[GeoNode-users] Admin auto login with geoserver not working
Francesco Bartoli xbartolone at gmail.com
Sun May 7 14:58:10 PDT 2017
Hi Toni,
this behavior is expected, the first time you access geoserver from geonode you have to login with the button on top of the page.
Francesco
Il giorno 07/mag/2017, alle ore 20:38, Toni Schönbuchner <toni.schoenbuchner at csgis.de> ha scritto:
> Hi,
> this might be easy. On a Ubuntu 14.04 and 16.04 vagrant
> I´ve installed geonode 2.6a1 and 2.6c1 from apt and from git!
> In every test case the geonode admin user is not automatically logged-in
> in geoserver. Even if I add GEONODE_BASE_URL (192.168.100.1)
> to web.xml as the documentation suggests nothing changes.
> The session cookie is valid for 192.168.100.1 / means geoserver
> should be able to read it.
> Has something changed with geoserver (2.9-SNAPSHOT) autologin in 2.6?
> cheers,
> Toni
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
