28 05:28:54 PDT 2017
In general geoserver has an ecosystem of pluggable modules which are released publicly for stable versions or can be built on our own. Geonode relies on a snapshot version of geoserver regardless of its version so basically you should achieve that by compiling the vector tile module from the geoserver source code. Just make sure to check-out the branch corresponding to the current version deployed with geonode.
Please also note that vector tiles are not yet supported by the web mapping component within geonode.
Hope this helps
Regards
Francesco
28 mar 2017, 13:15 +0200, Zizi Jama <mazizi.jama at gmail.com>, ha scritto:
> I want to replace our WMS basemap with vector tiles.
> I am more than happy to wait for GeoServer 2.11.0 to be part of GeoNode.
> Zizi
> On Tue, Mar 28, 2017 at 12:54 PM, Francesco Bartoli <xbartolone at gmail.com (mailto:xbartolone at gmail.com)> wrote:
> > Hi Zizi,
> > The stable version of GeoNode will be released with GeoServer 2.9.x while master is waiting for the merge of this branch (https://github.com/GeoNode/geoserver-geonode-ext/tree/2.10.x) for GeoServer 2.10.x. Once this will happen eventually it could be back ported to the stable release.
> > What’s your use case to have the last release which got out just few days ago?
> > Francesco
> > Il giorno 28/mar/2017, alle ore 12:33, Zizi Jama <mazizi.jama at gmail.com (mailto:mazizi.jama at gmail.com)> ha scritto:
> > > Is my understanding correct in that Geonode does not track the latest version of Geoserver.
> > > If so, why is that the case or alternatively is there a roadmap that shows the relationship between Geonode and Geoserver releases.
> > > Regards,
> > > Zizi
> > > _______________________________________________
> > > geonode-users mailing list
> > > geonode-users at lists.osgeo.org (mailto:geonode-users at lists.osgeo.org)
> > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170328/e61d649c/attachment.html>
More information about the geonode-users mailing list
