[GeoNode-users] Different layer count depending on site language
Daniel Victoria daniel.victoria at gmail.com
Tue Mar 28 08:18:53 PDT 2017
Found out that, for some reason, the English layer title in the Admin panel
was empty. I populated some layer titles in the en column and the layer
count worked. Is there a way to have GeoNode count the number of titles in
Portuguese as use that when the site language is english? Maybe my site
language settings are incorrect?
Cheers
Daniel
On Tue, Mar 28, 2017 at 12:13 PM Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Still trying to solve this problem. Though the culprit could be malformed
> .mo files. Deleted and created the .mo files again, using 'geonode
> compilemessages'. But still, no luck. When I use English as the site
> language, the number of layers in the first page says 'No layers'. If I
> change to any other language, I get the correct number of layer counts.
> On Fri, Mar 24, 2017 at 2:23 PM Daniel Victoria <daniel.victoria at gmail.com>
> wrote:
> Hi list,
> Running geonode 2.4 on Ubuntu.
> I have 2 layers registered in my site. When I load the site using
> portuguese (pt_br) language, the layer count in the first page is OK (2
> camadas). But if I change the language to English, layer count shows 'No
> layers'. All other languages work as expected. Any idea were I could have
> messed up?
> Cheers
> Daniel
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170328/e6ad1b32/attachment.html>
More information about the geonode-users mailing list
