[GeoNode-users] Problem to update the metadata_xml and CSW response
Davi Custodio davicustodio at gmail.com
Fri Mar 31 11:02:37 PDT 2017
Hello everyone, I'm having problems in the metadata form of Geonode 2.4
with regards to CSW xml generation.
I noticed that, for example, if i change only the abstract field, the
metadata_xml is not populated, and consequently, the PyCSW response remains
out of date.
In what class should I change, to force, that whenever any field in the
metadata form is changed, the metadata_xml field is populated?
Thanks
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170331/c18a96be/attachment.html>
More information about the geonode-users mailing list
