[GeoNode-users] Data backup (docker)
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu May 4 02:34:02 PDT 2017
Hello,
I guess you need to correctly setup your settings.
Please read the guide here about it
http://docs.geonode.org/en/latest/tutorials/admin/backup_restore/index.html#settings
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Thu, May 4, 2017 at 11:14 AM, Enrique Cerrillo Cuenca <cerrillo at uevora.pt
> wrote:
> Hi everyone,
> I'm really newbie to geonode and also to docker. I've managed to deploy a
> docker installation of geonode into a server. However, I'm really stuck on
> how to backup the data. Have any of you any experience on this?
> I've try to backup docker volumes, although I'm able to get data, the
> volume names are not standardized, which makes difficult to write a script
> that backup them.
> I have also try to use the traditional "python manage.py backup" approach
> inside the geonode_django container, but I'm getting this error "OSError:
> [Errno 2] No such file or directory: '/opt/gs_data_dir/data/geonode'".
> Any help will be highly appreciated! Thanks in advance,
> Enrique
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170504/da2e8f81/attachment.html>
More information about the geonode-users mailing list
